Question about Ingersoll Rand Type 30 Fully Packaged Ir Electric Stationary Air Compressor No. 2475N7.5FP 7.5HP. 80 Gallon Vertical Two Stage
Unloader valve keeps opening and closing during pump operation. does not give a continuous discharge, as when the ball valve is stuck open. seems that when the pump reaches max output pressure that the unloader discharges the pressure from the pump, then closes until the max output pressure is reached again.
    Scholar:
  • 84 Answers
Sounds like the cutoff valve is failing to cut power off to the compressor drive motor, while it activates the unloader.--- I'd consider looking closely at the contacts, or replacing the cutoff.
Posted on Nov 24, 2009
Error 20 in dishwasher AEG 77012 wop
i20 error code means:
Water is not pumped off and could be:
  • Fault with discharge pump
  • Discharge pump deenergized (faulty wiring or no activation by electronics)
  • Obstruction/blocking (filters in the appliance, discharge opening in discharge trough, discharge pump, discharge hose, siphon, cover plug at siphon connection not removed during first commissioning)
  • Discharge hose bent or connection height above 100cm
  • Ball valve in discharge trough glued / blocked (discharge pump does not aerate)
or water level inside appliance is not detected and than
could be:
  • Pressure controller faulty
  • Pressure controller hose obstructed or bent
  • Insulation fault with heating element
Dado
Feb 19, 2016 | AEG Dishwashers
Why is my unloader valve opening and closing when I'm not squeezing the trigger\
thats exaclty what a unloader valve does it unloads the pump when the trigger on wand is not depressed , it should however reseat and close off when trigger is pressed giving full presure to wand tip
May 11, 2014 | Northstar Professional Series Pressure...
Hot tub stuck in PR mode.
Are the pumps primed, the code represents that the pumps are being primed and should only stay on 2 - 5 minutes. If the pumps are not primed then you may have an air lock or dirty filters. You need to release the air or clean or replace the filters and your pumps will prime.
Mar 27, 2014 | Pool & Spa
Super pump 11 keeps blowing the threaded adaptor off the discharge. I replaced the 11/2 inch pvc adapter twice. Both times the adaptor blew off. Any ideas.
Something is causing the pump to "dead head" which means it is trying to pump water through a closed pipe. Check any valves, the filter, heater etc.. downstream from the pump. Your water flow is being severely restricted. Hope that helps.
May 11, 2013 | Hayward Pool & Spa
I have a SSR-EP60 air compressor and am having a problem with it unloading. It would shut off for high pressure (145). I changed the air piston to the intake butterfly and seems to be a little better. I...
If the pressure continues to rise, the inlet valve is not closing completely. Remove the top of the air cleaner box and look down at the inlet valve butterfly. When the compressor is down or unloaded, the valve should be held closed by an internal spring in the air cylinder. If it's not, the mounting stud on the bracket may have come loose and moved, or more likely the spring in the air cylinder actuator is broken.
This actuator has gone thru at least 3 revisions. I just replaced the cylinder on our EP60 because the spring had broken in two places and wouldn't come anywhere near closing the valve.
May 26, 2011 | Ingersoll Rand Stationary Air Cooled...
I have a trailer mounted rotary type air ompressor that is powered by a four cylender ford. The precice detais are not avalible as the bass plates are unreadable, it is probly 20 years plus old. What he...
I assume that this is a rotary screw type compressor, when these unload several things need to happen, One is the inlet valve must close,, (depends on design as to how far closed!) then a valve called a blow down must open on the sump lid,,, this usually vents to atmosphere either using a silencer or dumped back to above the inlet valve. then one other factor that comes into play is the discharge check valve that prevents the "system air" from coming back to the tank. This valve varies in design from model to model and is sometimes combined with what is called a minimum pressure valve. A good working knowledge is a must to service problems like this as personal injury is a possibility when working on some of these items.
Mar 07, 2010 | Ingersoll Rand Air Tools & Compressors
Compressor wont restart because of head pressure
Piston air compressors have to unload to permit a restart, the two mot common types are an unloader valve or free air unloaders.
with an unloader valve this system uses a check valve mounted in the discharge line as it enters the tank, when the pump stops this check closes and does not permit the tank pressure to return to the pump. a unloader valve also opens to allow air pressure in the discharge line to vent, this valve is either on the pressure switch or on some models is on the pump, and is a centrifugal type.
Free air unloaders or head unloaders are a set of fingers that hold open the intake valves on the cylinders to permit the piston not to pump air against a head load, and once the pump is running the fingers retract to allow the pump to function as normal.
Jan 19, 2010 | Air Tools & Compressors
Karcher G3050OH Pressure Washer Spill / Unloader Valve (Bypass)
You should put 'locktite' on the male thread and screw it in all the way and lock it there. That is how it works ,the spring keeps the valve at the bottom closed during high pressure operation. When the gun is released the part with the o-ring is forced down resulting in the valve opening and then the pressure is by-passed.Those dont normally give trouble. Look for a blocked nozzle or a restriction somewhere in your high pressure hose.
Sep 07, 2009 | Karcher 2500 PSI Pressure Washer
Coleman Powermate Model Number BV6548049, pressure switch leak.
Usually, a leak at the pressure switch unloader valve is caused by the checkvalve in the tank. The unloader valve at the pressure switch bleeds out the air from discharge tube after compressor reaches set pressure. This only takes a few seconds. If air continues to leak then air is leaking back into the discharge tube past the tank checkvalve. Follow the air discharge line from the compressor to the brass valve at the tank. The brass valve is the checkvalve that holds the pressure in the tank. There are usually two connections at this valve. One is the unloader tube to the pressure switch. Simple test for leaking checkvalve, with pressure in tank unplug or switch off the compressor and remove the small unloader line at the checkvalve(brass valve) and look/listen for leak. If leaking, remove the checkvalve and examine seat/check for debris keeping the valve slightly open. If it cannot be cleaned, order generic replacement from www.grainger.com. It will cost less than the factory checkvalve. Just pay attention to the thread sizes for easy fit. Good Luck on your repair and email if you have questions.
Mar 25, 2009 | Coleman Powermate 60 Gallon Air Compressor
Karcher K2400 pump is cycling on and off during operation
if this is occers when at rest it could be the pump non retern valve, witch will be just in side tghe machines outlet behine the chemical injector, you will need to unscrew the injector and the valve sits behind it, if this happens when at use it could be a blocked nozzle
Mar 23, 2009 | Alfred Karcher K2400HH 5 Hp 2.5 Gpm @ 2400...
Ingersoll Rand  Type 30 Fully Packaged Ir Electric Stationary Air Compressor No. 2475N7.5FP 7.5HP. 80 Gallon Vertical Two Stage  Logo
563 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
