Question about Creative Labs Inspire 2500 Computer Speakers
I have given additional ac supply to it something went wrong now it is not working
    Sergeant:
  • 199 Answers
Hello there!
Your wofer and speakers can't work because something is wrong could be a IC, diode , Transistor pls you need a multimeter to check this burnt items for faults ,you overloaded the sytem
The additional AC killed your woffer ,the woffer is the one that feeds the speakers with AC now you over fed it am sorry to say this .
Posted on Nov 13, 2009
    President:
  • 1,884 Answers
Rohit, With additional AC supply you have most likely burnt the amplifier. But there may still be hope if only the power supply unit of the device has been burnt. Open up the rear panel of the unit that has the power cord coming into and look for burnt and burst components. The whole modules would have to be replaced with exactly the same specs.Do it. if you feel that you cant handle it then go to the service center of the brand that you have.
Dometic AC B59516.711 15,000 BTU, while on generator power the AC works during day while it hot but once the sunsets and it cools down, compressor kicks on it drags the gen down and shuts it off.
something else besides the ac is stopping ( overloading) the genset
if it works well during the day, the compressor has to be working so the ac is not the problem
a 4000 watt gen set has a duty cycle load of around 3000 watts full time so any additional power requirement besides the ac will overload it
electric stoves , microwave ovens , hot water elements , anything that consumes power after dark will when combined with the ac will overload and shut down the gen-set
Jun 26, 2017 | Electrical Supplies
Will not work without battery.
most need it in for extra back up power they sell new ones on ebay for all too ok
Mar 16, 2008 | Televison & Video
Toshiba satellite a205 will not turn on is it the power supply regulator on top rear panel?
Check AC power cord, use a different one, also plug into different outlet. If that doesn't work power switch is bad. Or something else is wrong.
Feb 13, 2014 | Toshiba Satellite A205-S4617 Notebook
Battery won't charge even with a new battery
There could be something internally wrong with your laptop. Take it to a reputable dealer to help fix the problem.
Jul 10, 2017 | Toshiba Portege R705-P40 13.3" Notebook PC...
Problem Event Name: APPCRASH Application Name: czero.exe Application Version: 1.0.0.0 Application Timestamp: 00000000 Fault Module Name: kernel32.dll Fault Module Version: 6.0.6001.18215 Fault Module...
hi,
well this error leads to application crash that means either you did not install app correctly or something went wrong in PC try this
Start - Run - net localgroup administrators NetworkService /ADD
Hope this works for you
Jul 09, 2009 | HP Pavilion dv2000t Notebook
Was driving and the ac went out and power steering
Sounds like a belt has gone.
Have a look at the front of the motor if you can see pulleys with no belt on them that will confirm it... Any auto parts store should be able to supply a replacement given year and model details.
Jun 26, 2009 | 2002 Suzuki XL-7
Xerox Phaser fault 37,002,47:18505
37,0XX.xx Errors - PEST Faults
AC power supplied by power sources such as uninterruptible power supplies
(UPSs) or DC-to-AC inverter systems may not supply correct voltage to
properly power up the printer. Likewise, other devices sharing the same AC
circuit can cause AC voltage sags that cause the printer to fail its AC heater
PEST tests (Print Engine Self Test). The printer may produce any of the
following disconnected heater errors:
■ Printhead jet-stack 37,002.47 or 37,003.48
Error Messages and Codes
■ Reservoir heater, 37,004.40 or 37,005.41
■ Drum heater error 37,006.42
■ Preheater error 37,008.44
■ Ink melters errors 37,009.45 thru 37,013.40
The printer includes several heaters powered by AC. The printer itself can
power up despite insufficient or irregular AC voltage but it may fail its AC
heater tests. This is due the test not measuring sufficient current flowing
through the heater at the moment the test runs.
Devices sharing the printer’s AC circuit shared, such as a laser printer, a
coffee maker, or a space heater, may be placing heavy intermittent demand
on the AC circuit. This sudden inductive demand creates momentary AC
voltage sag that causes the PEST test to fail.
Verify the AC power source prior to troubleshooting these errors. For wiring
diagrams to aid in diagnosing PEST faults, see “Wiring Diagrams” on
page 10-1.
8400/8500/8550/8560 PEST Description
37,001.46: Generic PEST error.
Something went wrong during the PEST process.
37,002.47: PEST Error - Printhead Left jetstack disconnect. The left jetstack is
not drawing the expected power from the supply.
Mar 17, 2009 | Xerox Phaser 8400 Laser Printer
Toshiba p-200
try another wall outlet first. if it still doesn't turn on. then you going to need a meter in order for you determine if the power supply is at fault.
put the postive (red) lead to the positive side of the power supply output lead (+) and the negative to the negative. if your read 12V on the meter. the power supply is good.
if the power supply is good. then, take out the battery out of the laptop. push and hold the power button on the laptop for 20sec (resetting the laptop). replace the battery and the AC. if that don't work. then you have other power problem.
please email me (frcs68@hotmail.com) if any additional question you may have.
thank you
Oct 03, 2008 | Toshiba PA2502U - Libretto 100, 110,...
Dead laptop
Check the ac adapter is the proper one for that laptop. Check the power jack is not damaged or loose. let laptop site without battery or power for a few hours. remove battery and retry power. try another ac adapter if that doesn't work, you may have a reset button but not likely to solve the problem. sounds like motherboard is damaged, or something blew.
Aug 27, 2007 | Compaq Presario M2000 Notebook
Creative Labs Inspire 2500 Computer Speakers Logo
115 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
