Terma towel rail thermostat remote control manual missing
I have an electric towel rail with Terma thermostat and timer. I don't have a manual for the infra red controller for it, and I can't work out how to work it - I've contacted the supplier, so far with no joy. Can you help? The controller has the numbers 7713402 and T-R-DT-IR1-SI on the back. Thanks.
SOURCE: Onkyo DR-UN7 DVD Receiver remote control code
Nowdays there are CLONE type remotes available form electrical stores.
These clone type remotes carry all the codes necessary to work TV, Vdeos, CD players and other domestic sound systems.
I would suggest that you visit one of these stores and see what they have for your ONKYO system, the cost is not great and you will walk out with a complete remote for your system that will work all the other controls as well..
The stores have a fold out paper list, (thats very long) showing model and manufacturer detail for what codes you need to enter into the new remote to make it compatible wuith your ONKYO system.
Cheers From YUBEUT
Posted on Feb 15, 2008
  • 74 Answers
SOURCE: Code for a General Electic universal remote control
Try here:
http://www.replacementremotes.com/tvcodes/index.html
Posted on Mar 25, 2008
shaggyrat
  • 1224 Answers
SOURCE: remote control
in the remote and the fan the little blue box is called a dip switch
you will have to open fans base to access the remote power sender
on both the fan and remote the dip switches have to match in order for the remote to work the fan properly
or your signal will never make it to remote box
Posted on Jun 08, 2008
SOURCE: My Logik L22LID628 tv has
We have had two of these tvs break within 2 days of purchase, in our case both times it seems to be a backlight failure. Did you wall mount your tv? If so when you take the base off it leaves a hole in the casing leaving circuitry visible. I think it's very easy to damage the ciruitry.
Posted on Nov 03, 2008
SOURCE: thermostat problems!
You can turn off the 'Optimum Start'. See MoneySavingExpert website for instructions posted there by Honeywell as to how to do it.
Posted on Jan 22, 2009
How to replace the fuel injector for a 2008 chrysler pt cruiser?
To remove a fuel injector or injectors you must remove the fuel supply rail that sits over them. Here is how you do that for both engine options, Turbo and non Turbo..
Removal & Installation
Except Turbocharged Models
WARNING Release fuel system pressure before servicing fuel system components. Service vehicles in well ventilated areas and avoid ignition sources. Never smoke while servicing the vehicle. This may result in personal injury or *****.
  1. Release fuel system pressure.
  2. Remove the air cleaner lid, disconnect the inlet air temperature sensor and makeup air hose.
  3. Remove the negative battery cable.
  4. Remove the engine cover or throttle control shield if equipped.
    NOTE Wrap shop towels around hose to catch any gasoline spillage.
  5. Disconnect fuel supply tube from rail.
  6. Remove the Intake Manifold, refer to the Engine section.
  7. Disconnect electrical connectors from fuel injectors.
  8. Remove bolts holding fuel rail.
  9. Remove the fuel rail and injectors.
  10. Remove the injectors from the fuel rail.
To install:
  1. Install injectors to the fuel rail.
  2. Apply a light coating of clean engine oil to the O-ring on the nozzle end of each injector.
  3. Insert fuel injector nozzles into openings in intake manifold. Seat the injectors in place. Tighten fuel rail bolts to 170-230 inch lbs. (19.5-25.5 Nm).
  4. Attach electrical connectors to fuel injectors.
  5. Connect fuel supply tube to fuel rail. Refer to Quick Connect Fittings in the Fuel Delivery section
  6. Install Intake Manifold, refer to the Engine section.
  7. Install the engine cover or throttle control shield if equipped.
  8. Install the negative battery cable.
  9. Install the air cleaner lid, connect the inlet air temperature sensor and makeup air hose. Tighten air inlet tube clamps to 20-30 inch lbs. (2-4 Nm).
Turbocharged Models
  1. Release the fuel system pressure.
  2. Disconnect the negative battery cable.
  3. Disconnect the throttle body inlet hose and remove from throttle body.
  4. Disconnect the purge hose from the throttle body.
  5. Unlock and disconnect the electrical connection at the throttle body.
  6. Remove the throttle control shield .
  7. Remove the throttle and speed control cables from the throttle body.
  8. Remove the cables from the throttle body bracket.
  9. Unlock and disconnect the MAP sensor electrical connector.
  10. Remove the vacuum lines from the rear of the intake manifold.
  11. Remove the 5 bolts from the front of the intake manifold.
  12. Remove the 2 bolts from the rear of the intake manifold.
  13. Remove the intake manifold. Cover the lower intake manifold openings.
  14. Drain the Coolant system.
  15. Move the upper radiator hose clamp, so that the hose can be rotated up and out of the way.
  16. Remove the 2 small hoses from the thermostat housing.
  17. Remove the 2 bolts from the thermostat housing and rotate the assembly up and out of the way.
  18. Disconnect the fuel line from the fuel rail.
  19. Unlock and disconnect the electrical connectors from the fuel injectors.
  20. Remove the wiring harness from the fuel rail.
  21. Remove the 2 bolts from the fuel rail.
  22. Remove the fuel rail and injectors from the intake manifold.
To install:
  1. Install the fuel injectors to the fuel rail.
  4. Install the 2 bolts to the fuel rail. Tighten fuel rail bolts to 170-230 inch lbs. (19.5-25.5 Nm).
  5. Install the wiring harness to the fuel rail.
  6. Connect and lock the electrical connectors to the fuel injectors.
  7. Connect the fuel line to the fuel rail.
  8. Rotate the assembly back into place and install the 2 bolts to the thermostat housing tighten to 110 inch lbs. (12.5 Nm).
  9. Move the upper radiator house clamp back into place.
  10. Install the 2 small hoses to the thermostat housing.
  11. Fill the Coolant system.
  12. Install the intake manifold.
  13. Install the 2 bolts to the rear of the intake manifold tighten to 250 inch lbs. (28 Nm).
  14. Install the 5 bolts to the front of the intake manifold and tighten to 250 inch lbs. (28 Nm).
  15. Install the vacuum lines to the rear of the intake manifold.
  16. Connect and lock the MAP sensor electrical connector.
  17. Install the cables to the throttle body bracket.
  18. Install the throttle and speed control cables to the throttle body.
  19. Install the throttle control shield.
  20. Connect and lock the electrical connections at the throttle body.
  21. Connect the purge hose to the throttle body.
  22. Connect the throttle body inlet hose to the throttle body and tighten clamps to 20-30 inch lbs. (2-4 Nm).
  23. Connect the negative battery cable.
  24. Use the DRBĀ® scan tool ASD Fuel System Test to pressurize the fuel system. Check for leaks.
Mar 02, 2017 | Chrysler Cars & Trucks
Tip
Sauna Heater
Oil and Gas Sauna Heaters
Oil and gas heaters are the least popular heaters used in saunas.
One reason is because they're relatively inefficient compared to the others.
Some people even complain about the odor associated with the burning fuel. If they're properly vented, oil and gas heaters should have little or no unpleasant smell
Electric Sauna Heaters
Electric heaters are the most popular used in saunas.
They're easy to control with user friendly touch pads that include a timer and thermostat, and light switch,
They're also efficient and cost just pocket change to operate.
Electric heaters have controls that include a timer, thermostat, and light switch.
Wood Burning Sauna Heaters
If you have a house in the country or easy access to fire wood, a wood burning heater is a great choice for a sauna.
A wood heater may also be a good choice if you have an outdoor sauna.
Wood burning heaters don
on Jan 08, 2011 | Heating & Cooling
How to replace the fuel injector on a 2008 chrysler pt cruiser
To install:
Turbocharged Models
To install:
Where can I find an instruction manual for a n american standard remote for a trane split heating and ac unit?
AccuLink Remote Control - American Standard
https://www.americanstandardair.com/.../acculink-remote-control.html
Find more information on the AccuLink Remote Thermostat available from ... terms for your AccuLinkTM Remote Thermostat, please refer to your owner's manual ...
Thermostat Controls - American Standard
https://www.americanstandardair.com/products/thermostat-controls.html
Discover thermostats and get a digital thermostat for your home with American Standard. ... 7-day programmable comfort; Remote monitoring and programming ...
Free American Standard Thermostat User Manuals ...
homeappliance.manualsonline.com/manuals/.../american_standard/ameri...
Products 1 - 34 of 34 - Find the user manual you need for your home appliance products and ... American Standard Central Thermostat Installation Instructions.
Free American Standard Air Conditioner User Manuals ...
Feb 03, 2016 | American Standard Heating & Cooling
Fridgedair gleq332a52 won't stop heating
The timer: Located in the control console of the dryer the timer consists of a small motor connected to a series of gears that rotate cams, which turn electric contacts off and on inside the timer. The timer contacts control the dryer motor as well as the heat circuit and the timer motor itself. A defective timer motor or a defect in the timer's electrical contacts can cause the timer motor to fail and the timer will need to be replaced. The contacts can be checked for continuity with a multi-meter. This test should only be made when the dryer is unplugged. Another test u can do is observe by eyesight and see does the timer advance or is it stuck on one cycle?
1. On gas and electric dryers that have an "Auto Dry" cycle, the cycling thermostat is often used to advance the timer as well regulate the drum temperature. Essentially, thermostat will alternately turn on the heat source or the timer motor when the temperature has been satisfied. To check this thermostat, you will have to check for power to the timer motor with a multi-meter, during a cycle. This is a live voltage test and caution should be used.
2. Some dryers will use a cool down thermostat to tumble the clothes without heat, at the end of the dry cycle. Power is routed through this thermostat to the drive motor to keep it running until the drum temperature has dropped to a specific temperature. If this thermostat fails it can cause the drum to turn indefinitely or until the door is opened. You can check the thermostat for continuity with a multi-meter. This test should only be made with the power removed from the dryer.
Oct 16, 2014 | Dryers
Need original remote control & owner's manual for GE XS Stereo Commercial Skip TV, Model #27GT616
To get its original remote control and user manual, you have to contact the nearest authorized service center for GE
Sep 01, 2012 | Televison & Video
I need operating instructions for a wylex timer
There is no instruction manual for Wylex timers.
However the Wylex sell sheet appears to show generic din rail mounted timers.
Since these timers are made by other companies, and then sold by various companies, and then the models change rapidly, the best course of action is as follows:
1) Re-post question with clear and detailed description of timer buttons, and say what the timer controls.
2) Google image search for 1 and 2 channel timers to find same-similar timer.
3) Most timers have similar programming steps and once you find timer with same buttons, then that timer manual can be used to program unidentified timer.
4) Open following links to find din-rail timers that might match:
http://waterheatertimer.org/Hagar-timers-and-manuals.html
http://waterheatertimer.org/Tork-Digital-timers-and-manuals.html#DIN
Jun 23, 2012 | Hardware & Accessories
Need code for a rca remote for a seiki tv
You should look up that code in the manual of your RCA remote.
Seiki doesn't appear in the manual? You should follow the procedure indicated when a device is not listed with code.
You don't have a manual for your RCA remote? Please indicate the MODEL of your remote so someone might look it up on line.
Actually, if you input terma RCA, the model and MANUAL probably you can find it yourself.
Feb 07, 2012 | Televison & Video
Timer that has a 20 minutes interval up to 1 hour
More information is needed.
For example, a) what voltage timer is needed, b) what Load are you controlling and c) how does timer mount?
Easiest solution is 60 minute repeat cycle timer.
Timer knobs are adjusted, or the timer dial rotates once per hour and 20 minute timing cycle repeats each hour. The cycle repeats 24-7-365.
If you want the cycle to operate certain hours of the day, another 24 hour timer can be installed in-line.
1) Tork 8600 cycle timer, or Tork ACT percent cycle timer
http://waterheatertimer.org/Tork-timers-and-manuals.html#8000
https://www.grainger.com/Grainger/cycle-timers/timers/electrical/ecatalog/N-8hbZ1z0q55s
-or-
2) Intermatic CT2000 percent cycle timer, C8800 cycle timer
http://waterheatertimer.org/pdf/025-Talento-121-cycle-timer.pdf
-or-
3) For din-rail mount, Intermatic Talento 121 cycle timer
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#cycle
Add a comment
Oct 01, 2011 | Hardware & Accessories
Model:pf1103t will come but won't turn pump on now???
PF1103 is thermostat for 120V and 240V applications, and is usually wired to a timer that controls pool pump. When temperature drops below thermostatic setting, the thermostat by-passes the timer and runs pump continuously so pipes don't freeze. Usually this question appears in wintertime instead of summer, so I wonder how the PF1103 is turning ON, unless you are experiencing problems with a timer.
PF1103 manual shows wiring:
http://www.1000bulbs.com/pdf/Inter-PF1102T-Operating.pdf
You can buy the thermostat separately
http://www.amazon.com/Intermatic-PF1102M-Freeze-Protection-Mechanism/dp/B004I4278M
1) As an electrician, I would begin by looking for loose wires, evidence of burning and high heat.
2) Next I would examine the circuit and circuit breaker to see if voltage is reaching the timer and thermostat.
3) Last step would be to test individual wires to isolate problem.
Be sure to stand on dry surface like plywood when testing live electric circuits.
If you have a timer, open following links to help identify timer module, and then add a comment with timer model:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#FM
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#pool
Jul 24, 2011 | Hardware & Accessories
Heating & Cooling Logo
414 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
