Question about Kenwood Car Audio & Video
How to fit a amp
How to git a amp
  • 25 Answers
Hello i have seen you have a problem fitting a amplifier in your car its really simple
.. first get a lead to get from your battery(with a positive and negative)
..then just plug in your speakers and the power cable
but make sure it is all safe as you go over speed bumps it might knock off the wire
if this dosnt help feel free to ask again
Posted on Nov 20, 2009
Answering machine,how to set up an use
git book, and follow directions. too git book,go to the phone/answering device maker, anad git the book. it will be download able. lol.
Aug 20, 2017 | Lands Phones
Git a yamaha xvs1100 2001 reffiting battery but alarm keeps going off when connect leads
Remove the alarm connections from the battery terminals and fit the battery,,,
Then fit the arlarm wires starting with the black,,negative wire first ....try this first ,,,
If it doesn't solve the problem
Remove the arlarm wires and reconnect them as before ,,,this time pressing the alarm deactivate button on your key fob ....
Oct 19, 2014 | Motorcycles
88 chevy sprint just dies taking hard left turn & wont restart for 25+ mins.
hav u replaced the fuel pump--some cars with old pumps are sensitive to turns--git a fuel pressure test done to confirm
Jun 03, 2013 | Cars & Trucks
Can't git engine to fire know fire from coil.
Rechk plugs firing order. chk soliniod and coil r ok, rechk fuel is getting into engine- choking usually determines that, u can smell the over choked engine. I f engine turning & choked hold throtel to floor while cranking and leave there until it fires. if no firing happends it must be electrical. rechk electrical connections. Cheers
Sep 06, 2012 | 1989 Nissan Pathfinder
Transmisson wont shift into high gear
the tech doin service mite hav pulled some wires to trans--go and inspect or tellum about it--also linkage may be out of ajust--whenevr things git done ask that its test driven before takin it home
Nov 28, 2011 | 2000 Volkswagen Beetle
I have a squeeking in my front belt area on my '97 Jeep grand cherokee. I have replaced bearings and cleaned pulleys. It will not stop-Help!!
I just had my AC condenser pump realigned for the same belt noise issue. They also discovered the bolts holding the condenser in place were stripped out from the previous owner. I now have no belt noises! I had replaced the idler and bearing and have been through 3 belts before we figured this out!
Mar 17, 2010 | 1997 Jeep Grand Cherokee
Where is number one on distribor cap? which is cylinder #1 ? On 1980 triumph TR7
looking from above, it's top right rear, towards the engine block!, same as the spitfire,& Vittess. Lucky git for having one! The easiest way to find out, is to remove the spark plug, turn the engine over with a socket on the bottom pully of he engine, put your finger in the plug hole until No 1 it at the top of it's stroke with the rotor arm fitted, then fit the distributer cap, There is only one way way it should fit, if not rotate it 180 degrees, and try again. To set the other firing line, follow the same instrusctions above, but I think it's fire 2413.
Regards
Dave
Jul 15, 2009 | Triumph Tr 7 Cars & Trucks
Gitting gti lights
The wiring is different, if your Golf had headlights with H4 bulbs then changing to high beam turns dip off. The GTi has separate dip and high lights, on high beam dip stays on (all 4 bulbs on).
Mar 20, 2009 | 1995 Volkswagen Golf
Nitro BMW 484 1200 watt amp.
check fuses and remote wire at the head unit. must have a good ground at amp.
Dec 03, 2008 | Nitro BMW-482 Car Audio Amplifier
Car Audio & Video Logo
42 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
