Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Ice despencer opening keeps freezing and wont dispence
I have a tft27pf thats about 13 years old. Have had very little problems. Ice maker went out once. My problem is the Ice dispencer keeps freezing. (When it first begins it looks like snow on the inside of the door at the dispencer opening.) that is the only place that has the snow which turns to ice) everywhere else looks fine in the freezer. I have noticed that the fan behind the ice maker/holder is always running. Thank You
Howard
  • penyles Nov 16, 2009
    Door seal is not bad. have checked this. When I open freezer door I see thick fog in and around the ice holder and Ice dispencer only. Mostly above ice holder (above the ice). Could it be getting warm air from the fan behind the ice maker/ice holder that is running all the time. Any more suggestions?
    Door seal is not bad. Have cheked that. When I open the freezer door there is a thick fog at the ice maker/ holder area and where the ice is released into the door dispencer from the ice holder only. Could I be getting warm air from the fan that is behind the icemaker/holder that is running all the time? Does anyone have any more ideas?
    Thank You
  • 2,237 Answers
You have a bad door seal. replacement is better than repair. warm moist air is getting in and the condensation is freezing.
Posted on Nov 13, 2009
The ice maker do not give the ice
I had a problem like this it could be a few things but mine was some way or another I had a bunch of frozen ice freeze all the moving parts I had to take everything out and melt the ice it works fine now
Mar 31, 2013 | Frigidaire Refrigerators
Icemaker stopped working
It can happen that the ice got too thick for the little auger and it snapped off. The other issues arise when the water inlet tube freezes up so no water gets dispenced into the ice maker.Defrost unit to check this out. At least 24hrs.
Sep 15, 2010 | Whirlpool Refrigerators
Hotpoint refridger ice maker not despencing ice or water
my ice maker stop making ice there is ice cubes in the tray but the ice maker does not dispence the ice
Apr 04, 2010 | Hotpoint HSS25GFP Side by Side...
Icemaker will not fill with water but water comes out despencer
Check the ice maker first by filling with tap water. Let freeze and if it cycles and dumps the dual water control valve on rear is defective. If ice maker does not cycle then I think you have a problem with the ice maker. Thanks, Sea Breeze
Look for that model number.
Dec 16, 2009 | Whirlpool Refrigerators
Plhs67es fridgidaire refrigerator no water despence or making ice
Always remember Safty First to turn off power and water supply and only turn them on as needed!!!
I checked water supply it was great and then check the valves (solinoids) and the power and all was good. The next thing I checked was the water from the supply valve to the filter at the same time I put some water in the ice maker to make sure it was working (leave it to make sure it drops the ice). The filter was new but was defective. Water went to the filter but did not return any to the despencer or the ice maker. During the different test I performed I also found that the lines hook to valves that the filter plugged into and since the new filter fixed the problem those valves were ok but could have been the problem therefore I suggest if you have this problem remove the filter and depress the small valve with a small object (like a hollowed out pen) and call for the water to be dispenced. If the water does not spray out then you have another problem...I went threw the whole system to find a bad filter, which I thought in the begining but since the other filter was new I done all of the above.
Although I figured out the problem myself this is a great Web Site. Thank You
Mar 22, 2009 | Whirlpool GS5SHAXN Side by Side...
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
I have a 13 year old refrigerator with an icemaker. I installed a water line to get water to the fridge. The hose is connected to the water main and the fridge. I am not getting any ice.
Obviously, your ice maker problem could be any number of things... Now that you have water to the ice maker, is the inlet valve opening to allow water to get to the ice maker itself? If it is, is the line that runs between the inlet valve free to allow water to get to the ice maker? if it is, is the ice maker cycling ( meaning the motor rotates the drive mechanism that times the cycle of opening the valve, rotating the mold tray then releasing the ice with a small mold release heater? An ice maker that's ~ 13 years old probably has a removable front cover so that you can see the drive gears.. Also, is the lever that senses the ice cube bin is over full in a position ( normally down) that allows th eice cube maker to cycle? Hopefully, these simple checks will help you trouble shoot the problem and get your icemaker functioning again. Hope this helps !
Aug 14, 2008 | Amana Refrigerators
KENMORE REFRIGERATOR 106.57024601
the problem is most likely the water valve behind the machine. it is closing too slow and letting too much water flow into the icemaker. c30b276.jpg
Jul 16, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Frigidaire side by side ice maker, water and ice dispencer inop
It would depend on the age of the refrigerator whether repair is economical. If the refrigerator is under ten years old repair it. If it is over ten years old you have to consider how much life is remaining for the refrigerator. Burnt smell source must be located because that is the key to your problem. It could be a simple matter of replacing the switch in the door.
Jul 05, 2008 | Refrigerators
Refrigerators Logo
236 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
