Question about Kenmore Washing Machines
Stuck in a mode wont continue fills starts and stops and wont continue
    Problem Solver:
  • 15 Answers
Sounds like heater or stat
Posted on Nov 21, 2009
Why won't water stop filling?
There 2 reasons why water will not stop filling.
The water inlet valve is stuck open & needs replacing.
The pressure switch is faulty or the pressure switch hose is not connected.
To check the water valve turn washer on & let the water start to enter washer, turn off the power, if the water continues to run in then the valve is faulty.
Jun 30, 2015 | Washing Machines
Why won't the water in my whirlpool washer not turn off?
You mean that it wont stop filling? If it is continuing to fill when you start it, the water level sensor might be bad or plugged. IF it fills when it is off, unplug the machine to see if it stops. If it stops then it is the control board sending voltage to the valves. If it does not stop then the valve is stuck open.
Oct 07, 2014 | Whirlpool Washing Machines
Our F & P GW508 Smart Drive starts to fill at
Sounds like your out of balance switch is corroded. It is located underneath your gold motor controller board.
May 27, 2017 | Fisher and Paykel Fisher Paykel Intuitive...
My GE washer wont stop filling in any cycle. Even if you pull out the plug. Leaks everywhere. I blew into water level switch hose and it clicks. Model number WBXR1060T. Thank you
If water continues to fill and you have unplugged the washer from the wall then your fill valve is stuck open and needs to be replaced. Turning off the water at the wall faucet should stop the water. The fill valve is what the hoses are attached to at the washer.
Feb 02, 2010 | Washing Machines
My washer continually fills with water
your fill valve is stuck open replace fill valve
Sep 28, 2009 | Kenmore Elite 45986 Front Load Washer
How to mend it .com - Bosch dishwasher SGS43A12GB-27 does not stop filling
possibly the inlet water valve stuck open tho this is rare.
disconnect the valve electrically and see if the fault is still present. if so, the valve is stuck open and needs replacing
Jun 24, 2008 | Bosch Dishwashers
Starts to fill and then stops, and the cycle continues on.
Jmars, under the consol there is two pressure switches. One controls the fill and the other is back-up incase the other fails. It sounds like your water pressure switch is tripping too soon. Try putting the washer into a self test mode by pressing in this order soak--soil level---soak--soil level. The machine should enter a test mode. Let it run it's test and see if you come up with any error codes. The pressure switch is the one on the left under the consol. It will be marked OPR, the part number is 8054766. The consol will lift up by using a putty knife under each end, pushin on the clips and lifting up. The back panel of the consol is removable. Catriver..post back
Apr 14, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
15 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
