Question about Brother IntelliFax-2820 Laser Fax
Where is the drum and how do I clean it? - Brother IntelliFax-2820 Laser Fax
  • 105 Answers
The toner cart sits in the drum unit thers is a blue tab that you run across the wire a few times then lock it in the home position
Posted on Nov 16, 2009
Model ar5516. Why is drum not cleaning?
Sir,
Did you prime the cleaning blade with toner when you installed it?, and did you ensure the new cleaning blade did not flip!!!!, re-check the new installed cleaning blade, place a small amount of toner from the toner bottle on the drum along the whole drum. and using your hands at both end of the drum DO NOT TOUCH THE DRUM" turn just a 1/4" CCW (To ensure the cleaning blade is set) then CW to see if the toner is removed. your drum might need to be replaced and or the fuser unit have a example of the copy?
Dec 28, 2015 | Sharp Office Equipment & Supplies
Change drum kit
Remove the old drum unit,remove the drum and the drum cleaning blade,clean the charge corona wire and grid,install the new drum and drum cleaning blade,clean the image transfer /separator corona wire,clean the optical parts(mirrors ,lens,glass)clean the AIDC sensoe located under OPC drum,reinstall the drum unit in the copier,enter in the technical Rep mode,place 5 sheets A3 paper on the original glass and perform F5 AIDC sensor(Auto image density control).
Mar 19, 2013 | Minolta EP4000/5000 CS/PRO Copier
Streak in the middle of the copie/print with drum and blade replaced
Please clean the drum charge roller use the izopropilalcool,clean the charge roller cleaning roller,clean use the vacuum cleaner the waste toner (located under transfer assembly 6 screw),activate the ATDC and AIDC sensor configuration.
Jan 08, 2012 | Ricoh Aficio 1035 Copier
How do you clean the drum
Hi
Just open your drum and take the tissue and clean the drum and roll the remove the black cartridge powder to drum clean the put again... this is very simple way to clean the drum...otherwise u have to chose the HP service center also.
May 13, 2011 | HP CP3525N Color LaserJet Printer
How can I clean the drum in my Muratec copy machine versus purchasing one if I can clean it?
Hi when you say clean the drum the drum is cleaned by the drum cleaning blade if the blade is no good then the drum will not be cleaned if you want to clean the drum you canuse a very soft cloth lint free to clean the drum
it is not really something you clean unless like you got a label stuck on the drum once they reach there life they need to be replaced as you can create a lot more issues with the machine
Feb 07, 2011 | Muratec MFX-1430 Copier
How to replace copier drum Cleaning Blade UCLEZ0069FCZZ
Improper installation may damage the copier. Before disassembly, be sure to disconnect the power cord for safety. 1) Remove the drum cover. (4 Lock Tabs.)
2) Remove the drum fixing plate and the photo conductor drum.
•Dispose the drum fixing plate which was removed.
3) Check the cleaning blade and the red felt for damage.
•If there is damage, go to step 5
•If there is no damage, go to step 12
4) Remove the main charger. (Cleaning the screen grid and the sawteeth.)
5) Remove the cleaning blade.
•Dispose the cleaning blade which was removed.
6) Clean the cleaning section and the waste toner pipe to remove waste toner completely with a vacuum cleaner.
7) Remove the felt and duplex tape completely.
•Be careful not to scratch or bend the sub blade.
8) Attach the cleaning blade.
•Securely insert the plate section of the cleaning blade into the unit and fix it with a screw.
•Do not touch the cleaning blade rubber with your hand.
•When attaching the cleaning blade, press the cleaning blade in the arrow direction and attach.
9) Attach the felt.
•Attach the mocket with slightly pressing section A of the cleaning blade.
•Do not touch the tip of the cleaning blade.
•Do not put the mocket under the cleaning blade.
•Do not put the mocket on the sub blade.
•Do not press the sub blade with the mocket.
10) Attach the main charger.
•Securely set the MC holder on the projection of the process frame.
•Securely insert two projections of the MC holder into the groove in the process frame.
•When attaching the MC holder assembly, be careful not to make contact with the cleaning blade.
11) attach the drum fixing plate and the photoconductor drum. Apply grease to the inside of the photoconductor drum. (Diagram 2)
•Attach the drum from (b). (Prevention against the sub blade edge breakage)
•Attach the drum so that its position with the sub blade shown
12) Attach the detection gear.
•The detection gear is not installed to the drum cartridge package with the main body. Add a new one.
13) Attach the drum cover.
•After attaching the drum cover, do no make a copy
•When attaching the drum cover, engage the detection gear 20T rib with the 30T gear rib, and attach the drum to the process frame.)
14) Important.
•Insure proper drum rotation by rotating the drum counter-clockwise (as viewed from the front)
•If the drum does not rotate with reasonable effort the drum blade may need to be re-positioned or lubricated with a small amount of toner.
Dec 16, 2010 | Sharp Office Equipment & Supplies
Is there a way to clean the drum on the HP laserjet p3005n The toner and drum are one unit.
You don't want to clean the drum. It is done automatically as the drum rotates. The cleaning blade scrapes the residual toner off of the drum.
If the drum is not getting clean then you have to replace the cartridge.
Feb 10, 2010 | HP LaserJet P3005n Printer
Brother mfc. I made the mistake to use canned air to clean copier which got into my drum and made black streaks on my paper I keep cleaning the black streaks off the drum but when i put it back in i have...
First clean the glass of the laser.If you open the front door remove the drum from the machine just above were the drum was in place there is a glass mounted.Try and make a test print.If the streaks is still printing and you can see the streaks is deffinately from the drum you can strip the drum,clean the corrona wire and grit,and clean the drum brush.Strip only the drum unit if you sure the lines is caused by the drum.
Dec 11, 2009 | Office Equipment & Supplies
Print smears
Hi Allan:
Sounds like you need to replace the drum pivot plate assembly. This assembly is what cleans the drum assembly prior to putting the image on the drum. The pivot plate assembly has a rubber drum cleaning blade on it and when the printer begins to print a page it cleans the drum first. If the cleaning blade or the pivot plate are deffective then the drum will not be cleaned properly leaving smudgy areas on the drum.
Aug 13, 2008 | Xerox Phaser 8560DN Laser Printer
"Dust on Drum" problem
try using canned air to clean the coruna chagre wire assy
Apr 16, 2008 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
117 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
