Question about Electrical Supplies
Will start wont stay running over minute and cant find a manuel
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 44 Answers
It sounds either there is not enough oil in the engine or the low oil sensor is failing when the oil heats up. There are 2 parts to the oil sensor system, ususally it is the CDI that has blown. To test this (assuming the picture on the question is your generator) unhook the yellow wire that comes out of the front of the engine. Start the generator. If it keeps running without it attached then you need to replace the CDI.
We sell the parts if you need them.
Have a portable generator question? We are always happy to help. Generatorguru.com Generator Guru
Posted on Oct 08, 2014
  • 10,865 Answers
Most likely your carb. is gummed up. Drain out any old gas [over one month old] and replace with new. Change the spark plugs. And, add a carbeurator cleaner [ from any autoparts store]. Then start it up and let it run, restart it and let it run, restart it and let it run until it will run for as long as you want it to.
Posted on Nov 13, 2009
I have a FDL70S1 Frigidaire 70 pint dehumiifer that runs for 3 minutes then shuts off. I have tried to set the timer for it to run longer but it wont. Do you know what is wrong with it?
Hello lynn crisp, thank you for your post!
From what you have explained regarding your Frigidaire dehumidifier it sounds like the sensor or control panel has become faulty. I would recommend resetting your dehumidifier and you can do that by unplugging the power cord for ten minutes. Is your dehumidifier under warranty? If so, you may want to reach out to the manufacturer for a resolution to the problem. I hope this information is helpful. -Matt
Oct 20, 2014 | Frigidaire Dehumidifiers
New augar motor wont run even in manuel
Try putting power directly to the auger. If it works then you need to see why you have no voltage on the auger motor terminal. Could be a problem with air flow vacuum switch, or loose/wrong wiring.
Feb 28, 2014 | Breckwell A-P22-EXT Maverick SP22 Pellet...
Isuzu rodeo wont stay running
Fuel pump / Fuel filter ? ?
Nov 09, 2013 | 2004 Isuzu Rodeo
Cant get car to stay running has fuel delivery starts with chem start but wont stay running
replace the fuel pump relay
the priming switch operates fine if starts although after the priming switch does its job the fuel pump relay takes over
Sep 06, 2010 | 1992 Buick Regal
1991 cadillac wont stay started,it happen after tw...
I would try running some fuel tests to see if pump is working.
May 20, 2010 | Cars & Trucks
Pw 50 cc starts but wont stay started as soon as u go to
Are you aware the PW50 kill switch has a separate start and run position which will cause exactly that problem. it is a safety feature so the things cant be started with a full throttle and hurt the kids. If you already know about the switch sorry. but it still may be the problem if it is not contacting properly in the run position
Apr 16, 2010 | Yamaha G5 Motorcycles
88 fiero starts on it own, but wont stay running.
the brain is not sending the proper fuel pressure codes to the fuel rail to evenly distribute the fuel to the intake and fuel rail.
perform a fuel pressure test check on it ok? also run a diagnostic scan on it and see what codes come out.
Jul 25, 2009 | 1988 Pontiac Fiero
Cant get truck to stay running
did you try the fuel filter
May 20, 2009 | 2000 GMC Sierra
92 lesabre runs 4 minutes and dies
Make sure and check your ignitioin fuse if its out the car will start it just wont stay running verry long sometimes in most cases will turn over but not start
Dec 29, 2008 | 1992 Buick LeSabre
Electrical Supplies Logo
119 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
