Question about Acer Aspire 3680 Laptop
I have problem with my ctrl key it is always pressed example when i press only (F)then its open find window.
4 Suggested Answers
  • 244 Answers
SOURCE: keyboard
i believe your motherboard is bad
Posted on Feb 18, 2008
  • 244 Answers
SOURCE: want to restore my acer 5315 what keys do i press together eg ctrl alt f10
Alt+F10 during boot or in the windows. it will work as long as you didn't delete the recovery partition
Posted on Oct 08, 2008
parrotheadpc
  • 2600 Answers
SOURCE: My ctrl key always pressed. Can't type other
This may or may not help you but give it a try, if the key is not physically stuck down on the key carrier....try holding down the "Fn" key and tap the Ctrl key once. Hopefully, this will toggle the key lock to the off position.
Posted on Jun 21, 2010
Windows keyboard shortcut commands
There are many. Do a Google search for "Windows Key Combinations" and you should find several links to a list of the available commands. The "Windows Key" is that key between the Ctrl and Alt key on your keyboard that looks like a window with 4 panes in it. You hold down the Windows Key while pressing any one of several others, depending on what you want to do. afor example Holding down the Windows key and pressing R will open a "run" box. The Windows Key plus E will take you to "My Computer". the Windows key plus D will immediately take you to the Desktop, etc., and so forth.
Jul 14, 2014 | Microsoft Windows XP Professional
Tip
Windows xp keyboard tips
and also
and
Windows system key combinations
  • F1: Help
  • CTRL+ESC: Open Start menu
  • ALT+TAB: Switch between open programs
  • ALT+F4: Quit program
  • SHIFT+DELETE: Delete item permanently
  • Windows Logo+L: Lock the computer (without using CTRL+ALT+DELETE)
Windows program key combinations
  • CTRL+C: Copy
  • CTRL+X: Cut
  • CTRL+V: Paste
  • CTRL+Z: Undo
  • CTRL+B: Bold
  • CTRL+U: Underline
  • CTRL+I: Italic
Mouse click/keyboard modifier combinations for shell objects
  • SHIFT+right click: Displays a shortcut menu containing alternative commands
  • SHIFT+double click: Runs the alternate default command (the second item on the menu)
  • ALT+double click: Displays properties
  • SHIFT+DELETE: Deletes an item immediately without placing it in the Recycle Bin
General keyboard-only commands
  • F1: Starts Windows Help
  • F10: Activates menu bar options
  • SHIFT+F10 Opens a shortcut menu for the selected item (this is the same as right-clicking an object
  • CTRL+ESC: Opens the Start menu (use the ARROW keys to select an item)
  • CTRL+ESC or ESC: Selects the Start button (press TAB to select the taskbar, or press SHIFT+F10 for a context menu)
  • CTRL+SHIFT+ESC: Opens Windows Task Manager
  • ALT+DOWN ARROW: Opens a drop-down list box
  • ALT+TAB: Switch to another running program (hold down the ALT key and then press the TAB key to view the task-switching window)
  • SHIFT: Press and hold down the SHIFT key while you insert a CD-ROM to bypass the automatic-run feature
  • ALT+SPACE: Displays the main window's System menu (from the System menu, you can restore, move, resize, minimize, maximize, or close the window)
  • ALT+- (ALT+hyphen): Displays the Multiple Document Interface (MDI) child window's System menu (from the MDI child window's System menu, you can restore, move, resize, minimize, maximize, or close the child window)
  • CTRL+TAB: Switch to the next child window of a Multiple Document Interface (MDI) program
  • ALT+underlined letter in menu: Opens the menu
  • ALT+F4: Closes the current window
  • CTRL+F4: Closes the current Multiple Document Interface (MDI) window
  • ALT+F6: Switch between multiple windows in the same program (for example, when the Notepad Find dialog box is displayed, ALT+F6 switches between the Find dialog box and the main Notepad window)
Shell objects and general folder/Windows Explorer shortcuts
For a selected object:
  • F2: Rename object
  • F3: Find all files
  • CTRL+X: Cut
  • CTRL+C: Copy
  • CTRL+V: Paste
  • SHIFT+DELETE: Delete selection immediately, without moving the item to the Recycle Bin
  • ALT+ENTER: Open the properties for the selected object
To copy a file
Press and hold down the CTRL key while you drag the file to another folder.
To create a shortcut
Press and hold down CTRL+SHIFT while you drag a file to the desktop or a folder.
General folder/shortcut control
  • F4: Selects the Go To A Different Folder box and moves down the entries in the box (if the toolbar is active in Windows Explorer)
  • F5: Refreshes the current window.
  • F6: Moves among panes in Windows Explorer
  • CTRL+G: Opens the Go To Folder tool (in Windows 95 Windows Explorer only)
  • CTRL+Z: Undo the last command
  • CTRL+A: Select all the items in the current window
  • BACKSPACE: Switch to the parent folder
  • SHIFT+click+Close button: For folders, close the current folder plus all parent folders
Windows Explorer tree control
  • Numeric Keypad *: Expands everything under the current selection
  • Numeric Keypad +: Expands the current selection
  • Numeric Keypad -: Collapses the current selection.
  • RIGHT ARROW: Expands the current selection if it is not expanded, otherwise goes to the first child
  • LEFT ARROW: Collapses the current selection if it is expanded, otherwise goes to the parent
Properties control
  • CTRL+TAB/CTRL+SHIFT+TAB: Move through the property tabs
Accessibility shortcuts
  • Press SHIFT five times: Toggles StickyKeys on and off
  • Press down and hold the right SHIFT key for eight seconds: Toggles FilterKeys on and off
  • Press down and hold the NUM LOCK key for five seconds: Toggles ToggleKeys on and off
  • Left ALT+left SHIFT+NUM LOCK: Toggles MouseKeys on and off
  • Left ALT+left SHIFT+PRINT SCREEN: Toggles high contrast on and off
Microsoft Natural Keyboard keys
  • Windows Logo: Start menu
  • Windows Logo+R: Run dialog box
  • Windows Logo+M: Minimize all
  • SHIFT+Windows Logo+M: Undo minimize all
  • Windows Logo+F1: Help
  • Windows Logo+E: Windows Explorer
  • Windows Logo+F: Find files or folders
  • Windows Logo+D: Minimizes all open windows and displays the desktop
  • CTRL+Windows Logo+F: Find computer
  • CTRL+Windows Logo+TAB: Moves focus from Start, to the Quick Launch toolbar, to the system tray (use RIGHT ARROW or LEFT ARROW to move focus to items on the Quick Launch toolbar and the system tray)
  • Windows Logo+TAB: Cycle through taskbar buttons
  • Windows Logo+Break: System Properties dialog box
  • Application key: Displays a shortcut menu for the selected item
Microsoft Natural Keyboard with IntelliType software installed
  • Windows Logo+L: Log off Windows
  • Windows Logo+P: Starts Print Manager
  • Windows Logo+C: Opens Control Panel
  • Windows Logo+V: Starts Clipboard
  • Windows Logo+K: Opens Keyboard Properties dialog box
  • Windows Logo+I: Opens Mouse Properties dialog box
  • Windows Logo+A: Starts Accessibility Options (if installed)
  • Windows Logo+SPACEBAR: Displays the list of Microsoft IntelliType shortcut keys
  • Windows Logo+S: Toggles CAPS LOCK on and off
Dialog box keyboard commands
  • TAB: Move to the next control in the dialog box
  • SHIFT+TAB: Move to the previous control in the dialog box
  • SPACEBAR: If the current control is a button, this clicks the button. If the current control is a check box, this toggles the check box. If the current control is an option, this selects the option.
  • ENTER: Equivalent to clicking the selected button (the button with the outline)
  • ESC: Equivalent to clicking the Cancel button
  • ALT+underlined letter in dialog box item: Move to the corresponding item
reference: http://support.microsoft.com/kb/126449
on Nov 12, 2014 | Microsoft Windows XP Professional With...
Tip
How to save time on a PC
Time can be saved when repetitive tasks are performed by shortcuts instead of using the mouse.
In this tip I will be sharing a number of shortcut. I will not be sharing the most common ones.
*The windows key looks like a flag.
1. To see the desktop (minimize all the windows); Press and hold the windows key and then press D and release both of them.
2. To switch between windows; Press and hold Alt key and then press Tab key.
3. To Switch between tabs in a window; Press and hold Ctrl key then press the Tab key.
4. To close a window; Press and hold Alt key and then press F4 key.
5. To close a tab in a window; Press and hold Ctrl key and then press F4 key.
6. To open up Run; Press and hold Windows key and then press R key.
7. To select all text; Press and hold Ctrl key and then press A key.
8. To Undo; Press and hold Ctrl key and then press Z key.
9. To Redo; Press and hold Ctrl key and then press Y key.
10. To switch Users without completely logging off. Press and hold Windows key and then press L key.
11. To zoom in or out; Press and hold Ctrl key and press + or - key respectively.
+ being for Zoom in - being for Zoom out
12. To add www. and .com in the address automatically; First write the name of the site and then press Ctrl and Enter/Return together for an instant. For example to open fixya, you'll type fixya and then press Ctrl and enter together to bring in www. before and .com after the name.
13. To make a text go as a subscript or superscript. (MS OFFICE) Press and hold Ctrl and Shift key together and then press the + or = button to make a text go as a superscript. Press and hold Ctrl and then press + or = button to make the text go as a subscript.
14. To Save As; (MS OFFICE) Press F12.
15. To Save or overwrite save; Press and hold Ctrl and then press S key.
16. To make a hyperlink; (MS OFFICE) Press and hold Ctrl key and then press K key.
The following shortcuts can be used on other softwares as well, such as internet browsers, wherever there is a text in short.
17. To copy a text; Press and hold Ctrl and press C key.
18. To cut a text; Press and hold Ctrl and press X key.
19. To paste a text; Press and hold Ctrl and press V key.
These are the shortcuts of the tasks which are performed almost daily.
on Apr 06, 2010 | Computers & Internet
I need instructions on how to use the hot keys and function buttons
F1
  • Almost always used as the help key, almost every program will open the help screen when this key is pressed.
  • Windows Key + F1 would open the Microsoft Windows help and support center.
  • Open the Task Pane.
F2
  • In Windows commonly used to rename a highlighted icon or file.
  • Alt + Ctrl + F2 opens a new document in Microsoft Word.
  • Ctrl + F2 displays the print preview window in Microsoft Word.
F3
  • Often opens a search feature for many programs including Microsoft Windows.
  • Shift + F3 will change the text in Microsoft Word from upper to lower case or a capital letter at the beginning of every word.
F4
  • Open find window.
  • Repeat the last action performed (Word 2000+)
  • Alt + F4 will close the program currently active in Microsoft Windows.
  • Ctrl + F4 will close the open window within the current active window in Microsoft Windows.
F5
  • In all modern Internet browsers pressing F5 will refresh or reload the page or document window.
  • Open the find, replace, and go to window in Microsoft Word.
  • Starts a slideshow in PowerPoint.
Jan 15, 2011 | Computers & Internet
How do i flip my computer screen back?
Heya
Press CTRL+ATL+ Arrow keys on the keyboard
Say for example you want to flip it strait PRESS CTRL+ATL+UP Arrow key
Flip Right PRESS CTRL+ATL+Right Arrow key
Flip Left PRESS CTRL+ATL+Left Arrow key
Flip DOWN PRESS CTRL+ATL+DOWN Arrow key
Thanks & Regards
LoNG LiVE ThE gEeks!!!!!
Dec 11, 2010 | Computers & Internet
Tip
Microsoft Excel tips
Auto sum shortcut key
Quickly create a Microsoft Excel formula to get the sum of all cells by highlighting the cells you wish to know the value of and pressing ALT and = .
Create hyper links in Excel
Quickly create hyper links in your Microsoft Word, Excel, or Front Page document by highlighting text and pressing "CTRL + K".
Close all open files at once
Close all open Microsoft Word and/or Excel files by holding down the shift key and clicking "File" and then "Close All".
Quickly open recently opened files
Quickly open the recent files by first pressing "ALT + F" to open the file Menu and press 1, 2, 3, or 4.
Create underlines without any text
This tip works with the majority of Microsoft Office applications. Easily create an underlined space by pressing CTRL + U to start the underline, then press SHIFT + Space for each underlined space you wish to create. An example of how this could be used is for printable forms, for example: Name: .
Print only sections of a document
Save on your printer ink by selectively printing in Windows programs such as Microsoft Word, Internet Explorer, WordPad, Outlook, etc. To do this highlight portions of text you wish to print and click print. In the printer dialog window under Page Range choose the option Selection. It is important to realize that not all programs or printer drivers support this feature.
Repeat recent action
Using the F4 key in Microsoft Office 2000 and above allows the user to repeat the last used action. For example, if you have changed the font of a selected text and wish to change another portion of text to the same font, pressing F4 will do this for you automatically.
Quickly undo
Quickly undo mistakes in the majority of most PC Windows program by pressing CTRL + Z.
Quickly above cell contents
In Microsoft Excel press CTRL + SHIFT + " to copy the above cells contents.
Using the Microsoft Excel Auto filter
Organize cells quickly by using Microsoft Auto filter. Columns that contains long listing of data can be easily sorted by using the Auto filter option, to use this option select the top rows of the columns you want to be used and select Data / Filter and Auto Filter. Once successfully completed you can use drop down arrows to filter the data automatically.
on Dec 27, 2009 | Computers & Internet
Advise uses of all F Keys.?.
F1
Open the Task Pane.
F2
F3
F4
Open find window.
F5
Sep 30, 2010 | Logitech EX110 Mouse
Could you plz let me know how to print screen in IBM T42.
hit these keys at the same time CTRL P or PRTSCN above the home key.
Oct 05, 2009 | IBM ThinkPad R51 Notebook
How do i get a screenshot??
Hi!
1. Using Print-Key of your keyboard
Open the window from which you want a screenshot and press "Print".
Open e.g. M$ Word and press CTRL + V to paste it in.
2. Use the freeware tool ZScreen "http://brandonz.net/projects/zscreen/".
Hope I could help.
See ya,
Christian
May 08, 2009 | Microsoft Windows XP Home Edition
Acer Aspire 3680 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
