Question about Asrock K8NF4G-SATA2 Motherboard
My computer with Windows XP Pro SP2 is crashing often, after i had connected a hdd with my computer ============ CPU-Z TXT Report Processors ------------------------------------------------------------------------- Number of processors 1 Number of threads 1 APICs ------------------------------------------------------------------------- Processor 0 -- Core 0 -- Thread 0 0 Processors Information ------------------------------------------------------------------------- Processor 1 ID = 0 Number of cores 1 (max 1) Number of threads 1 (max 1) Name Mobile AMD Athlon 64 3200+ Codename Newark Specification Mobile AMD Athlon(tm) 64 Processor 3200+ Package Socket 754 CPUID F.4.2 Extended CPUID F.24 Brand ID 8 Core Stepping SH8-E5 Technology 90 nm Core Speed 2009.1 MHz Multiplier x FSB 10.0 x 200.9 MHz HT Link speed 803.7 MHz Stock frequency 2000 MHz Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64 L1 Data cache 64 KBytes, 2-way set associative, 64-byte line size L1 Instruction cache 64 KBytes, 2-way set associative, 64-byte line size L2 cache 1024 KBytes, 16-way set associative, 64-byte line size FID/VID Control yes Max FID 10.0x VID range 0.950 V - 1.400 V K8 Thermal sensor yes K8 Revision ID 4.2 Attached device PCI device at bus 0, device 24, function 0 Attached device PCI device at bus 0, device 24, function 1 Attached device PCI device at bus 0, device 24, function 2 Attached device PCI device at bus 0, device 24, function 3 Thread dumps ------------------------------------------------------------------------- CPU Thread 0 APIC ID 0 Topology Processor ID 0, Core ID 0, Thread ID 0 Type 02002002h Max CPUID level 00000001h Max CPUID ext. level 80000018h Cache descriptor Level 1, I, 64 KB, 1 thread(s) Cache descriptor Level 1, D, 64 KB, 1 thread(s) Cache descriptor Level 2, U, 1 MB, 1 thread(s) CPUID 0x00000000 0x00000001 0x68747541 0x444D4163 0x69746E65 0x00000001 0x00020F42 0x00000800 0x00000001 0x078BFBFF 0x80000000 0x80000018 0x68747541 0x444D4163 0x69746E65 0x80000001 0x00020F42 0x0000020A 0x00000001 0xE3D3FBFF 0x80000002 0x69626F4D 0x4120656C 0x4120444D 0x6F6C6874 0x80000003 0x6D74286E 0x34362029 0x6F725020 0x73736563 0x80000004 0x3320726F 0x2B303032 0x00000000 0x00000000 0x80000005 0xFF08FF08 0xFF20FF20 0x40020140 0x40020140 0x80000006 0x00000000 0x42004200 0x04008140 0x00000000 0x80000007 0x00000000 0x00000000 0x00000000 0x0000003F 0x80000008 0x00003028 0x00000000 0x00000000 0x00000000 0x80000009 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000A 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000 0x80000010 0x00000000 0x00000000 0x00000000 0x00000000 0x80000011 0x00000000 0x00000000 0x00000000 0x00000000 0x80000012 0x00000000 0x00000000 0x00000000 0x00000000 0x80000013 0x00000000 0x00000000 0x00000000 0x00000000 0x80000014 0x00000000 0x00000000 0x00000000 0x00000000 0x80000015 0x00000000 0x00000000 0x00000000 0x00000000 0x80000016 0x00000000 0x00000000 0x00000000 0x00000000 0x80000017 0x00000000 0x00000000 0x00000000 0x00000000 0x80000018 0x00000000 0x00000000 0x00000000 0x00000000 MSR 0x0000001B 0x00000000 0xFEE00900 MSR 0xC001001E 0x00000000 0x00000042 MSR 0xC0010015 0x00000000 0x00000000 MSR 0xC0010042 0x1806180C 0x060C000C MSR 0xC0010041 0x00000001 0x00000C0C Chipset ------------------------------------------------------------------------- Northbridge NVIDIA GeForce 6100 rev. A2 Southbridge NVIDIA nForce 410/430 MCP rev. A2 Memory Type DDR Memory Size 1024 MBytes Channels Single Memory Frequency 167.4 MHz (CPU/12) CAS# latency (CL) 2.5 RAS# to CAS# delay (tRCD) 3 RAS# Precharge (tRP) 3 Cycle Time (tRAS) 8 Bank Cycle Time (tRC) 11 DRAM Idle Timer 16 Command Rate (CR) 2T Memory SPD ------------------------------------------------------------------------- DIMM # 1 SMBus address 0x50 Memory type DDR Manufacturer (ID) (0000000000000000) Size 1024 MBytes Max bandwidth PC3200 (200 MHz) Part number Number of banks 1 Data width 64 bits Correction None Registered no Buffered no Nominal Voltage 2.50 Volts EPP no XMP no DMI ------------------------------------------------------------------------- DMI BIOS vendor American Megatrends Inc. version P1.10 date 05/12/2006 DMI System Information manufacturer unknown product K8NF4G-VSTA version 1.00 serial 00000000 UUID 00020003-00040005-00060007-00080009 DMI Baseboard vendor unknown model K8NF4G-VSTA revision 1.00 serial 00000000 DMI Processor manufacturer AMD model Mobile AMD Athlon(tm) 64 Processor 3200+ clock speed 2000.0 MHz FSB speed 200.0 MHz multiplier 10.0x DMI Memory Controller correction 64-bit ECC Max module size 1024 MBytes DMI Memory Module designation DIMM0 size 1024 MBytes (single bank) DMI Memory Module designation DIMM1 DMI Memory Module designation DIMM2 DMI Memory Module designation DIMM3 Graphics ------------------------------------------------------------------------- Number of adapters 1 Graphic APIs ------------------------------------------------------------------------- API NVIDIA NVAPI API NVIDIA I/O Display Adapters ------------------------------------------------------------------------- Display adapter 0 Manuf. API index 0 Display name \.DISPLAY1 Name NVIDIA GeForce 6100 Revision A2 Codename C51 Technology 90 nm PCI device bus 0 (0x0), device 5 (0x5), function 0 (0x0) Vendor ID 0x10DE (0x1849) Model ID 0x242 (0x242) Performance Level 3D Applications Core clock 425.0 MHz Memory clock 0.0 MHz Software ------------------------------------------------------------------------- Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600) DirectX Version 9.0c
  • wilfredkj Nov 13, 2009
    my motherboard is k8mm-v ms-7142 ver :1 .i need the motherboard drivers
    President:
  • 414 Answers
Probably itz either minor case of software corruption/improper ground/cpu fan..
or major case of faulty or defective main board/ram/hdd..
..plz do check the following as in order:..
the Hardware part:..
1)see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
2) 4) a) see if ur hdd is noisy or emitting any 'ticking' noise (like 'tuk tuk' or 'kirr kirr')..
b) or if the system is not supporting either the newly installed device or itz software/driver /firmware
if so, u need either a fresh os installation or ur hdd is likely to b replaced..
3)remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
4) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market) between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
5) on main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(esp above1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)....
the Software part:..
1) hv a licensed and UPDATED antivirus installed (i prefer avg/kaspersky,remember, without updation a full version antivirus is useless)..
2) download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
3) download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'remove all the unnecessary startup items from here..(if u can't find what to remove, post me/us in ur comment with all the items listed in each n every tabs herein)..
4) remove all unnecessary software from add/remove programs..
5) download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
6)disable the following:..
a) 'Automatically Restart' right click on my computer->properties->advanced->startup n recovery->(uncheck on the) Automatically Restart;
b)'Error Reporting' right click on my computer->properties->advanced->error reporting->disable error reporting->(uncheck on the) 'but notify me when critical error occur'..
7) Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
if u r bot a professional, always better to seek advise from ur system admin/vendor....
Posted on Nov 13, 2009
Eax300se problems with XP
First, open your Task manager and open the "performance tab". There are a lot of built in programs in XP that can peg the CPU to full and this will slow/crash your computer. If any program is eating 100% of your CPU power for a long time, use Google to see how to fix the problem.
Test your RAM: Open the Start Menu and type in mdsched.exe, then press enter. - Then follow the procedure you think is best for your machine.
If your machine is capable via the BIOS, check to see at what temperature the CPU is running. Some processors run hot all the time, but some processors can't take the heat and will crash.
Also, if your computer is not under warranty physically check to see that the CPU fan is moving freely... and the GPU fan as well if your computer has one. Clean any dust and what not off of the blades if it is dirty, or replace if necessary.
If none of that seems to be the issue, remember that XP is considered "End of Life" and a lot of programs will not run on XP any more. Also remember that while some programs might still work, they may still be buggy on XP.
Oct 16, 2013 | Computers & Internet
What is the best motherboard and system configuration for adobe premiere 6.5 and pinnacle pro on rtdv ? I need the configuration in details please..... Please, thanks, Mack
TECH SPECS for ADOBE PREMIERE 6.5
Minimum System Requirements
Windows
  • Windows 98SE, Me, 2000 (SP2), or XP
  • Intel PIII 500MHz
  • 128MB RAM (256MB or more recommended)
  • 600MB HDD space for installation
  • CD-ROM drive
  • QuickTime 5.0 recommended
  • Microsoft DirectX certified FireWire
  • dedicated large-capacity 7200RPM HDD
  • For Real-Time Preview:
    Pentium III 800MHz processor (Pentium 4 dual processors recommended)
    Macintosh
  • Mac OS 9.2.2 or Mac OS X v.10.1.3
  • PowerPC G3 (G4 or G4 dual recommended)
  • 64MB RAM (128MB or more recommended)
  • CD-ROM drive
  • QuickTime 5.0.2
  • QuickTime compatible FireWire
  • large-capacity HDD capable of sustaining 5MB/sec
  • For third-party capture cards:
    Adobe Premiere certified capture card
  • For Real-Time Preview: G4 processor (G4 dual recommended)
  • Jun 27, 2011 | Pinnacle Pro-ONE RTDV Video Capture
    Can the Dell Latitude D610 run any of the following games: Age of Conan Star Trek Online Champions Online Aion
    Check your system if it meets the following requirements
    Age of Conan
    Required
    OS: Windows Vista/XP
    Processor: 3GHz Pentium IV
    RAM: 1GB RAM
    Video Card: Shader Model 2.0 and 128MB RAM: NVIDIA GeForce 5800 or ATI 9800
    Recommended
    Processor: Intel Core 2 Duo 2.4 GHz (E6600) or better
    Video Card: NVIDIA GeForce 7950GX2 or better
    RAM: 2GB or more
    Enhanced for: DirectX 10, 64-bit processors, multi-core
    Supports Parental Controls on Windows Vista
    Start Trek
    System Requirements
    • OS: Windows XP SP2 / Windows Vista / Windows 7 (32 or 64-bit)
    • CPU: Intel Core 2 Duo 1.8 Ghz or AMD Athlon X2 3800+
    • Memory: 1GB RAM
    • Video: NVIDIA GeForce 7950 / ATI Radeon X1800 / Intel HD Graphics
    • Sound: DirectX 9.0c Compatible Soundcard
    • DirectX: Version 9.0c or Higher
    • HDD: 8GB Free Disk Space
    • Network: Internet Broadband Connection Required
    • Disc: 6X DVD-ROM
    Recommended System Configuration
    • CPU: Intel E8400 Core 2 Duo or AMD Athlon X2 5600+
    • Memory: 2GB RAM+
    • Video: NVIDIA GeForce 8800 / ATI Radeon HD 3850+
    • Disc: 6X DVD-ROM
    To check your system hardware> click on start>all programs>accessories>system tools> system information.
    Thanks for using Fixya
    proton
    Mar 27, 2010 | Dell Latitude D610 Notebook
    Windows xp sp2, amd sempron 2800
    you just need to go to the website of your motherboard brand, then after that you just click the motherboard, when you are now in the site just type your motherboard model, then click the driver, then chose the US when you download the sound and video driver
    Jun 30, 2009 | AMD Sempron 3100+ 1.8GHz 256k Socket 754...
    XP-Pro Crash
    I don't know why but some systems which have XP (SP1 or SP2) simply can't take the upgrade to SP3. Your system appears to be one of them. For instance our family's computer had XP SP2 and upon upgrading to SP3 we received a fatal crash while XP was loading into normal operating mode.
    I managed to resolve the issue by booting to safe mode and restoring the system to a date before I installed SP3. Sorry that the new SP doesn't work for you.
    Feb 03, 2009 | Microsoft Computers & Internet
    Cant play game
    This game is suffering from technical bugs lots of them. You must look for the patches.
    the real prob looks to be inside the game engine and only developer may be fully aware of it.
    Dec 20, 2008 | Computers & Internet
    Windows Xp sp 2 installation problem
    check the cpu fan or remove it then put it again
    Nov 08, 2008 | Intel D845WN (KD845WNPAK10) Motherboard
    Not booting up
    The OS doesn't like all the changes that were made. To keep people from cloning hard drives and putting them in whatever machine they want, microsoft winxp recognizes even subtle changes, upgraded cpu, memory video cards etc.
    1. put the hard drive in the old machine
    2. run link
    3. Software
    4. click on Installed Program
    5. click on licenses
    6. .click on report
    7. quick report licenses html
    8. click on print
    9. select page 1
    These are the key codes for your machine,
    now put hard drive in new machine, boot with xp pro cd and choose repair option. re-enter key code when prompted and telephone Microsoft in activation wizard.
    Apr 08, 2008 | EliteGroup GeForce 6100SM-M Motherboard
    Asrock K8NF4G-SATA2 Motherboard Logo
    709 people viewed this question
    Top Asrock Computers & Internet Experts
    David
    David
    Computer Links
    pankaj rautela
    pankaj rautela
    Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
