Question about Kenmore Washing Machines
My washer has started making a high-pitched noise while spinning.
    Problem Solver:
  • 7 Answers
I agree with solution number one, however after my washer made all kinds of squeals, high and low I called for service on it, and all it needed was for the bearing to be oiled. It worked just fine for 2 years and then a week ago the washer started making all the noises again. I took the front washer panel off and oiled the bearings my self with a high quality oil. Make sure you do NOT get any oil on the belt. Its working just fine again and saved us a hundred dollar service call. Woohoo
Posted on Jul 19, 2010
    Brigadier General:
  • 3,513 Answers
Hi
to chek what is wrong follow the bellow instruction....
Check the motor bearings
If your washing machine is making a high-pitched whine or squealing noise while running, the main culprit is usually worn motor bearings. To check the motor bearings, remove the belt and run the motor by itself, listening for the noise. If it makes the noise, than the problem is most likely the result of worn motor bearings and has nothing to do with issues in the rest of the washer.
Check for Obstructions
Sometimes coins, bra underwires and other metal objects come loose in the wash and become stuck between the tub and the drum. Using a flashlight, take a good look inside the washing machine. If you see dents, scratches or dings, that's a sign that there either are or have been items bouncing around in there that can make a horrible racket.
Check for Grease Spatter
A high-pitched squealing can be caused when the grease thins around the bearing that's located under the tub. Open up the washing machine and check the interior for grease spatters or spots. That could mean that the grease has thinned out around the bearing and it's making the noise because of rubbing.
Check the Drum for Irregularities
Spin the drum by hand, listening for the noise. If it makes the noise in the same spot with each rotation, the problem could be with the washing machine drum itself. Parts of the drum can corrode over time, leaving it vulnerable to cracks or rust.
Thanks for contacting fixya.com
Posted on Nov 13, 2009
3 Suggested Answers
dididsaythat
  • 291 Answers
SOURCE: kenmore elite washer 26922
I would take body of washer find out where noise coeing from.. got 2 screws in each side of head, flip head up and take clamps off .. pull whole body off washer run thu cycle and see if ya can locate the noise.. sometimes water pumps get something in them that well make weird noises.. but are in all cycles.
Posted on Sep 07, 2007
  • 107 Answers
SOURCE: high pitched screeching noise when in spin cycle
Sounds like something is in the pump or the pump bearing went bad. The pump runs CONSTANTLY in agitate, it runs backwards and spin and drain the motor reverses, so if there's something in it, it'll make noise the entire time.
Posted on Mar 25, 2009
Why is my Haier washer making a loud high pitched noise?
No. The high pitched noise did not originate in the control panel but rather in a part of the machine that was chafing or rubbing against something. And now the mechanism is stuck. Check for that first before messing with a control panel.
Sep 16, 2016 | Haier Washing Machines
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Kenmore - high pitch noice during spin cycle
Sounds like bearing squeal,providing no leaks or shake leave meantime
Jul 01, 2012 | Kenmore Washing Machines
How do I fix a high pitch noise when spinning?
If your washing machine is making a high-pitched whine or squealing noise while running, the main culprit is usually worn motor bearings. To check the motor bearings, remove the belt and run the motor by itself, listening for the noise. If it makes the noise, than the problem is most likely the result of worn motor bearings.
Jan 28, 2011 | Asko W6222 Top Load Washer
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
High pitched screeching noise when in spin cycle
Sounds like the belt is worn and might need to be replaced. Let me know if I can do anything else. thankyou for asking.
Mar 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 80 series washer make high pitched whining noise
cold water screen in hose was half plugged causing it to either shut off the spin cylce due to lack of water or increase the spinning speed.
Hope this solves the problem.
Dec 10, 2008 | Kenmore 24032\24036 Top Load Washer
Atlantis won't agitate. Will spin.
hi thanks for the question if it was making a high pitch noise that's the transmission buy new washer but not a maytag a roper is good same ae kenmore thanks the appliance doc
Jul 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
The washing unit makes a high pitched loud noise
Check to see if you have a bra underwire or nail stuck in the spin tub. Look around inside the tub looking for something stuck in one of the holes. Dont use the machine until you find the problem or you cut the tub in half with like a nail or screw and then the machine has to be rebuilt $$$$
You may have other problems, However start here. Let me know if you have other questions
May 26, 2008 | Whirlpool LTE5243D Top Load Stacked...
Kenmore elite washer 26922
Sep 07, 2007 | Washing Machines
Washing Machines Logo
764 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
