Question about Dell UltraSharp 1907FP 19" LCD Monitor
Dell LCD power up issue
My 19" Dell LCD Ultrasharp monitor has an intermitent issue with powering on. When I start up my computer, green light comes on and the screen works for about 5-10 seconds and then powers off. Usually all I have to do is restart the computer and the screen will work again. This morning I tried restarting 5 times and the monitor will not stay powered on. I had this exact same problem with my last Dell 17" ultrasharp LCD monitor with this same CPU and ended up throwing the monitor away and getting this 19" one. Could it be a weak internal fuse or is it the power supply. If someone has suggestions on the repair, please let me know how hard is it for a novice like me to repair. Thank you.
  • jarrett436 Nov 13, 2009
    I did a little more troubleshooting and I believe that the issue may be with some sort of Power Save issue with the monitor. The screen looks as it if automatically shuts off after the Bios and Windows screens. I shut the power strip off for a while and then turned the computer back on and the screen came on automatically (as it always does) and then stayed on. I guess if I do not shut off the computer - there is no issue.?
    Sergeant:
  • 199 Answers
I suggets you try your Monitor with another pc and see if its behaving the same if the same then the monitor is bad
Now if there is change ie its showing on the other PC then your pc VGA card is faulty or is not seated correctly on its slot pls check this,
Also swap VGA cards this how you will know its status .
Last get another VGA card
Good luck
Posted on Nov 13, 2009
One of my computers lost power this morning due to blown fuse. When I turned everything back on the monitor screen has power and no screen.. it is all black
If the power light is on, but the screen never appears to light up, either the backlight or the power inverter have failed.
May 05, 2011 | Dell UltraSharp 1905FP 19" LCD Monitor
I have a Dell Ultrasharp 1907FPV, it's a few years old. Whenever I start my computer, the moniter stays dark and the green power button does these quick flickers. Eash flicker cycle takes less then a...
You don't have a short-circuit. That would have blown the protections or even the monitor. Refer to the manual, that flashing light may be a code that tells you the problem. I don't think the repair would be expensive...
Nov 29, 2009 | Dell UltraSharp 1905FP 19" LCD Monitor
UltraSharp 19' Screen will not autoadjust.
Start in SAFE mode (press F8 wile booting) and choose Last Known Good to see if it works in Windows DEFAULT setting.
My guess is that MSoft pushed a patch or SP to your box and IT replaced the dll your monitor was using.
Goto www.support.dell.com and DL the correct drivers again
Good Luck!
Let me know what you discover ;-)
Let me know if this fixes it
Mar 26, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Dell UltraSharp 1800FP is black on start up but green light is on
i had the same problem i found out it was the inverter i replaced it and it was like new. i do have 2 inverters if you are intrested
Jul 30, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell Flat Screen Model 1907 FPt
Appears you have an inverter problem. Do you hear any sparking?
Mar 29, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Dell 1901FP monitor
It is probably either a CCFL back light issue inside the LCD or a set of capacitors on the inverter/power supply board.
Would you be willing to part with it ?
Oct 26, 2007 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell ultrasharp 15 inch flat panel lcd
It totally sounds like the backlight is toasted. If that is the case you will have to replace them. Normally if the power inverter is shot, the monitor will power up briefly at least and then shut off. If you can use a flash light and see some sort of image on the screen you know that your VGA chipset works however your backlight(s) are burnt out. If not, more than likely your power supply (power inverter chipset) is broken and needs to be replaced..
Mar 28, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell UltraSharp 1907FP 19" LCD Monitor Logo
182 people viewed this question
Alun Cox
