Question about M&S Systems Local Audio Input Module - Xtreme Digital Music System Shelf System
I have a M&S speaker/intercom system in my home and all the sudden it has stopped working. It will not even turn on. What could the problem be?
  • dlow80758 Nov 13, 2009
    I have a M&S speaker/intercom system throughout my home and all the sudden it wont turn on now.
  • dlow80758 Nov 16, 2009
    So who can I call to come out and look at it? I have no idea about electronics.
  • 2,359 Answers
Your M&S system draws its power from
1)remote power transformer
RT11 24 volt AC
RT35 24 volt AC
TE2D 24 volt AC
TE5D 16 volt AC /dual port (must likely power pack for your system)
or
2)alarm panel (if you has an existing alarm system in your home).
PLEASE OBSERVE ELECTRICAL SAFETY PRECAUTION
Check the power outlet and circuit to the M&S power supply.
Check the output of the power pack(s) // see AC voltage listed next to the model.
In order to pinpoint the problem,can you list few components you has in your home.
Here's a link to M&S
Please post the model on the comment window.
Posted on Nov 16, 2009
  • Vincent_G
    Vincent_G Nov 17, 2009
    Just check for power to the power supply.
    Check the M&S link
    The power supply pictures are listed toward the bottom of the page.
    In the last few day,I saw ZIP CODE popping up on the POSTING BOX.
    Double check your posting setting allow ZIP CODE to be displayed.
    I'm sure Fixya is working hard on matching qualify local trouble-shoot.
  • 3,741 Answers
There is a power button located on the unit.check out if that power button is properly pressed and not got stuck up.and also check out if that power button is not got damaged/loose.if it is then the power button internal connection to the units circuit board is the problem .the power button circuit connection internally needs soldering. but if the power button is properly seated and nothing looks improper there.then its the problem of power circuit board got short/faulty in the unit.that board needs to be checked then replaced or repaired.most probably there is fuse on the power board that goes short so the power does not comes on.and the fuse is not much costly.still the board needs to be checked if the fuse is not blown any other component is faulty on the board.the unit needs to be disassemble to reach the circuit board and then the board needs to be checked with multimeter and continuity tester to locate the faulty component on the main board.
you can get the required board and components at ----- www.radioshack.com ----
if you are not familiar with doing this you can get it done by local electronics repair technician familiar with this model.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Nov 13, 2009
  • charlymonty Nov 16, 2009
    the power board of the unit is in fault.that needs to be checked.you can call the technician and ask him to get the circuit board checked in the unit.he will check out for any short circuit in the board and the faulty components in the board.that will need replacement.
    thanks.
  • 4,924 Answers
If there is no power at all it a matter of a final fuse ( fusible cut -out ) ...probably a juice shock did that ...anyway ..where there do not even turn on ...its about the power...either the power transformer ...or the safety fuse..
Radio Problem?
First you need to know if you DO even have a factory preminum system.
Mar 10, 2014 | 2008 Jeep Commander 3.7
M&S DMC1 System- When I turn the power on it music does not play on the main station but does on the door stations. It only gives a humming sound.
Well it's not mainly the radio problem the problem occurs due to bad signals, anyway you can try a bigger antenna.
please check the below link for more information.......
http://webhome.idirect.com/~griffith/tdoa.htm
Good Luck!!
Thanks
Dec 24, 2009 | M&S Systems M & S SYSTEMS DMC1CDB Whole...
Casdasd
Replace amp ics. Check for any dc voltage on speaker terminals. replace ic that correcsponds to that channel. These are PWM amps.
Nov 21, 2009 | Samsung HT-SK5 System
"Push Power'' and ''Protector"
my sony bravia is KLV-32S400A. i tried to stop the dvd playing and turn off the home theatre, but the tv is still on. suddenly there was a loud blast sound and the home theatre shows PUSH POWER PROTECTOR.
please help what should i do with it?
May 13, 2009 | Sony DAV-HDX500 System
Subwoofer Speakers wont work
the speaker may have blown.
to test it look inside is there any tears in the fabric part of the speaker?
is there any loose or disconnected wires?
if thats not the case the speaker still may have blown out look on ebay for a new one
Apr 21, 2009 | Logitech X-530 Computer Speakers
Active sub has stopped working
I have 2 12" kenwood speakers on a 1000 watt amp ... the other day they cut off but the speakers arent blown, i replaced every fuse in the amp and the amp still cuts on when i turn the car on, yet the amp seems to not be pushing the speakers ...i also looked at the main fuse under the hood of my car but i cant tell whether its blown or not, why is my amp not pushing out any power?
Mar 31, 2009 | Audio Players & Recorders
Intercom pages coming through phone speakers HELP!
Try 325. Not sure if your system admin necessarily wants this feature turned off though. In my case we don't have an overhead speaker for dedicated paging so we programmed all handsets to page through the phone speakers. Your system admin probably has your phone in a page zone if the 325 shortcut works so you might want to ask before your turn it off.
j
Dec 13, 2008 | Inter-Tel Axxess Corded Phone
Logitech Z-680
You need a 2 Amp Slow Blow fuse. 250V. Available from eBay
Aug 01, 2007 | Logitech Z-680 Speakers and DVD218 System
M&S Systems Local Audio Input Module - Xtreme Digital Music System Shelf System Logo
332 people viewed this question
Top M&S Systems Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Tre Elkins
Are you a M&S Systems Audio Player and Recorder Expert? Answer questions, earn points and help others
