Question about HP LaserJet 3015 All-In-One Printer
HP Laserjet 3015 - Printed pages are VERY light
Printed pages are VERY light. I changed the toner cartridge but with the same result. If I print multiple pages (i.e. 10 copies of the same doc) it does get darker toward the last copy but still not dark/crisp as it is supposed to be. Any suggestions?
Printed pages are VERY light, and the fuser temperature is low. The toner is not fixed on paper. Still it don`t give any errors. A detailed diagram of the power souce have anyone?
Posted on Nov 17, 2009
Very bed image on a paper
Print a couple of pages. As the printer is printing open the toner cover. Pull the toner cartridge out and look down at the paper. If the printing looks good the fuser probably needs replacing. Before doing that, have you checked the toner cartridge.
Mar 09, 2014 | HP LaserJet 3015 All-In-One Printer
Very bed image when i print a page on hp 3015 lase
is the toner cartridge original or reffiled.
Try with original one.
check if the image you print is correct printed on drum
to do this print something and when the printer start to pull the paper stop the printer by open a door. then pull out the toner cartridge and look the drum if the image seems ok If you see bad image you have problem with laser scanner or charge of drum.
Our copier is copying in light shade. how to make it darker
To adjust the default lighter/darker setting
1. On the LaserJet 3015, press MENU/ENTER.
2. Use the < or the > button to select Copy setup, and then press MENU/ENTER.
3. Use the < or the > button to select Def. Light/Dark, and then press MENU/ENTER.
4. Use the < or the > button to adjust the setting. Move the slider to the left to make all of the
copies lighter than the original, or move the slider to the right to make all of the copies
darker than the original.
5. Press MENU/ENTER to save the selection.
Page 48 of the User Guide has instructions for adjusting the light/dark setting during a copy job.
Also see the Troubleshooting section of the User Guide for other possible reasons for light/faded copies.
If your copies continue to come out too light, you may need to clean the insert a new toner cartridge or change brands of toner. I tried several "generic" toner cartridges and refills, but my prints and copies were always faded or streaky. After going back to genuine HP cartridges, I haven't had any print quality problems.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
How many pages did my HP 3015 print from current cartridge?
It is not possible to see how many pages you printed with your current cartridge.
Mar 04, 2010 | HP LaserJet 3015 All-In-One Printer
New toner prints very light. No setting changes on printer.
I had a similar problem, it turned out to be a cheap toner cartridge. Replaced it with an HP cartridge and have had any problem since.
Mar 23, 2009 | HP LaserJet 4p Printer
HP3015 All in One - new toner put in but printing very pale
Try going into the Maintnence Center, should be in Options or Maintanence and running it.
Mar 11, 2009 | HP LaserJet 3015 All-In-One Printer
Problem with my Printer - HP laserjet 3015
I need a bit more information. Does it print at all or just does'nt copy?
If it does'nt print at all the problem is generally the toner cartridge. Have you tried changing the cartridge?
Feb 19, 2009 | HP LaserJet 3015 All-In-One Printer
Images of previous page remains on the new printed page
It is either a bad drum in the toner cartridge or toner on the fuser. Try changing out the toner. If the problem remains, you'll have to get a new fuser module.
Nov 29, 2008 | HP LaserJet 1020 Printer
Prints dark page
Try to change toner cartridge, I had this happen with my old laserjet 5, and it was a faulty cartridge on mine.
Aug 16, 2008 | HP LaserJet 2550L Printer
Poor print quality
the shadow-like copy of text is definitely coming from a faulty tone cartridge, replace it and you will have your solution,
the verical lines are caused by a dirty optical lens which is located under the keypad, just lift that up and you will see a glass bar that is likely dirty, clean it well and this should solve this problem as well
Jun 13, 2008 | HP LaserJet 3015 All-In-One Printer
HP LaserJet 3015 All-In-One Printer Logo
519 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
