Hello, I have a problem with my TV , for about a year now after I turn the set on after about 10 sec it turns off the picture and sound . its almost like it goes into stand bye if I change the channel two times it will come back on and not do it again the rest of the time. but resently it does it 3 or 4 times now the first hour or so. I need to know what is causing it or should I just get a new set . It works fine other than that.
  • k_reetz Nov 13, 2009
    hello.
    the brand is a magnavox , model# MS3250 C321
  • 10,594 Answers
Two possibilites for these symptoms in TV, either lose solder connections on main board or weak/ leaky electrolytic capacitors in power supply or main board.
Let me know brand and model number of TV to find out more helpful info.
Thanks.
Posted on Nov 13, 2009
  • Shahid Electronics
    Shahid Electronics Nov 13, 2009
    hello.
    OK, its 32" CRT TV and I think 4 years old. Please check dry/ cold solder joints in main board, specially in deflection and power supply area.
    Resolder all dry/ cold solder joints found on main board.
    Thanks.
Picture takes 10-15 sec to come on after setting all night. Sound is OK.
If this has been taking longer to come up over time, it is likely the picture tube at fault. Time to look into a new set.
Jun 25, 2014 | Mitsubishi CS-40503 TV
I have a philips flatscreen (32PF5331 / 12) that I bought it around 3 years ago. Everytime I turn on the TV, I only get the sound then I should turn the TV on and off (sometimes 5-10 times) before I...
Hello, not positive what part you need...but it sounds like maybe the main board needs replacing. I have purchased parts many times from a company named ShopJimmy.com. I included a link to the part from their site for your model. Hope that helps!
TeeVeeMan2@gmail.com
http://www.shopjimmy.com/catalogsearch/result/?q=32PF5331
Aug 25, 2011 | Philips Televison & Video
I have a sony Vega 55" kdf-e55a20, It is 3 years old, and now the picture and sound fade away for 10-15 sec every hour or so and comes back! Anyone knows what the problem is?
Lamp is getting weak and TV shuts off and turns on itself because of weak lamp in TV that you see picture and sound fades away for some time until TV reboots.
Replace lamp in TV to solve this issue. Lamp replacement procedure is written in user manual and its an easy work.
Please buy Sony original lamp for your Tv safety.
Thanks.
Dec 23, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
JVC 42 inch LCD HD TV has no picture or sound
utencilio posted this fix. It worked for my JVC LT-42X579.
Okay, I found a fix! Called JVC, spoke to somebody there, here it is:
1)unplug the TV completely, no wall no power strips, completely
2)wait 10 sec
3)plug TV back in and Turn it on, the light will still be doing the same thing
4)wait 30 sec
5)ON THE TV, not the remote, locate the menu, volume (-) and power button.
6)while simultaneously holding down the menu and volume (-) button, pressed the power button ONCE and continue to hold the other 2 for 10 sec.
7)on the remote control, go to menu>settings>system info
*** now this I know as a FACT will work on systems that display: JVC - ver.5.32FO001, but I don't know of any other versions***
8)press the mute button on the remote twice
9)unplugg TV again and wait 10 sec.
10) plug TV in and turn on
It SHOULD be working normally now... Thanx to the guys a JVC support for this one, I know it seems like an obvious first place to look, but sometimes it isn't. I for one checked online forums first
Jan 28, 2009 | JVC LT-42X579 42 in. LCD TV
My Sony tv CRT
If it's between 5-10 secs, that's normal. You will turn the tv on and hear a loud (buzz/hum) that is the picture tube firing up, once it's fired up, it has a few more seconds until your picture comes up fully. That is about 5-10 secs from pushing the power button.
If it's taking longer than that, your picture tube may be going out.
I had a 36XBR250 and it took about 10 secs to fire up and show a picture, and it was 5 1/2 years old.
Nov 25, 2007 | Televison & Video
Blinking Stand By/Timer LED
You can try this on the remote in standby mode, meaning tv plugged in but set off. Press Display,5,vol+,power on remote.Press each button within a 1 sec interv. Next the CRT display the item being adjusted. Press 1or4 on remote to select item. 3or6 to change the data. Press Muting then Enter to write into memory. Service Reset muting green enter red. Press 8 then enter on remote to initialize. turn set off to exit. wait least 10 sec. before turning back on.
Sep 10, 2007 | Sony KV-32V40 32" TV
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
