My lan drivers for win7 - Intel quad CPU Q400 are
My lan drivers for win7 - Intel quad CPU Q8400 are not being installed, plz help me
    Problem Solver:
  • 5 Answers
If your NIC is built into your motherboard, it most likely is, you'll need to visit the manufacturer's website to download the drivers.
Posted on Nov 13, 2009
Needupgrading my cpu
ztz198,
On the top of every Intel processor is the sSpec Number, and the part number.
Intel Core2 Quad, that operates at a maximum frequency rate ('Speed'), of 2.66GigaHertz,.........hmmm,
Gateway Support indicates if the option is a Core2 Quad core, it will use Up To a 1333MegaHertz, Front Side Bus frequency rate, ('Speed'),
[1333MHz FSB]
http://support.gateway.com/s/desktop/2009/gateway/dx/dx4822/DX4822sp2.shtml
That 'narrows' it down to about 6 different processors.
Starting with the Yorkfield-6M Core technology, based on the 45NanoMeter architecture. (45nm),
http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#.22Yorkfield-6M.22_.2845_nm.29
1) Core2 Quad Q8400
2) Core2 Quad Q8400S
3) Core2 Quad Q9400
4) Core2 Quad Q9400S
Then on to the Yorkfield Core technology, based on the 45nm architecture,
http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#Yorkfield_.2845_nm.29
5) Core2 Quad Q9450
6) Core2 Quad Q9450S
The maximum frequency rate of 2.66GHz, is actually a low estimate. It is a little higher, and rounded off to 2.67GHz.
BIOS Setup might state 2.66GHz, but a better program like CPU-Z, IMHO; will state 2.67GHz. A more realistic figure.
Does it REALLY matter? Yes, and No.
This way when you get into a conversation, with fellow minded computer geeks, you will stand out as one who knows; what hardware components he/she is using.
Also helps you determine what voltage range is being used.
What Instruction Sets are being used.
What technology is being used, and use it to know if the upgrade CPU will indeed work.
Also whether a BIOS upgrade is needed.
I'm guessing it is the Intel Core2 Quad Q8400.
How?
I cheated, lol!,
http://www.newegg.com/Product/Product.aspx?Item=N82E16883113110
Intel Core2 Quad Extreme at a maximum frequency rate of 2.93GHz?
That would be the Intel Core2 Quad Extreme QX6300,
Based on the Kentsfield XE technology, and 65nm architecture.
Uses a 1066MHz FSB.
Motherboard chipset is the Intel G43,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Core_2_chipsets
(Scroll down. Is not in 'alphabetical order'. It is past the P45, and G41 )
Yep. Should work.
Makes me wonder though, about how you addressed the Thermal Paste; situation.
The old Thermal Paste MUST be THOROUGHLY cleaned off, and fresh, new Thermal Paste PROPERLY applied.
CANNOT reuse old Thermal Paste.
CANNOT reuse a Thermal Pad, IF used.
http://www.hardwaresecrets.com/article/274
Do I also assume the inside of the computer case is spotlessly clean, to include the Heatsink sitting on the CPU; and the cooling fan for it?
Heatsink was sit on CPU flat?
Cannot be even a little tilted.
For this reason I remove the motherboard, and install Heatsink.
Then I can hold the motherboard at eye level, and look across.
If a tiny crack of light shows on one side edge, of the Heatsink; then the Heatsink is NOT sitting flat.
This = No.
Four screws with springs on them, hold the Heatsink to CPU, Joe?
Yes. I know. This is so you cannot over-tighten the Heatsink to CPU.
You CAN however keep tightening, until the motherboard breaks, though. (Jus sayin')
However, if the screws are not tightened in a crisscross fashion, and tightened in incremental stages; the Heatsink may not be sitting flat.
Will await reply before going further. Post back in a Comment.
Regards,
joecoolvette
Note* Using capital letters for an entire word, is not 'shouting' from me.
It is to emphasize.
Mar 24, 2013 | Gateway DX482203 (PTGA002009) PC Desktop
Hi I just bought a Intel Core 2 Quad q8400 for my gigabyte GA-G31M-S2L. It won't boot up!!! It freezes when I try to enter bios setup and if I do manage to get in, it freezes at the options screen. It...
What size power supply are you running? If you are not running a minimum of 400watt , I would anticipate issues with this type of processor. Since it is freezing right away, it could be bad memory. You can try memtest86.com to download a memory test tool to verify.
Secondly, you may want to reset the board by moving the jumper from normal mode to reset mode.
last thing, it's not impossible for a processor to be bad. Since it is an Intel processor; it should have a 3 year warranty on it. Any dealer who sells Intel should be able to warranty replace it for you.
Dec 31, 2010 | Intel Core 2 Quad Q8400 Computer System...
I want lan driver
Please click the link below and Run Intel® driver update utility. It would suggest you for a download.
After doing this if you still have the problem then kindly get back to us.
http://downloadcenter.intel.com/Default.aspx?lang=eng
Dec 20, 2010 | Intel Core 2 Quad Q8400 Computer System...
I have intel(r) pentium(r) dual cpu e2180 @ 2.00ghz 2.00ghz on mercury mainboard i have cd of mercury main board but drivers can not installed by that cd.so i find drivers as sound and lan drivers on net...
search with the motherboard name and model in google... you will find the drivers.. or go to the original site of mercury for driver download for your model.....
Oct 20, 2010 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
Lan drivers & draphic drivers are not installing. Im using win7
There are no drivers available or needed for this board under Win7.
Optionally you may use this tool (http://www.intel.com/support/motherboards/desktop/detect.htm) to detect any drivers you may be missing. Your biggest problem may be that Win7 hasn't detected your Lan card and update isn't possible. If this is the case try installing a USB Wifi Card and doing the update. Win7 will automatically find the drivers and install them for you with update.
Mar 07, 2010 | Intel D845GVSR Motherboard
Can i upgrade a dell vostro 200 computer to a q8400 cpu
unforntuately, these are the only type of processors that the vostro motherboard supports
Intel® Core2 Duo processor
Intel® Pentium® Dual-Core processor
Intel® Celeron® processor
the one that you were asking to use is not compatible since it's a Quad processor.
Oct 10, 2009 | Foxconn Computers & Internet
New CPU, No display
in my view, ur motherboard doesn't support the new processor, so plz check the capability of your motherboard, and replace with the supported cPU. ok byee
May 16, 2009 | Intel Core 2 Quad Q9550 2.83GHz Processor
Network adapter
if you have the driver cd means insert it and install the LAN component....it will show you the network adapter......
is this cleared your problem?
Apr 09, 2009 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
Computers & Internet Logo
148 people viewed this question
David Payne
David Payne
