Question about Samsung SyncMaster 245BW Monitor
Monitor my monitor disply is shivering when it was runninig. I likewise have a "shivering" on mine. Horizontal lines running the full width of the screen about a dozen or more of them dancing up and down. Worse when the monitor's been on for quite a while. They don't show on a white screen (like this page I'm typing on now) but on any other colour are quite obvious. David
    Scholar:
  • 85 Answers
Unquiet,
This issue has do do with your horizontal output chip inside your monitor screen. The Horizontal hold isnt running at 60hz anymore that is why you can see lines, kinda like if you watch tv threw a old black and white video camara. I would suggest looking at getting a new monitor. There isnt alot you can do and the prices on most monitors now days are pretty reasonable.
Posted on Jan 08, 2008
    Scholar:
  • 135 Answers
Try getting anything that may have a magnetic field away from the LCD (speakers, phones, any electronic product), does the problem persist?
  • Yonatan Horan Jan 08, 2008
    Try right clicking on your desktop and clicking on properties. Then, click on Settings -> Advanced -> Monitor tab. What does it say under the "screen refresh rate"? Try changing it to 75Hz or 70Hz if that's an option there.
    If these don't work, then what biomed said is probably true. Although trying to uninstall\reinstall the monitor can never hurt.
    The monitor comes with a three year warranty, so if it hasn't been three years you can call samsung (1-800-SAMSUNG) and have it repaired\replaced by them. You can also request service online at their website here. If it isn't under warranty anymore, you can find a repair center near you here.
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
Width problem
A width issue specially if this is short of width on the screen can be due to many reasons:1. It can be a low +B which means the SMPS power supply has a lower output due to low Switching or a low value on the main capacitor. Check this out, measure the +B on the mains end and also the secondary side which will confirm.2. If the secondary +B is correct the fault can be with the sync circuit IC or the horizontal coil or even a fault with the deflection coil. A proper measurement of the voltage in this section is important.3. Check for weak capacitors and DRY soldering on the horizontal section , line output section.
Dec 15, 2011 | LG Studioworks 700S 17" CRT Monitor
Screen horizondally pulled right side and screen rolled to left side
hi,
your monitors horizontal deflection side have some problem. you have to check the horizontal width cotrolling transistor mounded on the aluminum heatsik near the lot( line output transistor). also check the three mosfets which adjust the width for different resolutions. there are three such mosfets in the horizontal section.
fist of all replace the width controlling transistor in the heat sink. photo of mosfet and transistor is added for reference. not the exact number.
ok
Jan 27, 2011 | AcerView 99C 19" CRT Monitor
Very horizontal faint white lines running down the screen
hi,
check if the line appears in BIOS...dont worry when i say BIOS...not sure how to check...turn the system off...restart the system and keep tapping the F2 key...you would get a Blue screen...check if the lines appear on this screen...if it appears...it could either be b'cause the display driver has gone wrong or the system might have a physical damage.....if the lines does not occur on this screen....it is a manufacturing defect...please contact the manufacturer and report the issue for solution.......
regards
Rocky
Jan 12, 2010 | Acer AL1717 17" LCD Monitor
Monitor disply movable horizontal lines.
yes you first check the supply at vertical ic 12v if present then replace that vertical ic if supply is not present then check the regulator ic in smps if faulty then replace it
Nov 20, 2008 | SAMTRON 55V 15" CRT Monitor
Screen width unadjustable
chk the resolution is as mentioned by the makers in the user mannul.
Jun 16, 2008 | Computers & Internet
Syncmaster 245B Monitor Shivering horizontal lines
Which type of video connector are you using? VGA or DVI?
If you are using VGA, the horizontal line could be due to interference, like from an electric motor (fan) near the video cable.
Other thing to try is to change the refresh rate. In Windows XP: Control panel --> Display Properties --> Settings tab --> Advanced button --> Monitor tab --> Screen refresh rate. The default ot 60Hz for LCD monitors. Bump it up to 75Hz. That could give a clue to the problem or maybe even fix it.
Jan 08, 2008 | Samsung SyncMaster 245BW Monitor
Width of picture increase
Have you checked your display adapter settings? Check the display settings in control panel. Make sure you are viewing the screen at a decent resolution. 800/600 or larger. Let me know what happens. Good Luck, Tim
Feb 14, 2007 | LG Studioworks 563N 15" CRT Monitor
Most likely width control circuit has developed a problem. Most common causes are a failed diode in the yoke return circuit or open capacitor near the flyback.
Sep 23, 2006 | Envision EFT720 17" Flat-Screen CRT...
Samsung SyncMaster 245BW Monitor Logo
204 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
