Question about Electrolux EOB5600 Ultrafan Electric Single Oven
I have a brand new electric oven. When I switched it on there was a very strong smell of burning and when I opened the door alot of what appeared to be fumes came out, is this normal when an oven is new?
  • 15,935 Answers
Yes - there is a chemical put on the elements to keep them from corroding and appearing new until first used.
The smoke will go away after the first bake.
It is non-toxic.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Nov 13, 2009
How do I replace the door jamb switch on a GE Profile oven?
should be able accsses it by removing side panel on oven may also find the wires and terminals burnt on the switch
Nov 13, 2013 | GE Ovens
EW30EW65SS Stainless Steel smells like burning electrical
Hello purrpplee - If the smell is coming out of the oven vent, more than likely it is something inside the oven that is creating the odor. Also, keep in mind that new cooking products can create a burning electrical odor when the bake and broil cycles are used as any residual coating or film on the oven liner and elements burns off. However, if odor increases consult a professional for an accurate diagnosis.
Jan 31, 2013 | Electrolux EW30EW65SS Stainless Steel...
I used the oven at 425C for about 30 minutes, turned it off, took the food out, left the door open (the fan and light was on. During dinner, we smelled a strong chemical smell, like melting plastic or hot...
your mostlikley correct on the buring wires. The only thing that can be done at this point is to unplug the machine and start tearing in to it to find the bad wires.
Jan 08, 2010 | Whirlpool RBS275PD Electric Single Oven
I have fitted a new element to my creda fan oven but when i put the oven on it smelled of burning is this normal
You can expect it to smell for a while, as it is a protective coating on the element.
Run it at a high temp for a few minutes with the door open if possible, this should get rid of the smell.
Hope this helps.
Dec 15, 2009 | Ovens
Beeping driving me crazy
Ok, the first issue is the oven temp sensor. it is shorted. you will need to replace this device asap. Now, the second is is concerning the Self clean latch. it is not functioning and it is unable to be locked by the control(shorted). Use the procedure below to test this device.
1. If door latched:
1. Disconnect power from unit.
2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
3. Replace door switch.
4. Re-apply power.
5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
May 29, 2009 | Whirlpool RBD305PR Electric Double Oven
Microwave emits a burning smell when on
there is a transformer dont use it and get it serviced
Dec 28, 2007 | KitchenAid KEHC379JSS Electric Double Oven
Electric oven model 790.47892601
F7-E1 - Common Switch Wire Is Defective - This error occurs when common wire to latch switch and door switch is shorted.
Check all connections at control board and at the latch switch and door switch.
If connections are ok, then check individual switches as outlined for the F5 error code.
Oct 28, 2007 | Kenmore 47834 / 47832 / 47839 Electric...
Electrolux EOB5600 Ultrafan Electric Single Oven Logo
223 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
