Question about RIM BlackBerry Curve 8310 Smartphone
My trackball on the curve 8910 is not smooth when i direct it to the right? how do i fix this
  • 541 Answers
Make small changes in the settings.
Go to options
Screen and keyboard
change the trackball sensitivity to 90 percent horizontally.
press Menu and click on save.
Posted on Nov 14, 2009
Trackball wont scroll
i think its faulty you need to get it fixed
Jun 01, 2012 | Blackberry Curve 8350i
The roller ball on my blackberry curve sticks. Any suggestions?
Most trackball movement problems can be rectified by cleaning the trackball. Try the following steps to see if it helps tp resolve the issue you are having;
1) Turn the unit off, open the back cover and pull the battery out,
2) Take a paper towel, dampen it with water...nothing else, making sure that the towel is only damp and not soaking wet,
3) Rub the damp paper towel on the trackball, over and over, making sure to rub up, down, side-to-side and every which way. This should clean the trackball and remove whatever is causing it to not move smoothly.
4) Wait a minute or two and replace the battery and cover. Once the unit has rebooted, try moving the trackball again. It should be better.
Cheers!
Dec 30, 2009 | RIM Blackberry Curve 8300
Trackball for blackberry does not move smoothly
What do you mean...can it move in all four directions?
Cheers!
Dec 29, 2009 | RIM BlackBerry Curve 8310 Smartphone
My ball wont go left or right. only up & down. what do i need to do?
Cheers!
Dec 29, 2009 | AT&T Blackberry Curve 8300 Smartphone
Ball on blackberry wont navigate up or down
Hi. BlackBerry smartphone trackball fails to roll in a particular direction because, debris is lodged in the trackball.
The trackball user interface found on certain BlackBerry smartphones is similar to the trackball used in a mouse in a desktop computer.
Using for certain period debris comes in contact with the trackball and affects the usability of the BlackBerry smartphone, rapidly roll the trackball up, down, left, or right to potentially correct the problem.
If rapidly rolling the trackball does not correct the problem, please contact your wireless service provider for support options.
I hope this information will be helpfull.
Nov 11, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
My trackball moves up and down but not to the right.
You can try cleaning it, but it's very easy to break in the process (or sometimes it's a short lived fix.) The easiest and cheapest fix is to get a new trackball. It's really easy to replace yourself, and you'll be so happy when it's back to moving in all directions!
Check out http://www.blackberrytrackball.com
Jun 09, 2009 | AT&T Blackberry Curve 8300 Smartphone
BB Curve 8310 keys and trackball not working
is there a way to navigate thru options with no trackball
May 30, 2009 | RIM BlackBerry Curve 8310 Smartphone
Blackberry curve scroll button sticking
I had a similar problem, and the only solution is to change the trackball which cost between $5 & $10 dollars on e-bay. An easy and cheap fix, it comes with the tool to replace the assembly. A kid can do the job
May 11, 2009 | RIM BlackBerry Curve 8310 Smartphone
The tracking ball rotates but it does not move over the icons on the left side. Is there anything I can do to fix this?
Depending on how comfortable you are with removing the trackball it's not hard to fix... you may have some dirt or grit interfering with the trackball and/or sensors. Take a small screwdriver or blade and gently pop the silver ring around the trackball off. This will free the actual trackball housing. Use an old toothbrush to clean everything. I also soaked the trackball in a little rubbing alcohol. Just make sure it is completely dry before reassembling. If that doesn't work you can purchase replacement trackballs from places like crackberry.com.
Apr 18, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Trackball not moving right
This is right, the problem is in the trackball. If you can get hold of alcohol like the one used years ago to clean the heads of tape decks etc, you may be able to put some in the trackball and rotate the ball around in all directions with the hope that it may clean it.
Mar 27, 2009 | RIM BlackBerry Curve 8310 Smartphone
RIM BlackBerry Curve 8310 Smartphone Logo
83 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
