D-link i cannot get my d-link wireless g kit to connect with my home computer and my daughters laptop
  • shaz100 Jan 10, 2008
    hey guru treid what you said about typeing in ICONIFG. BUT ITS COMING UP ICONIFG IS NOT RECOGNISED AS AN INTERNAL OR EXTERNAL COMMAND,OPERABLE PROGRAM OR BATCH FILE anyother ideas thanks shaz100
    Novelist:
  • 101 Answers
Hi Shaz,
Shutdown everyithing, including the PCs, on your network. Make sure your Ethernet cable from your internet, (Modem) if plugged into the WAN or internet port. Power up the Modem, wait 2 min. Power up the router, wait 2 min. Power to your PC. Go to STARTt>RUN>type in CMD. Press Enter. In the black bix that opens, type ICONIFG.
Look for your IP Address. It should be 192.168.x.xxx. (X can be any number up to 254.) Subnet should be 255.255.255.0. Gateway IP should be 192.168.x.1.
If your IP address is 169.xxx.xxx.xxx, you are not connecting to your router. Check your firewall settings, and connection.
Good Luck.
Posted on Jan 09, 2008
6ya staff
SOURCE:
My daughter is trying to use her laptop at home. where do I find the security code for my netgear router
The encryption code is configured in the wireless settings.
Connect a LAN cable from the Netgear to the LAN port on your computer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the default admin password and configure the wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Sep 03, 2012 | NetGear Computers & Internet
My daughters Dell inspiring computor no longer logs onto the Internet at home through our wireless network. It seems to have frozen onto an unidentified network from a public place and I can't seem to get...
The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers cancommunicate with your wireless router.
Mar 11, 2011 | Dell Computers & Internet
I have an HP Pavilion dv4. The wireless connection disables when the computer is bumped or moved. Also, the computer will freeze up and shut down when it is bumped. I read a forum that said to go into...
Sounds that the wireless adapter daughter board is either loose or failing. First, we need to make sure it is making good contact with the laptop's motherboard. In order to do this, we have to do the following:
1. Turn off the laptop & remove the battery.
2. Look at the compartments in the bottom of the laptop. You should be able to see 2 or 3 areas with small rectangular plates covering them. These plates usually have one or 2 screws holding them in place.
3. Check which one of those plates is the one which covers the wireless adapter daughter board. When you find it unscrew its screws & remove it.
4. Below the plate, there will be a small daughter board screwed to the laptop's motherboard, with 2 thin wires attached to it (usually one black wire & the other is a white wire). Gently, remove both wires using a small flat screw driver to pull them out gently. Don't forget to note down which wire connects to which connection point.
5. Unscrew the wireless adapter daughter board & remove it from its slot.
6. Clean both the slot & the daughter board's terminal connectors using a dry electric contact cleaner. You can purchase it at an electronics store.
7. Leave the slot & the daughter board for a while to dry.
8. Re-place the daughter board back in the slot & screw it to the motherboard.
9. Reconnect the 2 wires.
10. Screw back the covering plate.
11. Put back the battery & turn on the laptop. Check if the problem was fixed.
If this did not fix the problem, you will need to repeat the steps to remove the wireless adapter daughter board & replace it with a new one.
Oct 26, 2010 | HP Computers & Internet
Laptop cannot pick up wireless from modem
Is your Wireless router integrated in the modem? If it is not, try to unplug the router for a few minutes then restore the power and see if it fixes the problem. If it is integrateddo the same for the modem. Try to connect using the laptop. If it does not work use the laptop to scan for new wireless locations and make sure you see the home location. If you do not your wireless router is not working, If so select the home location and enter any Web Encryption Protection and try to connect. If your wireless router is not working, make sure the preference for the router has the wireless function turned on. To do this use ether the software which you received with the router/modem or internet explorer to access the IP address of the router. If your router is configured for wireless use it may be a bad wireless router.
Feb 05, 2010 | NetGear CG814M (pn-3201155) Modem
I can connect my laptop using the ethernet cable. My daughters laptop works with the wireless, but I cannot connect my laptop via wireless. My laptop indicates that it has excellent signal strength but I...
make sure you putting the wep key proper and use the same wireless key which is configure in to your daughter laptop. and also try tio ping the wireless ip address to make sure the connection is proper.
Have a nice day and do not forget to rate please...!
Feb 02, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Will not connect another computer
you have to set up the WEP key. Open internet explorer and enter 192.168.0.1 and click on the wireless tab to set up the security key - there you can create a WEP, or WPA key - remember the key so that you cab enter it into the laptop.
Nov 28, 2008 | Linksys Wireless-G WRT54G Router
I've just purchased DKT-110 wireless G starter kit.
The Internet/WAN port on the router should be connected to your cable modem's internet port.
Then on your laptop, you should click on "View available wirless networks", your Router should show up there. click connect and you should be able to surf.
Note::The USB DWA 111 should be connected to your laptop and the drivers installed
Please remember to rate all users who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 30, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Wireless connectivity
You need a PCMCIA wireless card in the laptop to connect to your ACCESS POINT to communicate with the Internet and your "home" networked computers.
Sep 24, 2008 | Toshiba Computers & Internet
Emachine model t3302 ethernet card
This is how the wireless world works. You buy a wireless router with a four port switch. Your DSL or cable connects to that. A cable called a Rj45 connects the DSL or cable to the back of the wireless router. You also buy a wireless network card for your PC. After running the software for the router & the wireless nic card including setting up a home network through windows your daughter will be able to connect that computer to your network from any room in the house. Below is a link to a wireless router:
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10005578
You can connect up to four computers to the wirless router. A computer that does not connect to the router by a Rj45 must use a wireless network card. Linksys WMP54G Wireless-G PCI Adapter Retail: http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=252286
As you will see there is a big differance between a NIC card & a wireless card.
Jan 01, 2008 | E-Machines eMachines Desktop PC
Open Questions:
Avira Antivirus tEcH sUpPoRT pHoNe @#@[+l855*26O*[email protected]] nUmBeR USA Avira Antivirus USA phone number {+l855~26O*OO64^} is ranked Avira Antivirus is one of the biggest companies in the world which is providing its services. It has invested in various functions and can provide the best when we compare to others. So if you are interested in having the services, then you should not think twice. Avira Antivirus email Toll free Number. Once the person has those, then the user will be able to get the help from the user in a way which is going to make his experience a euphoric one. So dial the number whenever you are facing the problem. Avira Antivirus support number When you are using the Avira Antivirus for the cable, telecommunication, internet services or anything, then you will find it to be the best. The user will find that there is no other option when it comes to the quality of the services they provide. But even after that, the user can dial the Avira Antivirus support number and ask for the help. Once you dial the Avira Antivirus customer support number, you come in contact with a team of experts at the Avira Antivirus customer service. They will be able to help out the user with any situation in which they are stuck. So whenever the user feels that he or she is stuck, then there is no need to make any rash decisions. As the team on the Avira Antivirus support phone number will help you with that simply and quickly support number
Nov 11, 2019 | HIS Computers & Internet
Mcafee Antivirus tEcH sUpPoRT pHoNe @#@[+l855*26O*[email protected]] nUmBeR USA Mcafee Antivirus USA phone number {+l855~26O*OO64^} is ranked Mcafee Antivirus is one of the biggest companies in the world which is providing its services. It has invested in various functions and can provide the best when we compare to others. So if you are interested in having the services, then you should not think twice. Mcafee Antivirus email Toll free Number. Once the person has those, then the user will be able to get the help from the user in a way which is going to make his experience a euphoric one. So dial the number whenever you are facing the problem. Mcafee Antivirus support number When you are using the Mcafee Antivirus for the cable, telecommunication, internet services or anything, then you will find it to be the best. The user will find that there is no other option when it comes to the quality of the services they provide. But even after that, the user can dial the Mcafee Antivirus support number and ask for the help. Once you dial the Mcafee Antivirus customer support number, you come in contact with a team of experts at the Mcafee Antivirus customer service. They will be able to help out the user with any situation in which they are stuck. So whenever the user feels that he or she is stuck, then there is no need to make any rash decisions. As the team on the Mcafee Antivirus support phone number will help you with that simply and quickly support number
Computers & Internet Logo
181 people viewed this question
Ekse
Marvin
Marvin
