Question about HP iPAQ RX3715 Pocket PC
Screen problem My touch screen wont respond to the stylus, it was working fine til i installed some software. Active sync still works, so I Uninstalled all the software but no luck. I then tried soft resets and a hard reset a couple of times but now it is stuck on tap screen to align screen page. Is this a software issue or is the screen duff?
  • 59 Answers
Sometimes 3rd party apps that don't work so well with the palms can freeze them up.,/
You could do a hard reset and when you initially sync the palm, when it asks you for a profile choose a new one and see if this method removes your problem.
Diagnosing problems by 3rd parties link-
More info-
Does the calibrator keep looping or not seem to work?
If you can access the calibrator, but it loops through the target sequence (repeatedly asking you to tap the targets), there may be a physical problem that's causing your touchscreen to be confused:
  • Do you use an adhesive screen protector? A screen protector which is trapped under the screen edge may interfere with touchscreen calibration. Occasionally, just having the screen protector on the screen can cause the issue. Try removing the screen protector.
  • You may have debris trapped under the edge of the screen. Use the corner of a piece of thin, stiff paper (copier paper works well) to very gently slide all around the edge of the screen. Don't let the corner of the paper travel more than an eighth of an inch under the screen edge frame. By doing this, you may be able to dislodge small particles of debris trapped under the frame.
  • A heavy impact or scrape to the touchscreen can cause permanent damage. If your touchscreen is damaged, you may need a repair
Posted on Jan 08, 2008
  • Eduard Vander Smitte
    Eduard Vander Smitte Jan 11, 2008
    This has some good digitizer fix ideas, the whole link won't fit on the post so you have to copy and paste. Hope it helps!
Pfaff creative 7570 touch screen doesnt work
it's possible that the computer has gone out, since it's used it would be a good idea to have it checked.
Mar 08, 2014 | Sewing Machines
My touch screen wont respond to touch or stylus or anything at all...screen looks great it just doesnt respond
Can you please advise which model, and what is the problem you have....good detail works best for a better, faster reply..Please use this link ... Contact Us at Bargain Box
I cannot connect my htc touch mobile to my pc (computer). what can i do for it . can i install the new software on it.
uninstall the active sync software from the computer and download the lastest active sync software (as per your windows version) and install it, this should solve your problem.
Dec 25, 2010 | HTC Touch P3450 Smartphone
My iphone wont respond to touch i cant use it
try hard reset (hold down the power button and the central button until you see Apple logo on screen). If this wont help then use RESTORE.
Aug 25, 2009 | Apple iPhone 3G Black Smartphone
Need to get contacts from phone to computer and my screens broke
hey mate you need active sync on your pc- it should have installed in the first connection (maybe you got a cd with the HD with it on it or try searching for it) from here you connect up using the usb cable that also goes in your power pack and connect it up and choose active sync on the mobile (if touch is still working) or if not it usually is preset to choose active sync from here it should start syncing all your phone info to microsoft excahnge automatically (i had to set up an excahnge connected it to my hotmail account/uni account) from here next time u say reset your phone (hard reset) or flash it or get a new windows mobile phone (all same software ie samsung omnia and htc touch hd both windows 6.1) it will automatically resync all your contacts onto the phone (as long as its connected on active sync)- hope this helps a bit
May 25, 2009 | HTC Touch HD Smartphone
Please help me!!! i buy my new htc touch dual i already installed(and also activated ) activesync 4.5 but the phone says that install active sync 4.5 .And also active sync does not connect.
If you are on Xp you need to go in control panel, click ad hardware, follow the steps til it get on.
but if you are onVISTA you need instal windows download make to isntal MOBILE DEVICE CENTER here:
May 07, 2009 | HTC Touch P3452 Smartphone
Start button not working right
Try A soft reset, open the back/battery cover and press on the reset button w/your stylus.
If it still is the same check to see if you have any programs that make 'modifications' to Windows Mobile, or Touch flo 3d, etc. As it might cause the problem. If you recently installed a program, try removing it. Of course you would have to do this through activesync or the vista equivilent.(Windows Mobile Device Center)
To do this in active sync go to Tools>Add/Remove Programs. Not sure about vista as i dont have it.
If you still can't fix it, do a hard reset, its in settings>clear storage, but i dont know how you would get to it.
Or use the hardware buttons, while the diamond is on, press/hold the power button, volume down (lower one) button, and ok/enter button, at the same time, with your stylus, press the reset button in the back. Yeah it sounds like im lying, but im not :P (Note some say you don't need to press the power button too, try a combination of the 2 if mine didnt work.
HARD RESET WILL REMOVE ALL YOUR DATA! So make sure you sync all your contacts to outlook on your PC through active sync, and make sure they're there. Your programs will be removed and will have to be reinstalled manually (other than the originally included software, like internet explorer, opera, office, etc). But if you installed through a setup file on your pc, which later makes activesync install it onto your diamond, you can reinstalled through active synce after a hard reset, by going to add/remove programs and checking the boxes for the software you want to reinstall.
Feb 21, 2009 | HTC Touch Diamond Smartphone
HTC touch HD is completley frozen
If you have all your items saved to your computer with Active Sync, then do a master reset:
HTC Touch hard reset 14 January 2008
  • Power on.
  • Press and hold buttons marked 1.
  • Press and release 2 with stylus.
  • Release buttons marked 1 when menu comes up.
  • Press directly down on center dpad, marked 3.
You can also get tips & tricks from
It has the latest and great updates, software, even known issues if you ever come across this. HTC does recommend that you do a master/hard reset once a quarter to keep it moving smoothly. Also, ensure you don't have a lot of open running programs. Perhaps once a day, clean the cashe and history. Do a soft reset (aka battery pull) once or twice a week. All depends on how hard you play with this lovely PDA device!
Feb 02, 2009 | HTC Touch HD Smartphone
Easy Sync Pro not able to connect to my HTC touch
I had exactly the same problem. I changed location from Easysync on my HTC P3300 from memorycard to internal memory. It worked!!
Using easysync 4.26
Lotus Notes 8.0.2
Active Sync 4.5
Jul 10, 2008 | HTC Touch P3450 Smartphone
HP iPAQ RX3715 Pocket PC Logo
329 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
