Question about Indesit W 123 Front Load Washer
When machine is switched on, the programme clicks round and round and the machine does nothing
    Genius:
  • Indesit Master
  • 1,460 Answers
You may need to reset this put to . positon then switch on machine light flashes several times then pulses..it is now reset should now fill and start motor providing motor is working okay...Brushes not worn....
Posted on Nov 13, 2009
Ariston Washer not running Programme
It sounds as if the brushes in the motor have worn,when the motor stops it wont go through the program,try turning the ddial around to spin to check the motor
Mar 07, 2014 | Washing Machines
W83t, programme selector knob keeps clicking over clockwise. is it just a faulty switch?
No it is not a faulty switch, it is the selector switch going round because of another fault on the washer, it is usually associated with a faulty control module.
Check your handbook and see if there nis a reset point on the selector switch dial, usually marked with one or more solid black dots.
Hope this helps.
Feb 02, 2010 | Indesit W 83
Ariston A 1635 Margherita washing machine, programme switch keeps clicking
Try Cleaning your filter under the front of the washer it probably has coins and other wonderfull stuff which can cause the clicking issue.
Regards Ed
Jul 06, 2008 | Ariston Technologies AW149NA Washer
My indesit washer/dryer model w10 ,is not working.the programme dial keeps cliking round wont start a programme or take in water.
probably a main module fault but worth while checking for continuity thro the heater and that the pump and filter are ok. the idea is that when a fault is detected, the dial will click round indicating a fault but usually it is the module itself. expensive part. not worth repair
Jul 04, 2008 | Indesit Washing Machines
Programme dial again
yes thats your problem,the reason it wont unscrew is because of things caught inside ie coins gunk you will have to take out machine turn on side,there are two sometime four screws at front of machine where black dail is remove these,when machine is on its side you can acess pump from underneath,there is a black rubber hose which goes from drum to pump which is held on with a circlip remove this at pump end you will need a vicegrip,remove all gunk coins ect, refit all back to machine ,,problem solved......the reason dail was turning was because it was looking for progam to release water which it couldnt because of blockage,after tou unblock you will find that black srew on cover on front can be removed(always better to check for blockages every few weeks hopes this helps
Dec 18, 2007 | Hotpoint BWM12 Front Load Washer
Timer just spins round
yes it is the timer,i had the same thing happened to me on a hoover,i was told that the fault was when you turn the timer to a programme to do this slowly and gently and if you go pass a programme not to turn it back but to go forward again until you get to the right programme..hope this helps.all the best..ps a new timer may cost about £80 to £100.
Nov 19, 2007 | Hoover PE235 Front Load Washer
Machine not starting at all.
the white box you refer to contains the main module which drives the whole issue. with no start, this module is probably faulty and is an expensive part
Jun 17, 2007 | Hotpoint BWM20 Front Load Washer
Indesit W 123 Front Load Washer Logo
176 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
