Question about Sony PlayStation 2 (PS2) Console
How do i get my ps2 to read the disc again, because its not reading any discs right now
    Problem Solver:
  • 9 Answers
You could try to get lens cleaner in the form of a CD with a small brush on it and try that, but make sure it is the dry type cleaner. If it was a a single disk that was not being read then i find that cleaning it with Windex and a soft cloth, then waxing it with a liquid car wax works a lot of times. If the lens cleaner doesn't work you may have to send it off to Sony and have them recalibrate the laser, or replace it.
Posted on Nov 27, 2009
  • 4102 Answers
SOURCE: ps2 not reading discs
does it still read the disk you was playing or not if it dont then you could buy a lense cleaner put this into you ps2 and then after it has cleaned the lense try your games again you can buy these really cheap and they are just a disk with little brushes onn that cleans the lense in anything that takes disks if this dont solve the problem and the ps2 dont play any disk at all then the laser will need replacing you can replace it yourself but it will need to be recalibrated witch is something a pro must do as not doing this will stop it reading any disk but you only get this prob if you buy new laser you can get second hand ones but you never no if they are working or not hope this is some help to you
Posted on Nov 19, 2007
Cerfer39
  • 709 Answers
SOURCE: play station 2 won't read silver disc only reads blue disc
Hi Elvis,
The Blue back disc is CD format. The DVD laser circuit is giving you trouble. You can adjust the DVD pot some on the back of the Laser. Turn it about 3 degrees clockwise. Then put it the laser back in. Test the PS2 with no cover on, and use the white round disc from the laser drive cover to clamp a disc onto the spindle. Test DVD and PS2 Games that do not have Blue back.
Posted on Nov 28, 2007
  • 1003 Answers
SOURCE: ps2 disk read error
THE LASER LENS AND OR HUB SURFACE is dirty
Posted on Dec 05, 2008
  • 273 Answers
SOURCE: My PS2 only reads blue discs?
go here and go to the very end. hope this helps :D www.powerfulguides.com/ps2
Posted on Jun 09, 2009
localwonder
  • 6784 Answers
SOURCE: My Ps2 Won't read any disc I put in it
HI, the optical lens assembly has failed in your unit. you will need to replace this failed assembly in order to restore the reading capabilities of this gaming console.
Posted on Jun 19, 2009
There is no data, reading disc ps2
Clean the disc with rubbing alcohol. There may be scratches, which causes the Ps2 to not recognize the disc. Also, gently blow into your ps2. There may be a dust build up.
Jul 18, 2010 | Sony PlayStation 2 (PS2) Console
My ps2 (phat) wont read the disc it reads some ps1 disc,but wont read any ps2 silver disc
if it says reading disc 4 a while then disapears then try loading the disk while the ps2 is upside down.
Dec 08, 2009 | Sony Video Game Consoles & Games
Disc read error
Disc Read Error is mainly due to worn-out,dirty lens and it can also appear because of the disc that you have inserted in your PS2......
Try following to get rid of DISC READ ERROR:
  • Clean your PS2 lens:
Watch this video first
This will help you in cleaning the lens.You can also clean your PS2 lens by some lens cleaning DISC.Make sure not to touch lens with your hand.
  • Clean your DISC:
Watch this one to clean your DISC
Thank you!!!
Nov 12, 2009 | Sony PS2 Dual Shock 2 Controller...
Ps2 is not reading disc my playstation fell down and now doesn't read the disc
A lot of ps2 systems have been having a balance problem with discs that have top art. try putting a piece of tape right around the hole in the center of the disk and then try again. it may help to solve the problem
May 12, 2009 | Video Game Consoles & Games
Will not read blue discs no problem with clear(silver) ones tho.
1. Apparently, blue PS2 discs are lighter than silver ones, so they tend to move around more when the PS2 is reading them. To fix this, you can put duct tape on the top of the disc. This will make it heavier, so it won't move around too much and it should make reading the disc easier for your poor PS2. People have told me that this indeed works (but not always). Don't go overboard with the tape though. Attempt at your own risk. 2. If the problems occurs when the PS2 is horizontal, try putting it into its vertical position. Or try putting it horizontal if it is vertical. 3. Use a can of compressed air to clean dust out of the system. 4. Make sure your game discs are not the problem. Keep them as clean as possible. Even small scratches can cause problems. 5. Open up your PS2 and clean it out or try adjusting the lens. Very risky and voids your warranty. 6. Try using a DVD lens cleaner (for problems reading silver discs) or a CD lens cleaner (for blue disc problems). 7. Send your system to Sony for repairs. Due to a lawsuit, Sony may have to repair your PS2 for free even if there is no warranty. Contact Sony for details. That is all the advice I can give. If the len(s) cleaners or compressed air don't work, then you are probably just out of luck. There is no magic way to suddenly get your PS2 working again without professional repair.
The trick to getting the discs to play on any PS@ (old or new) when they are black or blue is to put a piece of tape lengthwise and width wise around the hole in the disc on the topside (picture-side) of the disc. What this does is add weight to the disc and thus allows the PS2 to read it more accurately. I had bought many older titles not too long ago and was disappointed when they didn't work. Then I spoke with a Japanese expert online and he suggested using scotch tape around the hole in the disc and it worked instantly. Don't be fooled into buying a new PS2, just a roll of scotch tape. You'll only need four one inch strips.
Thank you for using FixYa - a FixYa rating is appreciated!!
Jan 27, 2009 | Sony PlayStation 2 (PS2) Console
Disc doesn't play
yes its 100% lens problem.the lense of the ps2 consists of two parts,one is the one that reads the dvd disc and the other one that reads the cd-r only.the dvd reader is already busted that is why it only recognises only some cds which are cd-r's.try replacing the lens and you can play dvd discs again.hope this one helps
Jan 01, 2009 | Sony PlayStation 2 (PS2) Console
Disc read error
Disc Read Error generally means that the game disk cannot be read by your console.
Reasons for Disc Read Error
1. Disk surface scratched or smudged.
2. Disk surface dirty.
3. Lens surface dirty.
Here is what you can try doing.
1. Check the game disc for any scratches or smudges on the surface of the game disc, try to clean them off by using a non-abrasive cotton cloth.
2. If the PS2 console is lying down, please set the console to on its side or if it's on its side set it to flat position, restart the console and then try game again. Always ensure the PlayStation 2 is in a cool, well ventilated place.
3. Remove and reinsert the Memory card of your PS2, restart the console then try running the game again.
Other troubleshooting that you can try.
Change the Disc speed of the PS2 DVD and then try again.
Start the PS2 with no disc in a drive. Press the "triangle" button on the controller.
Use the up and down buttons on the controller to select "Playstation Driver” and press the "triangle" button on the controller.
Select Disc speed. If it is set to "Fast," select "Standard"; if it is set to "Standard", select "Fast" and press the "X" button on the controller. Press the "O" button on the controller. Insert the game disc and restart the PS2. Try running the game again.
Turn the Diagnosis On for PlayStation2 to auto detect the best settings.
From the Browser and System Configuration menu. Press the triangle button to select Version. Highlight the Console from the list and press the triangle button - this accesses the next menu option. The Diagnosis will be highlighted. Press the X button to access the options available. Highlight "ON" and press the X button to affect the change. Restart the console and try the game again.
If the above steps does do not solve the error then you would probably have to replace the disc.
Note: If you are using the Slim version of PS2 make sure that the console is properly ventilated and that it should always be in the standing position, as the slim version of PS2 no fan or any other cooling unit unlike the normal PS2.
Oct 13, 2008 | Video Game Consoles & Games
Read disc error
You said the model is 77001?? is that the slim type ps2?? if it is try this troubleshooting step
if the console is lying down flat where the disc lid is at the right side, try applying pressure on the lower right corner of the lid, sometimes the lid's safety button gets worn out and it will give you disc read error if this solves the problem then the button really is busted, if you have technical background you try and change the button
Jun 06, 2008 | Sony PlayStation 2 (PS2) Console
PS2 disc read error. Help Please
my skinny ps2 will not read the disc
1. it takes long
2. it says disc cant be read
Apr 06, 2008 | Sony PlayStation 2 (PS2) Compact System...
Sony PlayStation 2 (PS2) Console Logo
205 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
