Question about Praktica DCZ Digital Camera
Praktica dcz 8lm camera: when turned on the light comes on for a second then goes straight back off again. won't take pictures or allow you to view pictures on pc
    President:
  • 2,761 Answers
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Posted on Nov 15, 2009
Camera wont switch on praktica dcz 8 lm busy light comes on 3 seconds then off and nothing after that
took the memory card out and then turn on the camera. Now see the busy keep coming or its gone. If not showing busy any more then format the memory card and then try to turn on the camera with inserting the memory card. Thanks.
May 23, 2012 | Praktica SlimPix Digital Camera
What cable do I need to download pictures from my DCZ 7.4 camera to my PC?
The manufacturer's website does not indicate the type of cable needed.
http://www.praktica.de/index.php?id=21&L=1&tx_prdigital_pi1[showUid]=347&cHash=2ef074a2c3
However, it uses a common type of memory card SD.  You can take out the card from the camera, insert it into an SD card reader, and the reader's USB jack into the back of the computer. Your photos can be downloaded at Start/My Computer/ and click on the SD card volume (E: or D: etc ) and open any folders inside to see your photos, copy and paste them to your hard drive.
Alternately use picasa software or the irfaniew viewer from www.irfanview.com to import, view and edit these photos from the SD card.
Dec 09, 2010 | Praktica DCZ2.2S Digital Camera
I CANNOT FIND THE INSTRUCTION MANUAL FOR THE PRAKTICA DCZ 8LM CAMERA
Hello
OK, at the l;ink below you will be able to download the manual in PDF format free of charge.
Click HERE to navigate to download page.
Fell free to contact me if you need any further assistance.
Kind regards
Andrea
Sep 25, 2010 | Praktica DCZ Digital Camera
Praktica dcz instruction manual
0e94afd.jpg May be this will help a little bit. Manual can not be found.
Jan 29, 2010 | Praktica DCZ Digital Camera
White appears pink
I contacted Praktica Support and it seems that the camera is faulty and needs to be replaced. It was the white balance faulty.
Jan 06, 2010 | Praktica DCZ 5.4 Digital Camera
Praktica dcz3.2s
Check this website for updated drivers.
http://www.opendrivers.com/freedownload/247962/praktica-dcz-3.2s-digital-camera-driver-download.html
If the problem still exists, turn off you computer, connect the camera and restart the computer.
The operating system may install kind of a generic driver to allow you to access the camera a a simpkle 'mass storage device.'
If it finds and installs drivers, the camera will appear as a 'removable disc drive' that you can access as any other drive although you may have to open nested folders to see your pictures.
Jun 05, 2008 | Praktica DCZ3.2S Digital Camera
Praktica dcz unable to delete photos and take picture
You probably have a memory card in your camera.
Remove it and check for a nearly microscopic slide switch on one edge.
This is a 'protect tab' and will not allow you access to memory unless it is properly set.
May 20, 2008 | Praktica DCZ3.2S Digital Camera
Praktica DCZ Digital Camera Logo
200 people viewed this question
Top Praktica Cameras Experts
Are you a Praktica Camera Expert? Answer questions, earn points and help others
