Question about Palm Tungsten E2 Handheld
My palm just displays ''Palm Powered'' Tried soft reset
  • Palm Expert
  • 346 Answers
Have you tried a hard reset? Just remember a hard reset will delete everything on your device. All your data will be deleted, and formats, preferences and other settings are restored to their factory default settings. Don't perform a hard reset unless you've backed up your data, or you're willing to lose everything. Here is a link with the directions:
http://kb.palm.com/wps/portal/kb/na/tungsten/e/unlocked/solutions/article/42094_en.html#tx
If that doesn't work then try the free palm chat service they offer. Here is a link to that:
http://kb.palm.com/wps/portal/kb/na/tungsten/e/unlocked/solutions/article/43473_en.html
Posted on Nov 19, 2009
Palm won't shut off but displays the Palm shield with the note "powered by" or it displays a message that says it it trying to connect to tyhe desktop. I have pressed the reset button and it will shut off...
HI,
Here is a link to Palm support. It sounds like you need to do a hard reset. Try that by depressing the reset button on the back of your unit. You will need to use something pointed like a paperclip and insert that into the hole and hold in in while you hold down the power button. When you see the Palm powered logo let go of the power button and follow the onscreen directions.
Here is the link for Palm support in case you have any other issues.
http://kb.palm.com/wps/portal/kb/na/tungsten/e/unlocked/home/page_en.html
Oct 26, 2009 | Palm Tungsten E Handheld
When trying to sync, error message reads (sys 0505)(0,841).What can I do? For Palm TX handheld
Try to perform a System Reset (see article linked below). If it works to break the loop, you should then be able to delete the offending "My Palm" software and perform a Hotsync to backup your data to your desktop.
If that doesn't break the loop, you'll have to perform another Hard Reset. Sometimes, a Hard Reset takes a couple of tries to get it right, since it's easier to do it wrong than to do it right.
This article discusses the various types of Reset for different Palm devices:
http://tinyurl.com/zlwza
Until you break the TX out of its loop, you won't be able to get the data from it.
To see the Palm OS version running on your TX, enter the Menu, select Info, then Version.
To Get Out Of A Loop:
  1. Perform a SYSTEM RESET by doing the following:
a) Press the UP Button
b) And THEN press and release the RESET Button
c) When you see the second Logo (Palm Powered) release the UP Button
d) Now check if your SYSTEM RESET worked by going to Beam Receive. If it goes back to Off even after you put it to On it means you were successful
2. Now Perform A SOFT RESET by pressing and releasing the button in the back once
  1. After a soft reset, a logo screen appears, followed shortly by a Preferences screen asking you to set time and date.
  1. If a soft reset does not break it out of the loop, you may need to try one of the other resets below.
  1. Do an INCOMPLETE HARD RESET by holding down the power (on/off) button on your device.
  1. While holding down the power button, Press and release the reset button on the back of your handheld device
  1. Keep the power button pressed and release it when the “Palm Powered” logo appears.
  1. A message will now appear warning that you are about to “Erase All Data”. And this will happen if you press UP or DOWN.
  1. Instead you press left or right to begin a soft reset, leaving your data intact.
  1. Your device will then take you through a series of screens to calibrate the digitizer and verify the time and date.
Sorry this was so long, I tried to put everything down that might help you.
Aug 03, 2009 | Palm TX Handheld
After a soft reset, my Palm TX becomes stuck on the "Palm Powered" screen. I have tried all of the resets, including the hard reset. The PDA does not respond to any of the resets. I can not turn the PDA...
You need to perform full reset which will erase all personal data and set everything to factory default. You need to press reset and power button to perform full reset.It will give you confirmation once you choose yes it will perform hard reset If issue persist you may disconnect and reconnect to internal battery
Aug 02, 2009 | Palm TX Handheld
Palm m515 frozed up when powered on.
Did you install something rare at your palm??? Is your palm Sayin "Fatal Exeption" when you Reset it??? If you install something rare and after that your palm is saying taht you can...
Do a soft reset:
Reset it normally... If after that your palm show again that message you can;
Do a warm Reset:
Pres de up scroll when resseting.. when you so the Palm logo you can stop press the reset botom... There you will see the configuration screen... If it is not more the "fatal exeption" message you can uninstall what is doing the problem... you can hot sync your palm now... after that... do a soft reset and-If you uninstall what is doing the problem- you are not going to saw any more that message... if it is not resulting...
Try to do a Hard Reset
Do a warm reset and copy all you important files or programs to your stick memory...
then when pressing reset botom pres the on-of screen botom.... when you see the palm logo you can stop presing on-of screen botom.
bye.
From paraguay... luis-c
(sorry for my english... im stilll learning)
Apr 14, 2009 | Audio Players & Recorders
Palm stuck on the Palm Powered Screen
try syncing it to your computer
Mar 24, 2009 | Palm Z22 Handheld
T5 is frozen on the "Palm Powered" screen
Remove the battery and let the palm sit for a day, reconnect the battery and do a hard reset. To remove the battery, you need a Torx T5 screwdriver. Carefully remove the cover making a note of the location of all the buttons in the case. The battery is connected by a mini 2 pin connector, just disconnect the battery by gently wiggling the connector and pulling.
Mar 06, 2009 | Palm Tungsten T5 - Multilingual Handheld
The palm powered icon
To do a hard reset, hold down the power button, press the little reset button, release it, then release the power button.
Make sure you back up your TX first.
Jan 29, 2008 | Palm TX Handheld
Frozen screen ( palm powered)
Perform soft reset. If issue persist you may consider full reset
Nov 08, 2007 | Palm Tungsten T Handheld
Palm Tungsten E2 Handheld Logo
133 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
