Question about Cannon Canon i960 Photo Printer
How to I access canon s600 ink pad - Cannon Canon i960 Photo Printer
  • 4,041 Answers
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on s600)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Posted on Feb 16, 2010
My Canon S600 has no longer prints the colours nor black - even the nozzle check does not print. The printer goes through the motions, but the page is always blank. All ink tanks have ink in them. I...
I use to have a Canon with the same issue as yours. Do you refill your own ink tanks? If so, that is the problem because they leak inherently after awhile. If they leak then your print head is probably clogged. Was this a gradual problem or did it occur all at once? That will make a difference in troubleshooting your problem. Another issue with Canon printers is that you have to use them often of the print heads will clog up after a period of time. Take a look at this video as well. It may help you!
Jan 09, 2018 | Canon BJC S600 InkJet Printer
Model is Canon S600. I troubleshooted the problem why it is not printing but it cannot identify the problem. When I try to test print, it was always error printing and the canon S600 icon has an...
it might the catrige ink coagulated better remove it and dip it in mild hot water for some times and replace it wiping the water it might solve your problem.
May 15, 2011 | Canon BJC S600 InkJet Printer
E8 Waste ink absorber full, or platen waste ink absorber full WHAT MUST DO?
I am told that this will reset your counter and eliminate the full absorber warning that you are getting.
Cleaning the pads is messy, sending the printer to Canon is expensive,
I used a simular reset code for my MP470 and haven't had any problems.
1. To clean physical pads:
Open cover (as if replacing ink cartridge).
Locate waste ink pads, they are far right under cartridge slider.
Pry up waste ink pads (inky, might want to wear gloves).
Rinse pads in sink or with alcohol, dry.
Replace pads. Make sure pads are fully seated.
2. To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
Jan 14, 2011 | Canon PIXMA MP190 All-In-One InkJet...
The waste ink absorber is full
Press OK.
Press Copy.
Press OK.
Press Stop/Reset.
Jan 04, 2011 | Canon PIXMA iP90 Mobile Printer
My Printer - Canon Pixma Mp130 says my waste ink absorbers are almost full, what do I do ? How do I fix this problem ? Please help !!!
If this happens, just turn off the printer plug,then hold the reset\stop button,after that you turn on the plug while pressing the stop reset button, then follow these steps:
-Press Menu-Scan-Copy-Scan to enter service menu.
-Use arrow keys to scroll to "Service menu counter access".
-Press OK.
-Use arrow keys to scroll to "ABS-M DOT COUNT"
-Press Copy.
-Use arrow keys to reset count to zero.
-Press OK.
-Press Stop/Reset.
To clean physical pads (optional):
-Open cover (as if replacing ink cartridge).
-Locate waste ink pads, they are far right under cartridge slider.
-Pry up waste ink pads (inky, might want to wear gloves).
-Rinse pads in sink or with alcohol, dry.
-Replace pads. Make sure pads are fully seated.
Dec 09, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Locate waste ink absorber pad
canon pixma ip1000 printer, how do you access and clean waste ink absorber pad
Apr 13, 2010 | Office Equipment & Supplies
Is the Canon S600 printer compatibl with Windows 7?
Have you tried to connect the printer?
If so, did Windows 7 recognize it, and load the correct device-drivers?
If not, access the manufacturer's web-site:
http://www.usa.canon.com/opd/controller?act=OPDSupportWindows7Act
Select "Printers".
Select "S" series.
Is your printer listed among those that are supported by Windows 7?
Nov 19, 2009 | Canon BJC S600 InkJet Printer
How do you gain access to the "used ink tank" on the Canon i560?
Well Fay after much research, the best answers I've seen actually came from other experts on this website. The link below will take you to another Fixya page with several, very good solutions to the same problem you have. My personal favorite was soaking up waste ink from the pad with kleenex or some other absorbent material as you won't need to take apart your machine. You merely remove the ink cartridges and carriage to gain access to the pad/sponge that Canon calls it's waste tank. I do wish you well and hope you come back to let me know if you were able to fix your machine.
Greg
Fixya Waste Tank Solution for Canon Printers
Nov 08, 2009 | Canon BubbleJet i560 InkJet Printer
Canon i950 will not reset counter for waste tank full.....
For Canon i850, i950, S600
2. release RESUME
3. press RESUME twice, then release POWER
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
Jun 04, 2008 | Canon I990 InkJet Photo Printer
Ink waste absorber is full, what do i do!!!
Use arrow keys to scroll to “Service menu counter access”.
Press OK.
Use arrow keys to scroll to “ABS-M DOT COUNT”
Press Copy.
Press OK.
Press Stop/Reset.
Mar 15, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Cannon Canon i960 Photo Printer Logo
122 people viewed this question
Top Cannon Office Equipment & Supplies Experts
Iqbal Husain
Iqbal Husain
Victorman
Victorman
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
