Question about Craftsman Garden
I need manual for 1987 craftsmanlawn tractor 12.5 hp ohv 4 speed & stamatics also magnetto for same machiine
  • tannerlawn Nov 15, 2009
    The number is 143-386012 engine # 917-254561 tractor# im just fixing this for snow so i need info asap thank you very much.
  • 486 Answers
I need the ID numbers from the tag under the seat to be able to give you any information. Thanks, rwvanlue
Posted on Nov 13, 2009
Need to find a repair manuel for 1987 Dodge Ram Charger transmission
What you want/need is a Factory Service Manual for the '87 Ramcharger, it covers each transmission in depth.
Which, if i remember correctly, there were 4 transmissions available in 1987. The Torqueflite 727 3-Speed Automatic (Found in 2WD and 4WD Ramchargers), the 904 Torqueflite 3-Speed Auto (2WD only), the New Process 435 4-Speed Manual Transmission (2WD & 4WD) and the Chrysler A833 4-Speed Manual (2WD only)
Aug 23, 2011 | 1987 Dodge Ramcharger
I need a starter .i have a poulan 15.5 hp ohv i/c rider mower briggs& stratton how much does it cost
Before you shell out a bunch of money for a starter, unless you are sure that is what's wrong, there are a few things to check out first:
1. Safety switches
2. Starting solinoid
3. Ignition switch
4. Battery
Those are for if you have no response whatsoever. If it turns, but barely, check the following:
4. Battery (could have one bad cell and still hold some voltage, try jumpstarting the motor)
5. For over head valve (OHV) engines, adjust the intake and exhaust valves.
I hope this helps.
Aug 02, 2011 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Craftsman lawn tractor, LT2000, 18 HP OHV INTEK, 917.273752 I have a similar stalling problem as the one I reviewed in your forum, 10-15 minute run time, then stalls. Only difference, no cool down...
hi there
here is web site for manual and parts diagram
http://www.hammerwall.com/Download_Manual/12377/
have the valves been adjusted correctly ? or could have a tight valve clearance
and when gets warm holds valve open - looses power
your engine will be 31p777 intek ohv avs
run the piston to tdc on compression stroke , then turn piston past tdc & set piston is 1/4 inch down the bore on power stroke this eliminates decomprssor lift from the setting
intake should be 0.003 Thou
and exhaust 0.005t thou
then check the carburettor main jets and emulsion tube and pilot jets and air bleeds and progression ports for obstruction etc for restriction / blockage
check fuel flow from tank to carb , check that the fuel solenoid has got continual 12 volt supply
when switched on and does not go o/c cutting fuel supply to main jet
have a look let me know
cheers hope it helps
pauly 46
dont forget the thumbs rating
Jun 08, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need to replace alternator, what cars or trucks are compatable to 1991 3.0 liter engine
AerostarV6 - 3.0L vin U 182ci - MFI GAS OHV
7 vehicles
1986 - 1992
BroncoV8 - 5.0L vin N 302ci - MFI GAS OHV
2 vehicles
1986 - 1987
BroncoV8 - 5.8L vin H 351ci - 4BBL GAS OHV
5 vehicles
1988 - 1992
BroncoV8 - 5.8L vin H 351ci - MFI GAS OHV
5 vehicles
1987 - 1991
E-150 EconolineV8 - 5.0L vin N 302ci - MFI GAS OHV
4 vehicles
1988 - 1991
E-150 EconolineV8 - 5.8L vin H 351ci - MFI GAS OHV
5 vehicles
1987 - 1991
E-150 Econoline Club WagonV8 - 5.0L vin N 302ci - MFI GAS OHV
4 vehicles
1988 - 1991
E-150 Econoline Club WagonV8 - 5.8L vin H 351ci - MFI GAS OHV
5 vehicles
1987 - 1991
E-150 Econoline SuperV8 - 5.0L vin N 302ci - MFI GAS OHV
4 vehicles
1988 - 1991
E-150 Econoline SuperV8 - 5.8L vin H 351ci - MFI GAS OHV
5 vehicles
1987 - 1991
E-250 EconolineV8 - 5.0L vin N 302ci - MFI GAS OHV
4 vehicles
1988 - 1991
E-250 EconolineV8 - 5.8L vin H 351ci - MFI GAS OHV
4 vehicles
1988 - 1991
E-250 Econoline Club WagonV8 - 5.8L vin H 351ci - MFI GAS OHV
4 vehicles
1988 - 1991
E-250 Econoline Club WagonV8 - 7.5L vin G 460ci - MFI GAS OHV
1 vehicles
1991
E-250 Econoline HDV8 - 5.8L vin H 351ci - MFI GAS OHV
5 vehicles
1987 - 1991
E-250 Econoline SuperV8 - 5.0L vin N 302ci - MFI GAS OHV
4 vehicles
1988 - 1991
E-250 Econoline SuperV8 - 5.8L vin H 351ci - MFI GAS OHV
4 vehicles
1988 - 1991
E-350 EconolineV8 - 5.8L vin H 351ci - MFI GAS OHV
4 vehicles
1988 - 1991
E-350 EconolineV8 - 7.5L vin G 460ci - MFI GAS OHV
4 vehicles
1988 - 1991
E-350 Econoline SuperV8 - 5.8L vin H 351ci - MFI GAS OHV
4 vehicles
1988 - 1991
E-350 Econoline SuperV8 - 7.5L vin G 460ci - MFI GAS OHV
4 vehicles
1988 - 1991
E-350 Econoline Super WagonV8 - 5.8L vin H 351ci - MFI GAS OHV
4 vehicles
1988 - 1991
E-350 Econoline Super WagonV8 - 7.5L vin G 460ci - MFI GAS OHV
6 vehicles
1988 - 1994*
F Super DutyV8 - 7.5L vin G 460ci - MFI GAS OHV
7 vehicles
1986 - 1992
F-150V8 - 5.0L vin N 302ci - MFI GAS OHV
2 vehicles
1986 - 1987
F-150V8 - 5.8L vin H 351ci - 4BBL GAS OHV
5 vehicles
1988 - 1992
F-150V8 - 5.8L vin H 351ci - MFI GAS OHV
7 vehicles
1986 - 1992
F-150 Super CabV8 - 5.0L vin N 302ci - MFI GAS OHV
2 vehicles
1986 - 1987
F-150 Super CabV8 - 5.8L vin H 351ci - 4BBL GAS OHV
5 vehicles
1988 - 1992
F-150 Super CabV8 - 5.8L vin H 351ci - MFI GAS OHV
7 vehicles
1986 - 1992
F-250V8 - 5.0L vin N 302ci - MFI GAS OHV
2 vehicles
1986 - 1987
F-250V8 - 5.8L vin H 351ci - 4BBL GAS OHV
5 vehicles
1988 - 1992
F-250V8 - 5.8L vin H 351ci - MFI GAS OHV
2 vehicles
1986 - 1987
F-250V8 - 6.9L vin 1 420ci - MFI DIESEL OHV
2 vehicles
1988 - 1989
F-250V8 - 7.3L vin M 445ci - MFI DIESEL OHV
7 vehicles
1988 - 1994
F-250V8 - 7.5L vin G 460ci - MFI GAS OHV
2 vehicles
1986 - 1987
F-250 Super CabV8 - 5.8L vin H 351ci - 4BBL GAS OHV
5 vehicles
1988 - 1992
F-250 Super CabV8 - 5.8L vin H 351ci - MFI GAS OHV
2 vehicles
1986 - 1987
F-250 Super CabV8 - 6.9L vin 1 420ci - MFI DIESEL OHV
2 vehicles
1988 - 1989
F-250 Super CabV8 - 7.3L vin M 445ci - MFI DIESEL OHV
7 vehicles
1988 - 1994
F-250 Super CabV8 - 7.5L vin G 460ci - MFI GAS OHV
2 vehicles
1986 - 1987
F-350V8 - 5.8L vin H 351ci - 4BBL GAS OHV
5 vehicles
1988 - 1992
F-350V8 - 5.8L vin H 351ci - MFI GAS OHV
2 vehicles
1986 - 1987
F-350V8 - 6.9L vin 1 420ci - MFI DIESEL OHV
2 vehicles
1988 - 1989
F-350V8 - 7.3L vin M 445ci - MFI DIESEL OHV
7 vehicles
1988 - 1994
F-350V8 - 7.5L vin G 460ci - MFI GAS OHV
2 vehicles
1988 - 1989
F-350 Super CabV8 - 7.3L vin M 445ci - MFI DIESEL OHV
7 vehicles
1988 - 1994
F-350 Super CabV8 - 7.5L vin G 460ci - MFI GAS OHV
7 vehicles
1988 - 1994
F53V8 - 7.5L vin G 460ci - MFI GAS OHV
2 vehicles
1988 - 1989
F59V8 - 7.3L vin M 445ci - MFI DIESEL OHV
1 vehicles
1991
RangerV6 - 3.0L vin U 182ci - MFI GAS OHV
1 vehicles
1991
Ranger SuperV6 - 3.0L vin U 182ci - MFI GAS OHV
Feb 28, 2011 | 1991 Ford Aerostar Extended
Briggs & Straton 20 HP, two cilinder engine idle speed
Surging is usually caused by a lean condition You can try to turn the mixture screw ccw about 1/4 to 1/2 turn. If this does not solve the problem your carb will have to be removed, cleaned thoroughly, and reinstalled.
May 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a Craftsman LT1000 Tractor. It has a
if you have a model # 917.272672, you can download a free user manual at
http://www.craftsmanlawn.com/Tractors-Riding-Lawnmowers/917.272673/
Oct 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I need the owners manual for this lawn mower Craftsman 917.377220 6.75 HP
Here a website that gives a list of Craftman Lawn Mowers and it owner manuals. Hope it help, its were I found my manual.
http://www.craftsmanlawn.com/Walk-Behind-Mowers/
May 02, 2009 | Garden
Need owners manuel for Craftsman LT1000 Model #917.272673
I'm not the same person, but I did find this manual at the Sears parts site. I needed the same manual. I used the model# 917.273399 and thier part number is 193548. Less than ten bucks. Thanks!
Jan 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
49 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
