Question about Standard Oregon Chainsaw Chain For Mcculloch Chainsaw 18" Bar Length 64 Drive Links 3/8 0.05 Gauge Chiesel Chain
I need to know what fuel to put in - Standard Oregon Chainsaw Chain For Mcculloch Chainsaw 18" Bar Length 64 Drive Links 3/8 0.05 Gauge Chiesel Chain
    Sergeant:
  • 399 Answers
Its either 2stroke or standard petrol
Posted on Nov 13, 2009
How would I drain the fuel from my RunX?
you can by a piece off transparent tube.put the car hight off the ground,take a barrel.stick the tube in filling hole.off the car .suck on it till you see it ,almost on your mouth.then put the tube in the barrel it chould flow on its own.
May 05, 2014 | 2005 Toyota RunX 160i
Does a chevy cavalier 2.0 fuel pump put out same pressure as 1998 dodge neon 2.0 dohc?
if its a racing fuel pump than it will have more BUT that will do you no good if you dont have racing fuel injectors, fuel rail, bigger intake manifold, bigger throtle body, and your mapping tuned in with a flashable pcm$$$$$$$$$$$$. stock fuel programing will let it run stock no matter how much pressor your fuel pump puts out. fuel injectors are solenoids that the pcm opens and closes they dont stay open. BUT IT WILL WORK
Mar 16, 2012 | Dodge Cars & Trucks
Will not start -changed plugs bike has been on battery tnder all winter added dry gas battery seem fine but still will not start.don't know what to do next.
Your fuel will go stale after a month or so.
You need to drain your tank and put fresh fuel in.
Also put some seafoam (if in US) or forte fuel conditioner in tank as old fuel coats the inside of fuel system and can cause it to stick.
let me know how you get on.
Please dont forget to vote this answer was helpful
Many thanks
Feb 17, 2011 | 2003 Suzuki VL 800 Volusia
94 4DR CHEVY TRUCK BLAZER S-10 4.3L V6 ENGINE NEED TO KNOW THE RIGHT MODEL/NAME OF GAS PUMP MY TRUCK USES PLEASE ! ? !
when ordering fuel pump, need to know the vin letter w or z. one is for a carb and the other is for a injection or vortec engine. one puts out 11psi and the other puts out 60psi. is this an in tank fuel pump?
Nov 12, 2010 | 1994 Chevrolet S-10 Blazer
Has began cutting off in midmotion. Have put fuel
if it were the fuel filter you would feel the engine starving for fuel. If it just cuts out its not a filter. Its most likely a fuel pump or one of three ignition parts. Only testing will reveal the faulty prt unles you just want to throw parts at this.
Jul 21, 2010 | 1994 Nissan Altima
Fuel line is bad and needs replaced. need to know
  • One line should be hooked to a small fuel filter or screen.
  • The other one is a dump or over flow that will put a small amount of unused fuel back into the tank.
  • You can buy this type of line at most Lawn Mower shops as a kit. 2 lines and a filer/screen.
  • You can use line for air shocks that fit some cars ie. Cadillac's
May 30, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I need to know if I need to mix the gas for my Yamaha 2002 Banshee 350 Twin or if I can just put in straight gas
Normally these days on 2 stroke engines you put fuel into the tank directly and then you should also have a reservoir for your oil mix on the LH side cover. The system will mix the required fuel to oil mix themselves. Good enough?
May 21, 2010 | Motorcycles
Fuel pump
hi the only reason you would need to replace your fuel pump is if it is not producing enough fuel preasure to run your engine.
Jan 29, 2009 | 1986 Volkswagen Jetta
How to put a fuel filter on
All you have to do is remove the gas cap and go under the hood and use a small screwdriver and press the schrader valve. The schrader valve looks like a tire valve on top of the intake on the fuel rail.
Jun 21, 2008 | 1995 Chevrolet Blazer
Standard Oregon Chainsaw Chain For Mcculloch Chainsaw 18" Bar Length 64 Drive Links 3/8  0.05 Gauge Chiesel Chain Logo
134 people viewed this question
Top Standard Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Standard Measuring Tool and Sensor Expert? Answer questions, earn points and help others
