Question about Linksys Wireless-G WRT54G Router
My router is not configuring with modem for internet lan. help needed?
  • 535 Answers
First u need a lan card in your pc then plug one cable from the router another is in PC lan socket then power on your router
1) open internet explorer
2) type in address bar 192.168.1.1 then press enter
3)then u get user and password screen
4) type in user name admin and pass is admin
5) then go in 1st manu of the router
6) configer ip address in your router
then modem cable plug in router internet socket
Posted on Nov 13, 2009
How to change browser to allow conection to internet
To connect to the Internet you need a few extra things aswell as a network or wireless card and install the LAN or wireless driver.
1. You need to sign up with an Internet service provider.
2. Connect a LAN cable from your computer to the DSL or cable modem
3. You need a DSL or cable modem and connect and configure the modem to inaccordance with your Internet service provider's instructions.
4. Install Internet Explorer if it has not been done.
5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet.If you have a wireless router and it is connected to the DSLor cable modem then -
To connect to yourwireless router, the router needs its wireless settings to be configuredwith the SSID, encryption key etc., also the wireless cards in all thelaptops/computers needs to be configured with these router's wireless settings.Then the laptops/desktop computers can communicate with your wireless router.
Dec 27, 2011 | Computers & Internet
I cant get this sylvania 7 smartbook , model # synet07wicv to get internet.
Dec 25, 2011 | Sylvania G-Netbook
How to connect inenter by using lan and ftp
To connect to the Internet you need a few extra things aswell as a network card and install the LAN card driver.
5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet. If you have a wireless router and it is connected to the DSLor cable modem then -
Jun 11, 2011 | Computers & Internet
Configure Modem Echolife HG520s With WRT54G OR WRE54G
Not sure if I understand properly but your router should have a WAN port or an "Internet" port
your modem should be connected to it and your PC should be on any of the LAN port
Apr 04, 2009 | Linksys Wireless-G WRT54G Router
Connecting a wireless router to Tiscalli broadband connection
  1. USB modem is connecting a PC USB port with a DSL phone line: CANNOT be connected to a ROUTER LAN (ethernet NOT USB port).
  2. Wireless ROUTER is NOT a modem and it CANNOT connect the Internet (or WAN) LAN port to any "phone line"
  3. Connect the Router Internet (WAN) port to Modem (you need a LAN MODEM = a modem with a LAN/ETHERNET port)
  4. Be sure your internet is running before strting ROUTER configuration with Router Company CD
Jan 05, 2009 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
Setup linksys wrt54g2 broadband router with prolink h9200 modem
You probably will need to make some configuration changes in the Linksys router, or in your computer, or both. Your are correct that you connect the Linksys WAN connection to the LAN connection of the modem. If your connection type is PPPOE, you will need to set that up in the Linksys with the username and password provided by your ISP, so the modem will allow you to login and connect to the internet. If that is how you were connecting to the modem with your computer, you will need to configure a new LAN connection in the computer in order to connect to the Linksys. You can then configure the Linksys through your web browser to connect to the modem.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Dec 27, 2008 | Linksys Wireless-G WRT54G Router
Router no connecting to the internet
You need to configure NAT on the router to permit the entire LAN to access internet
Example.
LAN Segnment is 192.168.1.0/24
1. Create an access-list to identify the local segment
2. Configure the Nat interfaces properly (NAT-INSIDE, NAT-OUTSIDE)
3. do the NAT configuration
i.e ip nat inside source list (ACLNUMBER) .....
Dec 08, 2008 | Computers & Internet
No internet when router plugged in
I assume your modem is a ADSL or cable modem.
I suggest you first connect your modem to a computer and check if you can connect to the Internet. If you cannot connect then check status of the LEDs on your modem. If you don't have LEDs indicating the PPP/ADSL, and LAN connection then you have an ISP connection problem.
If you can connect to the Internet then your problem is either the router configuration and or LAN configuration.
Jun 15, 2008 | NetGear WGT624 Wireless Router
Need help in connecting to the internet using Dlink 704p router.....
it doesn't matter whether the other computer is set to static and the other one is set to dynamic as long as both computers are getting/using valid ip addresses.
if i got it right. 1 computer is connected to the LAN port of the router and the other computer is connected to the WAN port. if so, you need to connect both computer to the LAN ports and the WAN port of the router should be connected to the modem that you are using.
if the physical connection is correct, check how you are connecting to the internet through the modem. if you can access the internet from the modem without configuring anything, you just need to power cycle. turn off everything then turn on the modem first, wait for the lights on the modem to turn on properly before turning on the router then turn on the computers.
hope this'll help you but if not, just provide the following:
(1)ISP:
(2)brand/model of the modem:
so i can help you further.
Jun 04, 2008 | D-Link DI-704P Router
Linksys Wireless-G WRT54G Router Logo
48 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
