Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Panasonic PT-53TW53G coverage wont move the blue color? I DON'T KNOW THE PROBLEM. I JUST REPLACE THE IC'S. pLEASE HELP
  • Panasonic Master
  • 8,617 Answers
Did you check the six 2.2 ohm 2watt resistors? Usually your model will have at least one blown when the ICs fail
Posted on Nov 15, 2009
PT-47WX53G. TV got moved. Unable to move blue
The convergence ICs have failed which is very common when the set has been moved as a wek IC wont allow the color to be moved. You can get the PT52WX53G convergence repair kit from www.tvrepairworld.com which is the correct one for your model. The kit contains the parts and the CD with repair instructions.
Apr 10, 2010 | Panasonic PT-53TW53 53" Rear Projection...
My panasonic TV Model: pt 53tw53g turns off by it self
My Panasonic has exactly the same problem. The repair man just came in and said that the convergence and resistor burned under heat and have to be replaced. Will cost $400.
May 13, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53TW53G 1 Blinking red light, will not stay on.
just got back today for same problem. convergence went out. took to repair shop. $200 part plus $60 labor. second time in a year convergence went out. was told it will happen again.
Mar 19, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Blue convergence problem
you lhave a problem with the convergence IC that control the blue but for the description you made it seems you have no even a slight idea about electronics then my best recomendation is do not mess with it & get some body that does it for you because trying to save some bucks may be costly if you make a mistake think about it
Jan 28, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic Pt-53TW53G projection tv
5 Blinks means IC4511 thats located on the DG board which is the small board on the left side in front of the signal board looking in from the rear of the set.
Oct 31, 2008 | Televison & Video
Which IC controls the blue convergence
Usually the second IC controls blue example if the two ICs are IC6001 and the other is IC602. 602 would usually control blue the first IC will almost always control red.
Apr 04, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Convergence
i would take the board out and have ptscorp.com test it.
Feb 19, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53TW53G CONVERGENCY GUNS NOT POWERING
There are feeder resisitors that can go when the STKs (ICs) go bad. They might be bad as well. Also check to ensure you have all cables properly connected.
Jun 04, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-47wx49 47in
One of the resistors in the circuit connected to one of the ic's has burned out or changed value due to heat caused by short in previous ic before it was changed.
Mar 06, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Skt IC and Capicitor??
You need to replace both STKs. They are pretty obvious to find in the unit. They are normally mounted to the same heat sink and will typically be about 3 inches long each, maybe 2 or so high...Front should read something like STK350-120
Feb 07, 2007 | Panasonic PT-61HX40 61" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
70 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
