Question about ViewSonic VX2235wm LCD Monitor
Extremely Dim/Dark ViewSonic Monitor
I have this 22" Widescreen ViewSonic monitor that appeared to have had it's backlight turned down so low you could barely see anything. When I pressed the "1" button to enter the menu, I could just make out the menu box and the highlighted options, everything else such as the text and even the webpage I had up were so dark I could barely see them or nothing at all depending on the angle of the montor sat at. (i.e. Much like how a Laptop screen looks with a bad Inverter Board)
Then, when I switched between monitors to look at a user manual and plugged the ViewSonic monitor back into the computer (I did this about two or three times), the screen on the ViewSonic was back to normal.
I left it on all night last night and it was still fine. Problem seemingly solved, but what would cause the monitor to become so dark?
  • andersoncory Nov 13, 2009
    Looks like there's something different going on now. The screen seems to flicker every now and then (usually in 20 Second intervals). First I had an extremely dim screen that I didn't know how I fixed, and now there is this flickering.
    Any suggestions on what may be the cause of this?
  • 11,361 Answers
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 14, 2009
Can't see red on monitor
Make sure your video cable is secure. If using VGA cable, check for bent or broken pins. If not, try swapping cables.
Apr 28, 2014 | ViewSonic VX2250WM-LED 22-inch Full HD...
Using my hanspree jm01-22 through vga cable alls fine except lack of brightness on the screen,ive turned the brightness and contrast up on the monitor and its still fairly dark,appreciate any help
It does sound like it had logic issue that seding the dimming command to the backlight inverter circuits to dim down the lamps. Yoy may have to look inside.
Please look here to see what ususlly goes wrong with the monitors: http://s807.photobucket.com/home/budm/allalbums
Mar 31, 2010 | Hannspree 19" Widescreen LCD Flat Panel...
VA1703wb Viewsonic Monitor backlight
The problem can be bad power supply feeding the backlight inverter circuits due to bad caps, or in the inverter circuits, or worst case will be bad lamps, you need to open it up and tell us what you see inside first, good pictures will help, see example of failed VIEWSONIC due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 25, 2010 | ViewSonic VA1703wb Monitor
My hannspree hs257hps monitor keeps going dark after a short period of time. I can turn it off and on and it works for a while but after a few minutes it goes dark again
backlight inverter is loose or bad.. dissasemble and check..shile a light on it while it is dark , but still on ..just like you would with a laptop
Jan 10, 2010 | Hannspree 22" widescreen LCD Flat Panel HD...
Monitor goes dark... can still see the screen faintly, have to turn the monitor on and off to get the picture to " stick"..
ok, we have two options here, either the power inverter that turns on the backlight has stoped working or the backlight itself is not working. in these both situations, the best for you will be to ask to a local technician to replace it for you. but you may want to verify first if it's worth it to repair due to the low prices on lcd monitors nowadays.
Dec 12, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
Monitor flickers or 1/3 turns black, have tried wiggling cable, and moving/tapping monitor, sometime it works great, other times i fight this every few min. Doesn't matter if i turn computer all the way...
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Aug 31, 2009 | ViewSonic VA2226w 22" Widescreen LCD...
Monitor is blinking out
Hi...there,
It's seems you got a busted backlight inverter problems...
Dec 17, 2008 | ViewSonic VX2025wm 20.1" LCD Monitor
Monitor isn't working
just replacing the fuse should help. There are two of them on the inverter board. depending on which one is blown will give you 2 different issues. One will cause the screen to flash content perfectly for two seconds and then drop out. the other will be really dark if can see any picture at all,
Feb 10, 2008 | ViewSonic VX900 19" LCD Monitor
Monitor stays dim
Chances are it's not the actual CFL back-light bulbs themselves, but the back-light inverter board. If it was the bulbs you would have not had the "warm up and it get bright" issue. The board IS replaceable, (as well as the bulbs) ViewSonic charges about $36.00 USD for the board when they have them in stock. (out of stock as of yesterday 11/14/2006) It should be covered under warranty if you got longer than one year. (I know the warranty was only one year on MY VA800 but I have seen longer offered since i got mine) Good Luck I hope this helps! El Duderino
Nov 11, 2006 | ViewSonic VA721 17" LCD Monitor
ViewSonic VX2235wm LCD Monitor Logo
739 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
