Question about Cell Phones
Cannot slide unlock my i9 mini cell phone
Hi
Recently I bought an i9 mini.
I've installed few games on my phone, but i was not able to uninstall that. so i reset the mobile to factory settings, after restart the touch screen doesn't work. In some mobiles the calibration screen must appear. It didn't happen.
please help
Roopak
How do i delete the java games on my cect i9
Being that the game is on the cell phone memory not the external memory... be very cautions on deleting...go to the game it self and go to options (you can delete from cell) before starting
May 11, 2010 | AT&T CECT Unlocked i68+ Quadband GSM FM...
How do i unlock my sciphone i9
The SciPhone i9 is not locked to a specific carrier from the factory. That is, it comes from the factory SIM unlocked.
Jan 27, 2010 | Dual Electronics CECT P168 Cellular Phone
I recently bought a sciphone i9++ and i dont know how to install java...Can yu give me the step by step procedure on this
You don´t need to install java. It is already installed.
Just put Java applications (jar files) into the Java folder and run them by double clicking.
Oct 18, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
How do i delete apps from an i9 that are factory
Most i9 phones come with one or several games, & the answer is probably NO, you will not be able to delete them or delete their icons from the menu screens. Go to the Java menu & select the program or game. Is there an option to Delete or Uninstall it?
If there isn't, then you cannot delete or uninstall the application. The only way to get rid of them would be to find a different firmware & flash it to your phone.
Aug 24, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
I9 3g java installation problems
i9 3g is a secure telephone so you wont be able to inistall any java game.
Jul 03, 2009 | Cell Phones
Apps for cect 3G i9 touch phone and english java games
Ok you should be able to go into JAVA on you i9 phone and select OPTIONS and delete the chinese games. As for other apps, I have not been so successful in finding the ones that are like the apple phone but here is a site that has games for your phone www.getjar.com
You do have to select your phone but here is the link with the i9 already selected :
http://www.getjar.com/software/CECT/A1000
The games are ok but it dinda makes you feel like you just bought a portable Nintendo ES....
Feb 19, 2009 | Cell Phones
Cect i9 slide to unlock will not open
THIS WORKED FOR US: Hold down the power button until you see the "CANCEL" icon; tap around the screen until the "CANCEL" button turns blue - this will take you back to the slide feature. MAKE NOTE OF WHERE THIS SPOT IS ON THE SCREEN. Repeat the "cancel-screentap" process to find a 2nd spot in another area of the screen. While on the "slide" screen, draw a line between the 2 spots; when you return again to the "slide" screen, the "slide" should work.
ONCE YOU HAVE OPENED THE PHONE do 2 things:
  1. RECALIBRATE the screen
  2. LENGTHEN the screen saver time-out to something other than the shortest time available.
Hope this works for you - GOOD LUCK!
PS - dunderground posted the following solution in Apr 2009:
"The fastest way is to be on the slide-lock screen & hold the side volume button in the Up position until "Press volume down key to check" comes up onscreen. This may or may not work on all firmware versions on the current i9, but works on most. Make sure to hold the button firmly in the Up position. You will first see the normal volume speaker icon show onscreen and the volume rise, but just keep holding it Up, and eventually you should see the pop-up box noted earlier. The moment you see that pop up onscreen, immediately press the side volume button in the down position. A white calibration screen should now show & you can calibrate the touch screen using the stylus."
Jan 20, 2009 | Dual Electronics CECT P168 Cellular Phone
My i9 phone's slide to unlock feature wont work
THE I9 IS A JAVA BASED JAVA APP PHONE THE JAVA APP THAT RUNS THE SLIDE TO UNLOCK FEATURE HAS MALFUNCTIONED THE ONLY WAY IS TO HAVE A TOTAL FIRMWARE RESET BUT AT THE MOMENT CECT ARE NOT SUPPORTING THIS YOUR ONLY HOPE IS TO CONTACT THE SELLER OF THE PHONE AND TRY TO GET A REPLACEMENT HOPE THIS IS OF SOME HELP THERE IS A CECT FORUM IF YOU SEARCH GOOGLE
Jan 19, 2009 | Apple iPhone Smartphone
Cell Phones Logo
118 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
