Question about Panasonic DMR-ES40V DVD-Video Recorder
DMR-es40v f60 error - Panasonic DMR-ES40V DVD-Video Recorder
Problem for Panasonic DMR-ES40V DVD-Video Recorder with Built-in... Maching displays F60 as soon as it's turned on and
Posted on Jan 03, 2010
4 Suggested Answers
SOURCE: F60 Error message on DMR-ES40V unit
Unplug the unit.
Plug back in and wait till you see 000000.
Press and hold the power button in at least ten seconds or until the clock shows up.
This worked to fix mine.
Posted on Jul 22, 2009
steven_mower
  • 9 Answers
SOURCE: F60 ERROR CODE ON PANASONIC DMR-ES40V
Unplug the unit for 24-hours. I know, it should not take that long, but in this case I tried shorter periods WITHOUT success!
Just before plugging in unit depress and hold POWER button. You are supposed to hold it for 30-seconds after plugging in, but in my case I did it for 60-seconds. This results in a MASTER RESET that clears all errors, resets interlocks, etc. I could not get past a DVD failure problem, but when I discovered this process everything worked fine!!
Good luck! Hope it works for you too.
Posted on Jul 21, 2010
SOURCE: Panasonic DMR-ES40V, error codesF60 & U99...
Same problem. Contacted Panasonic. Technician indicated that there is a problem between the CPU and the timer. The unit is three years old and out of warranty, so he offered Panasonic's service at $120 for labor plus any parts.
So I gave it one more try. I pressed and held the REC on the Power button for about 10 seconds, which reset the unit. Then I was able to play a DVD and eject it.
Hope this helps with your unit.
Posted on Dec 01, 2008
Panasonic dmr-es40v
Ron, F60 is a general error code usually related to a failure on the video processing board. You could fix this by just replacing that board. Try to place it in standby mode first by unplugging it, wait a couple of minutes and then plug it back in. When the 000000's starts, hold down the power button for 15-20seconds. The unit should then be in standby mode. From this mode try to start it normally using the power button and see if it cleared the error. You could also try a complete reset by powering the unit off and press and hold the "Stop" and "Channel Up" buttons at the same time for a few seconds while powering the unit up. Hope this helps, good luck.
Jul 08, 2016 | Panasonic DMR-ES40VS DVD Recorder/VCR
When powered on, code F60 shows on player and nothing works.turned on and off and also unplugged for 10 seconds but doesn't reset.
With the unit powered off, press and hold the Stop and Channel Up buttons while powering on the main unit at the same time for about 5 seconds. This hoepfully will reset everything
Oct 03, 2015 | Panasonic DMR-ES40V DVD-Video Recorder
F60 displays on Panasonic DMR ES40V and efforts to reset unit have failed.
I had the same unit and had the same problem occur.
Finally contacted Panasonic service and sent it for repair.
They replaced it w/ a refurbished model.
http://www.service-center-locator.com/panasonic/panasonic-service-center.htm
Jan 21, 2015 | Panasonic Televison & Video
Jul 17, 2010 | Panasonic DMR-E85H DVD Recorder
Panassonic dmr-es40v f60 what can i do thank you
If you have access to spare/replacement parts, this is an easy error to correct by simply replacing the board.
You can recognize this board as the small board with the onboard HDMI port in the DMR-ES40V model, and has the mini cables connecting to it. It floats above the rest of the boards in the middle back of the machine.
All you need to do is to get the replacement part and open up the player by unscrewing the screws that are around the player, open up the cover and you have direct access to the board you are trying to replace.
You can as well take it to a repairman to help you with the replacement, that is if you cannot replace it yourself.
Hope this information is helpful to you.
Take care
Jul 12, 2010 | Televison & Video
Unplug the unit.
Jan 05, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
Jul 21, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Panasonic DMR-ES46V shows F60 Error
I have same problem with es40v - f60 error with no response to troubleshooting protocol. This machine also was used very little & also has a history of turning itself on. Panasonic used to make high quality products. A shame that their products are no longer trustworthy. I can understand that machines break - i'm very frustrated to learn replacement parts are not available. Guess i need to re- think brand loyalty.
Sep 02, 2007 | Panasonic DMR-ES46VS DVD Recorder/VCR
Televison & Video Logo
1,954 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
