Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
WHILE BROILING F10 CODE CAME ON STOVE DOES NOT WORK
  • 48 Answers
Need model number to what f10 relates to .
Posted on Nov 13, 2009
Have Frigidaire Gas oven FFGF3053LSF. We had a power surge & F13 code came on display. Power restored, clock works, F13 code is gone- but now a DR code comes on when I push bake or broil button
answered on another appliance site..
https://www.justanswer.com/appliance/9dp3z-tyler-i-frigidaire-stove-with-dr-error-code-oven.html
the F13 indicates that you have an EEPROM (Electrically Erasable Programmable Read-Only Memory) error in the clock control board of the range. You can unplug/turn off breaker to the range for 1 minute and then plug/switch it back on. This too may possibly fix the DR.. maybe?!
Feb 12, 2018 | Frigidaire Ovens
How do get rid of F10 which is on the window of my Kenmore stove
The F10 error means that the high temperature sensor is reporting a runaway temperature and shut down to avoid a potential fire. Try unplugging the stove or tripping the circuit breaker to reset the code.
If the error recurs, unplug the stove (or turn off the circuit breaker) again. Look at the broiler and bake elements with a flashlight. If it has any damage (breaks, char, melting), you will need to replace the element. Check where the elements connect to the oven and replace them if there is any charring on the back wall.
If the elements are undamaged, you need to check the wiring to identify if the problem is at the elements, the high temperature sensor, wiring or the control board. You will need to access the wiring from the back of the stove. Disconnect the wires to the heating elements. Then disconnect the wiring connections at the high temperature sensor and the control board. Without a model number, I can't be completely sure of the resistance that should be seen at various points. Please post a comment with the model number of the stove and I'll try to confirm the expected and faulty resistance values. Most likely, the resistance should be under 50 ohms but above zero between the left and right contacts of the elements and the violet wires in the wiring harness at the control board. The high temperature sensor should probably have a resistance between 1,000 and 1,200 ohms. If the resistance is high, you'll need to replace the appropriate parts. (Note: if the wiring at the control board gives a reading similar to the resistance of the high temperature sensor, the control board is the likely suspect.)
I hope this helps. If your stove is under warranty, contact Sears/Kenmore to fix the issue. If you aren't comfortable testing the wiring, contact Kenmore for a service call.
Feb 04, 2015 | Kenmore Ovens
Whirlpool stove pf
A pf code usually shows up if the power to the stove has been interrupted for a short time. It is usually cleared by setting the clock or setting the oven or broil.
Nov 20, 2013 | Ovens
Crosley oven dont work f 10 gas
The "F10" oven error code means "Runaway temperature"
try this link http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/70424-what-does-f10-error-code-mean.html#ixzz2VTV50IJ4
Jun 06, 2013 | Ovens
After broiling steaks, f10 appeared on screen and constant beeping since. 1-2 hrs now. turned off electricity and keeps beeping.
Press the Stop/Clear button. If that doesn't work, press it and hold for 3 seconds. If you get a fault code, something is broken. If it is associated with broiling, the first thing I would check is the broiler temperature sensor. Is there a buildup of grease on the ceiling of the oven?
Jan 10, 2011 | Kenmore 47783 Electric Single Oven
Kenmore stove model# 665.92024100 While cooking
Check and see if the broil element has shorted to ground.
Bonus
Apr 13, 2010 | Kenmore Ovens
Bottom filament on bake not working but broil and
FAULTY ELEMENT OR THERMAL SWITCH. HAVE IT CHECKED OUT BY AN ELECTRICIAN.
Sep 07, 2009 | Stoves 720EF Electric Double Oven
Bake and Broil not working
After you hit the function you want...bake or broil...click the up arrow.  That should give you the default temp of 350 and the unit should light.  Now adjust to the temp you want.
Nov 28, 2008 | Ovens
Problem with Kenmore Electric stove
I have kenmore stove mod.790-95660103 you turn on any top burner . T he small one inside the big burner comes on Roy
Nov 24, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
151 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
