Question about Ovens
I have a ' Firenzi ' electric oven which has ceased to function after a recent power cut. The word ' STOP ' appears on the display. Can you help? Regards Norman Dayton
  • 6,784 Answers
HI. This will occur when a surge has entered the unit, due to the power outage. Normally, there will be a power surge when the power is re-introduced to the home circuits after a brief outage. This will damage most unprotected electronics in this situation. The most vulnerable area in the unit will be the main control board. I would advise to try a hard rest. You can initiate this by simply shutting down the appropriate circuit breaker, or unplugging the unit for 5 minutes. Once the 5 minutes have passed, kindly re- introduce power to the unit, and try to run a baking cycle. If the word stop, or PF illuminates on the display, this will confirm that the surge has damaged the board. It must be replaced, in this case.
Posted on Nov 13, 2009
F1 code after installing oven, cut power to unit for 30 min. then F7 code displayed. What do they mean? This is a model SC302ZS Thank you for your help.
F1 means internal logic failure; control needs to be replaced
F7 means function key shorted (touch pad).
Hope that helps.
May 20, 2011 | Thermador SC302T Electric Double Oven
I Have a firenzi oven, the electric went off ,
I have exactly the same problem. I found out that you could hold button 2 down while turning power on, but this didn't work for me... var viewReq = new Array();function vu(u) {var i=new Image();i.src=u.replace("&","&");viewReq.push(i);} vu("http://googleads.g.doubleclick.net/pagead/adview?ai\x3dBQHenXgRHTarfAc6m8AO8mtSYDM-1tesBl4qClxel7-_HBAAQARgBIAA4AVCAx-HEBGC7vq6D0AqCARdjYS1wdWItMzM4NDk0NjI4NTM1MTk1NqABx5L46gOyAQ13d3cuZml4eWEuY29tugEKMzAweDI1MF9hc8gBCdoBSGh0dHA6Ly93d3cuZml4eWEuY29tL3N1cHBvcnQvdDM2NzY3OTAtZmlyZW56aV9vdmVuX2VsZWN0cmljX3dlbnRfb2ZmX3JfbpgC1AepAp9IXDEvwbo-wAIByAKxu74N4AIA6gIkNjE1My9maXguaG9tZWdhcmRlbi9tYWpvcl9hcHBsaWFuY2VzqAMB6AONCugDjwL1AwAAAATgBAE\x26sigh\x3dKqwNoW_2lVE") body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(/wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; }
Dec 20, 2009 | Ovens
Led display has ceased to show temperature, etc, but oven still functions by guesswork...not satisfactory!
Did you get an answer to this because we have the same problem. We had it fixed by NEFF a few years back and cost £100 - we are now being quoted even more
Nov 21, 2009 | Neff B1644 Electric Single Oven
Thermador SC302T clicking noise, locked door after power outage
iodine, open the upper oven, look thru the grill below the control panel on the right side and there is your model number. The issue here is that when the power came back on the oven run thru a test and your lower lock motor has failed. It will need to be replaced. Yes the only way to stop this is to shut off the breaker.
Feb 03, 2008 | Thermador SC302T Electric Double Oven
Power outage issue
You unit is stuck in the "Display Model Mode". Hold the stop/clear button for at lest five seconds in insure the interlock activates. If it does not activate then the electronic range control (erc) is not functioning. Replace the erc (Clock/Display.)
Jan 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
No indication on display module - apparant loss of power
Did you check the power cord.
Connection(s) could have been fried during power surge.
Dec 27, 2007 | Ovens
Whirlpool electric oven
hi switch main power off at wall. hold middle clock button in and switch power back on at the wall. Display should show --:-- and oven should work.
Nov 30, 2007 | Ovens
B3101 AEG oven cuts out after approx. 15 minutes - why?
this is probably the thermal cut-out causing the problem. not sure where it is located but possibly on the roof of the oven or in the rear casing near the fan. however, the cause may be lack of ventilation to the unit as a whole
Nov 21, 2006 | AEG B3101-4 Electric Single Oven
Ovens Logo
575 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
