Indesit washing machine W1A 121 no red light when
Indesit washing machine W1A 121 no red light when switch on was working then started making a banging sound and water filled to top with washing inside. Have managed to open door and let water out but now it switches on but no red light comes on and there is a clicking sound. Help please
    Genius:
  • Washing Mach... Master
  • 1,466 Answers
Select reset from front panel and reset timer. you may needalso to cure water level fault as its overfilling. could be dirty air hose to pressure switch...
Posted on Nov 13, 2009
Washing machine would not start
On the lid is a switch that turn off the washer when the load pushes against the top. You may have over-loaded the machine.
Feb 26, 2014 | Indesit Washing Machines
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
Indesit WIA121 Flashing Door Lock, Prewash and Spin Lights - Machine not draining
hi something similar has started happening to our washer, after the initial wash starts the machine doesn't do anything for a while then the red door light flashes on and off very quickly as does the 1st and 3rd green wash cycle light?
Jul 04, 2012 | Washing Machines
All lights flash on indesit washing machine soon after switch on
Indesit washing machine lights come on briefly when awitched on at mains and then no power
Feb 17, 2010 | Indesit W 123 Front Load Washer
Indesit WIA 121 not working - door latch not shutting
At first thought it was door lock mechanism was at fault but proved it to be ok - removed rubber 'boot' which on this model was on two stretchable spring retainers and checked operation of door lock.
Thought door hinges may have been bent so dismantled door, finding the problem to be the pin that the door latch pivots on had come out on one side so not lining up properly. This was easily pushed back into position.
Oct 05, 2009 | Indesit W 123 Front Load Washer
Selector knob on my Indesit Washing Machine WI 121 keeps turning & light flashes twice before light turns off. This happens approx 4 times in a whole turn of the knob. Indesit want £100 to come out to fix!...
Hi.
Sounds like you have faulty control module, which is quite expensive to replace.
Also the E.P.R.O.M would have to be replaced as well.
Probably cheaper to buy new washer.
Good luck.
Nov 18, 2008 | Indesit W 123 Front Load Washer
Indesit wia 121 door lock keeps flashing and when put machine on it goes to a wash without turning dial to correct wash no.
these machines have a memory built into the pcb's which means that if they are switched off or there is a powercut etc they will just carry on from where they were in the cycle as soon as they next power up. if there is a black dot on the timer settings turn the dial to it then switch machine on and this should reset it for you after a few seconds. if this does not work count how many times the doorlock light flashes as this is a fault analysis code they will usually flas then pause for a second then flash again and repeat this sequence until a longer pause (3 seconds) then the sequence starts over.
hope this helps
Jul 28, 2008 | Indesit Washing Machines
Indesit W1A 111 front load W/M
hiya
no need to worry they do this.
hope this helps
please dont forget to rate the helpfulness. thanks kj
Jul 20, 2008 | Indesit W 123 Front Load Washer
Indesit WIA 121 washing machine, front loader. The door lock led is continuessly flashing red even when the programme has stopped and the door is opened. I have to switch off at the main plug. Machine is...
One of the main problems with Indesit front loaders ( apart from replacing the door interlock switch) is
If the door will not close and click in the lock, then take the door off with a tork screwdriver and take the screws of the inner plastic off the door (make sure you do this on a flat surface) and gently prize off the inner plasic by running round a flat head screwdriver..
Once you have taken off the door and glass bowel - check out the door catch to see if a metal rod has come out of its housing holding the catch and spring in place and refit or replace.
I have come across many door catches like this.
Apr 21, 2008 | Washing Machines
Washing Machines Logo
206 people viewed this question
Top Washing Machines Experts
