Question about Maytag Washing Machines
My maytag neptune front loading washer - WMAH3000AWW just started leaking water which is coming out from the bottom. Any idea what is causing this? It's not coming from the hoses.
  • mareg8tr Nov 13, 2009
    How do you get to the clear hose. I guess what I'm asking is do I need to open the machine up, and if so, how?
  • mareg8tr Nov 14, 2009
    As is turns out, the washer wasn't leaking. The leak was coming from the plumbing inside the wall and was leaking out from under the washer so it looked like the washer was leaking.
    However, I have the matching Maytag Neptune dryer model number (s) 13217709UM and I opened it up because it was making a popping noise. I believe I've fixed that problem, however I cannot figure out how to get the belt back on.
  • 3,741 Answers
Your washer can develop several types of leaks from its bottom . You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make.
you can get the required board and components at ----- www.partselect.com -------- or from ------ www.repairclinic.com ----
if you are not familiar with doing this you can get it done by local washing machine repair technician familiar with this model.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Posted on Nov 13, 2009
  • 6,784 Answers
The water pump recirculates water during the wash cycle and pumps it out for the spin cycle. Some washers use the recirculation to mix and distribute add-ins like bleach or fabric softener. In some models the spin cycle starts while the water is still in the tub; others drain first before the spin cycle starts.
For the the initial filling of the tub, the pump is not involved. Filling the tub is the job of the water inlet valve. The rinse cycle is also done with fresh water supplied by the inlet valve, although the water pump may be running simultaneously to remove the water while it is being added.
There are two types of pumps; direct drive and belt drive. The direct drive is mounted directly to the motor, the belt drive is mounted to the chassis. The direct drive style can be opened for complete inspection while belt drive models may or may not be designed to be opened. You can however, still remove the hoses and inspect the ports for a blockage or loose connections that may be causing a leak. Inspecting the pump is fairly easy to do, but you will most likely have to open the washer's cabinet.
Typically one of three problems occur with the pump. The first is a blockage in the pump, often from small items like a sock. The second possibility is that the impeller blades become broken or worn down and cannot move water efficiently. Next, in belt drive models, if the belt is loose or broken it does not turn the pump. Finally, Your pump may leak if there is a loose hose or cracked pump housing.In this case, it must be replaced.
Locate the pump, it will have two, three or four hoses. Label each hose and where it connects. The hoses should each have a wire clamp or a hose clamp with a screw. Pinch the wire tabs together with pliers and wiggle the clamp farther up the hose. Screw style hose clamps are simply loosened by turning the screw, then slide the clamp up the hose. Now remove the hose from the port.
Direct drive pumps have metal clips that hold the cover plate unto the pump assembly. Use a screwdriver to pry up the clips and remove the cover. Pull off the pump's impeller unit and inspect for damage.
Belt drive pumps vary and may or may not be designed to open for repair. Examine the pump to determine whether it can be opened. If it cannot be opened, look into the ports for any blockage.
If there are no blockages, the actual leak may be in a damaged hose or pump housing may be compromised. check all hoses for good connections and good hose integrity. if the hoses are not leaking, replace the pump.
  • 1 more comment
  • Michael Masters
    Michael Masters Nov 13, 2009
    I have located a service manual that will help you disassemble the cabinet correctly. The section that you will need to pay close attention to will be section 5. This section is for cabinet disassemble, and reassembling steps. Use this section to guide you through the disassembling process. This manual is very precious. I would advise to download it, and print it out for future use. This is a complete repair manual.
    CLICK HERE TO ACCESS YOUR REPAIR MANUAL
  • Michael Masters
    Michael Masters Nov 14, 2009
    Click here to see the belt diagram. Your belt diagram will be on the bottom, left hand side. it will be labeled Maytag.
  • Michael Masters
    Ok, click here for a step by step instructional guide of the belt replacement.
Water leaking out of bottom of maytag Neptune front load washer
Check the door seal gasket for splits or holes
May 15, 2012 | Washing Machines
Leak
You have 3 areas to check. Drain hose, water pump and hot/cold water valves. Any of those 3 areas can be the cause. Most often leaks are caused by loose hoses, but neptunes use a plastic water pump that can clog and lose bearing water seals as well. Try the easy options first, then if those solutions don't point to the cause, remove the front cover and check the water pump for moisture.
Mar 12, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Water is leaking from the bottom of my washer, it is maytag neptune ,front loading washer
Check the door boot (typically grey rubber bellows looking ring around the door opening that keeps the water in the tub from leaking) for cuts.
See the manual:www.applianceblog.com/manuals/MaytagNeptunenew.pdf
Joe
Jun 06, 2009 | Maytag Neptune MAH6500A Front Load Washer
Washer has a water leak coming from the bottom!
usually this is the front seal around the door they do crack with age. you will have to pull the front of the washer off to change it any appliance parts co. should be able to get you one
May 15, 2009 | Maytag Neptune MAH6500A Front Load Washer
My Maytag Neptune leaks water from the bottom (immediately) as it fills with water
usually this is from the front door seal going bad remove the front panel and door to replace it
Apr 30, 2009 | Maytag MAH6700AWW Neptune Front-Load...
We have a Maytag Neptune washer Model # MAH4000 AWW it is leaking from the front at the bottom of door. Water pours out like a water fall when it wants to rinse. Any ideas?
TO ELLIESHIRK, I SEE YOU POSTED YOUR PROBLEM ON MAR. 19, 2009. I HAVE A MATAG NEPTUNE FRONT LOADER WASH MACHINE MODEL #MAH55FLBWW. I AM HAVING THE SAME PROBLEM WITH MY MACHINE LEAKING WATER OUT THE FRONT DOOR. MY WASH MACHINE SEAL LOOKS FINE. IF YOU HAVE FOUND A SOLUTION TO YOUR WASH MACHINE LEAK PROBLEM, PLEASE LET ME KNOW, OK. YOU MAY EMAIL ME AT: CJA931@FRONTIERNET.NET , MY WASH MACINE IS NOT VERY OLD EITHER 4-5 YEARS IM GUESSING, IT WAS LEFT WITH THE HOUSE I PURCHASED. THANK-YOU FOR YOUR HELP AND TIME. CONNIE
Mar 18, 2009 | Maytag Neptune MAH7500A Front Load Washer
Leaking water Maytag Nepture washer MAH400AWW
open door and feel around the rubber bellow possible tear causing leak
Feb 27, 2008 | Maytag MAH6500 Neptune Front Loading...
Maytag neptune mah5500bww leaking water
Here is the solution I found that worked for me, there is a small drain hole at the bottom of the boot that is connected to a drain hose. Remove the hose and clean out to make sure that it has not become plagged. replace hose and reattach boot. Mine stoped leaking imediately.
Feb 22, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
