Question about Nintendo Wii Console
My wii blew a fuse and i want to know what to look for
If my wii has blown a fuse, what would that fuse look like and where would it be located inside the console?
  • 1,525 Answers
Hello the fuse inside is made of glass if you open the wii up you should see the power supply the fuse might have a cover over it, if the fuse is black it's blown, if you put a nother 1 in and blows again the then you have a dead short somewhare make sure the power off. good luck.
shaun
Posted on Nov 13, 2009
RMS PM 10400s not turning on suddenly
They may have ran it too hard and blew the outputs and thus blew the main fuse. You will have to check to see if the main fuse is blown...It should be located around the ac cord...sometimes it is built into the ac receptacle where the cord plugs in...other times it is inside the unit and requires dis-assembly which should be taken to a qualified technician......unless you know what you are doing...and do not plug the unit in while you are looking for the fuse or taking the unit apart. If you do not know anything about electronics then DO NOT touch it...get a qualified techician to take a look.
Jan 19, 2014 | Rms PM10400S 10 Channel Powered...
I was putting a new radio in my car,wires touched and shorted and blew a fuse,i replaced fuse but now my car wont start.Ignition was on when fuse blew
Hi, check the remainder of the fuse's chances are you have blown more than one fuse, if they are all ok then you may have blown one of the main fuse's which are located in a fuse box in the engine compartment.
Jul 17, 2011 | Ford Futura Cars & Trucks
Tried to install a radio and blew a fuse and now dont know wat fuse is blew the interior lights want come on and the clock dont come on
Clock and interior fuse is blown its the same fuse, Main power for the radio fuse is blown also
Oct 22, 2010 | 1995 Ford Taurus
No power
The outlet that the unit plugs
into... Is it 'hot'? Plug in a known working Table
Lamp. If you have power, the problem is the unit.
Where the cord goes into the unit, locate the Power
Supply. Carefully check for any cracked, blackened,
or broken components. My educated guess is that
a small fuse blew, as did the Metal Oxide Varristor,
which is either a large blue or red disc shaped component
near the power transformer. If the fuse is blown black
inside the glass, this indicates a short, and would require
an Ohm Meter to locate it. If the fuse is blown so that
the element inside just melted open inside the glass,
this indicates an overloaded condition, and would require
that the fuse be replaced with a rating 1/4 amp greater
than the original fuse. Why? because most fuses are
under rated to insure that they will need service to keep
people like me from starving! Trust me on this one.
good luck!
Jun 26, 2010 | Memorex MVD2042 DVD Player
Athena AS-P4100 Sub Woofer - blown main fuse - who repairs these?
Sorry I can't solve your problem. I think the main fuse on mine is blown too. Can you tell me where it is located?
Mar 09, 2010 | Athena AS-P4000 Subwoofer
Put the battery in backwards. Now the car will not start. I know I blew the starter relay because the lights and radio didn't work inside. I replaced the relay. The inside lights work now. But the car...
Check all of the fuses & relays in BOTH fuse boxes. There's one fuse box under the hood, just 'north' of the battery. There's a second fuse box under the dash.
Feb 10, 2010 | 2004 Hyundai Tiburon
I blew out the fuse to the cigarette lighter under the dash and do not have a diagram as to which fuse it is,...? help
It should be marked on the body of the fuse box as "cigar" next to the fuse it represents.
Jan 05, 2010 | 2003 Ford Crown Victoria
My wii console will not power on. have checked all plugs and everything is connected and outlet has power
HI. the power supply board has failed. There is a fuse(3amps) inside the power supply unit. you will need to remove the cover from the power supply to access this fuse. once inside the power supply, inspect the fuse. if it is truly blown, replace it. if the fuse is not blown, this will confirm a failed power supply unit. it should be replaced in this case...
Aug 04, 2009 | Nintendo Wii Console
Blows main fuse when power is turned on
Shorted power supply/module is most likely problem.
May 27, 2009 | Sony STR-DE635 Receiver
Fuse location on tv
a fuse is a small glass tube about 3/4" to 1". it is located near the end of the power cord inside the tv. it is located in the power board supply circuit. there are several reason why fuse blew up. 1. sudden surge current/voltage in your area 2. shorted in either power supply or horizontal deflection circuits. when replacing fuse, be sure to change it with the same value. but if after replacement has been done and the fuse blew again, there is a short in the circuit as stated in reason no. 2. refer to a qualified service technician if you are not inclined with this job. good luck!
Feb 12, 2007 | Panasonic CT-32HXC43 32" TV
Nintendo Wii Console Logo
1,041 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
