Question about iRobot 5900 Scooba Robotic Wet/Dry Vacuum
I got a used Scooba which is not sucking up the solution from the floor after it dispenses it.
  • Adriana Gutierrez Nov 13, 2009
    All filters and the squeegee have been cleaned, the dirty water tank has been half filled with hot water vinegar solution and shaken thoroughly. No seals appear to be out of place.
    I suspect this unit, which I bought used may have sat unused for a while - could some valves be stuck due to this?
    I have checked all of your suggestions and none of them seems to apply. DO you have any other suggestions?
  • 3,741 Answers
Turn the tank over. It's transparent on the underside, and there are two oval-shaped openings that stick out more than an inch, located toward the middle. On the far right and far left sides, next to each oval opening, there is another opening. (These are oddly shaped-- one round, one large and curved like Roomba's filter.) Rinse all four of these openings really thoroughly with warm water. The water should go in one opening and come out one of the others. (This should happen when you put water in every one of the four ports.) Do not be surprised if you get clots of dirt out of there. This is generally what keeps Scooba from being able to pick up water. Then, if this works for you, make the tank rinse part of your regular cleaning routine and it shouldn't happen again.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Posted on Nov 14, 2009
  • 10,515 Answers
There are only a few things that can cause the condition you describe. First would be to verify that the vacuum/blower motor is running. You can test this by placing your hand on the floor opposite the side where the charger is connected and see if you feel air movement. If no air is felt, there's your problem. Second, there is a valve located in the dirty tank that if blocked will prevent water pick-up. To resolve and clear this condition will require several processes to occur at once. Fill the dirty tank half way with hot water, add Scooba cup of vinegar. Close the stopper and shake the "Good Grief" out of the tank. This action is necessary and may have to be repeated several times to clear the flapper valve in the dirty tank. Third, there may be a poor seal between the tank and the Scooba base. Verify that both the left and right sides of the tank are close to the base and equal in distance. If the right side is farther away from the tank (larger gap) then water pick up will be poor. Some Scooba owners resort to using duct tape to hold down the tank. Fourth, verify that the thin rubber pieces on the bottom of the tank are not deformed and properly seated in the grooves.
Also, make sure that you should clean the Vacuum. Sometimes, they might be clogged with junk.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 13, 2009
  • taran_2005
    taran_2005 Nov 14, 2009
    Thanks for your response!!
    It is possible that your robots vacuum is defective and therefore, not
    picking up the dirty water. Do you still hear that high pitched sound
    when your robot cleans? Do you feel air exhausting from the side of the
    tank?
    If you hear the vacuum and can feel the air, it is also possible that
    your robot tank is dirty and needs a good cleaning. You may want to
    have your tank soak in hot water and/or shake any debris out of it.
    If you flip the robots tank over, you have the holes for the Scooba
    filter port and vacuum port. You may want to insert hot water on one
    side of the tank (the filter hole) and come out of the other (the
    vacuum port hole).
    If you are not technically inclined, you may also consider our Scooba diagnostic and repair service.
    Hope i helped you.
  • 19,396 Answers
Hi .
Check the filter and check that the dust bin is well seated in place. Empty the dust bin.
If the motor is not working at all , then the motor is faulty. Motor fault is usually causing a three beeps fault code.
Check the filter holder and the blue rubber part in the dust bin. If this parts are worn, then the scooba may have lost sucking power.
In that case the solution is disassembling the unit , cleaning it , and replacing worn parts.
Scooba 390 "Charger Failed"
If this is a new Roomba make sure that the Battery pull-tab has been completely removed.
Dec 06, 2013 | Roomba iRobot Scooba 390 Floor Washing...
It leaves water after finished. That's the first time I use it but it leave water on the floor and it stops.
According to iRobot make sure that the Scooba is clean, including the parts (vacuum hose & filter, bottom roller)
Make sure the battery if fully charged, and that you let it complete the cycles!
May 15, 2010 | iRobot 5800 Scooba Vacuum
My scooba is not dispensing the water
Mine started doing thatafteri bought a new battery.
now i wet the floor lightly and let it run. after several minutes the solution comes out.
Jan 23, 2010 | iRobot 5900 Scooba Robotic Wet/Dry Vacuum
My Scooba floor cleaner "check tank" light stays on even after it's refilled and everything cleaned but still will not work. It just keeps beeping at me when I try to start it. How do I reset it or get...
Flush out the solution valve with water (aka "prime the pump"). Use water, not just air, because water will clear any obstructions that may be in the lines. Also, rinse your tank through the four ports on the *underside*-- one round, two oval, one large and curved, all four in a row. Rinse them really thoroughly with warm water, then refill the tank and try the Scooba again. If it doesn't work, call us: 1-877-855-8593.
Aug 16, 2009 | iRobot 5800 Scooba Vacuum
Scooba problem
Does it put down clean water onto the floor? If so, rinse the four ports on the underside of the tank really thoroughly. You might have a clog; it's not difficult to dislodge it if you use enough warm water. Also make sure that the squeegees on the cleaning head cartridge (which holds the brush) are straight and in good condition.
If it doesn't put down water at all, try the tank rinse anyway, as it can help with that issue, too.
Jun 20, 2009 | iRobot 5800 Scooba Vacuum
Can you use irobot Scooba on laminate floors?
they are suppose to be hardwood floor safe but maybe you should call the manurfacturer and make sure
Mar 21, 2009 | iRobot 5800 Scooba Vacuum
My scooba is not picking up all the water.
There are only a few things that can cause the condition you describe. First would be to verify that the vacuum/blower motor is running. You can test this by placing your hand on the floor opposite the side where the charger is connected and see if you feel air movement. If no air is felt, there's your problem. Second, there is a valve located in the dirty tank that if blocked will prevent water pick-up. To resolve and clear this condition will require several processes to occur at once. Fill the dirty tank half way with hot water, add Scooba cup of vinegar. Close the stopper and shake the "Good Grief" out of the tank. This action is necessary and may have to be repeated several times to clear the flapper valve in the dirty tank. Third, there may be a poor seal between the tank and the Scooba base. Verify that both the left and right sides of the tank are close to the base and equal in distance. If the right side is farther away from the tank (larger gap) then water pick up will be poor. Some Scoobe owners resort to using duct tape to hold down the tank. Fourth, verify that the thin rubber pieces on the bottom of the tank are not deformed and properly seated in the grooves. hope this helps
Oct 17, 2007 | iRobot 5900 Scooba Robotic Wet/Dry Vacuum
Will not dispense soap from handle
The soap dispenser, on the side, make sure the seal is on the bottom of it and not in the hole. You may have to replace the valve asm for the dispenser part # 2101795
Sep 30, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
iRobot 5900 Scooba Robotic Wet/Dry Vacuum Logo
154 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
