Question about Canon PowerShot A540 Digital Camera
Camera says there is no memory card but the memory card is in the slot.
  • 535 Answers
Remove your memory card then connect with card reader then plug it in PC if its work in card reader your card is ok then the problem in camera or if its not work with card reader your card has been dead
Posted on Nov 13, 2009
Memory card for t3 no longer feels secured in slot
The holder that holds your memory card is broken and needs to be replaced.
Apr 03, 2012 | Canon EOS 1100D / Rebel T3 Digital Camera
How to remove memory card from camera
Confirm the power-on lamp and the monitor are off and open the battery-chamber/ memory card slot cover. Be sure to turn off the camera before opening the battery-chamber/memory card slot cover.
Removing Memory Cards 1 Before removing memory cards, turn the camera off and confirm that the power-on lamp and monitor are off. 2 Open the battery-chamber/memory card slot cover and press the card in to partially eject the card. 3 The card can then be removed by hand. Do not attempt to remove the card at an angle.
Insert the memory card.
4 Slide the memory card in correctly until it clicks into place. 5 Close the battery-chamber/memory card slot cover.
Oct 08, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Can not down load pictures off of the camra
If you have got a memory stick take it out of your camera and if your computer has a slot for it slot it in. if you don't have a memory card buy one from any local camera shop and put your pictures on it then slot it in to your computer. if your computer doesn't have a slot for the memory card you can buy a USB stick with a memory card slot in it.
Dec 18, 2010 | Kodak EasyShare Z1012 IS Digital Camera
The memory card slot feels tighter than usual. after i put in the memory card and turn on the camera, i get the message of "no memory card."
Make sure you are inserting the card in exact manner as illustrated in the camera manual or near card insertion slot.
Try to check into the memory card slot if any of the contact pins are not damaged.
Oct 05, 2010 | Canon PowerShot SD850 IS Digital Camera
I get a "Memory card error" message on my SD750?what could be the problem with my card and can it be solved?
The reason there is an error message on your memory card is because the memory card might have been damaged or probably not inserted properly.
To find out if the memory card is damaged, try to use the memory card in other devices that supports the memory card to see if it works. If it works on other devices, then the problem if from the card reader that is in the camera, and if it does not work, then the memory card is faulty. And the only solution is to replace the memory card.
To test the slot in the camera, try a tested okay memory card on it, if it does not work then the slot is faulty and to solve this problem, i will strongly advice you take the camera to a camera repair guy to clean the slot for you.
Goodluck
Sep 13, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Sanyo VPC-S1285 what is the best memory card for this camera and how do i put it in?
You want an SDHC Memory card UP TO 8GB's in size. A good one is shown at: http://www.jr.com/sandisk/pe/SAD_SDSDB8192A1/ but you can Google the above type memory cards and take your pick.
Then, open battery cover on camera. Slot for dropping memory card into is right next to opening for dropping in batteries. You will see a little picture on camera of a card in-between the battery openings when looking straight at the slot (with one corner appearing to be cut off which is how memory cards look) showing how card should go into the slot but also read instructions that came with memory card.
Jan 02, 2010 | Sanyo Cameras
How do I enter my sandisk into my kodak easyshare camera?
Hello
  1. Open the camera memory card door on the side of the camera.
  2. Insert the camera memory card into the slot with the connecting end of the card facing the camera, and the lip on the card facing toward the front of the camera. CAUTION: The camera memory card can only be inserted one way into the camera. Forcing the card in the wrong way may damage your camera.
  3. Push the camera memory card all of the way into the card slot and then close the door. Make sure that no dirt is present when you close the door.
Hope this can help you.
Kind regards
Andrea
Nov 17, 2009 | SanDisk 2GB microSD Memory Card
Wot is the memory card slot for
HI,
The memory slot is an expansion slot that you can put a camera card (SD card) into so you save all you photo's to that instead of the internal memory.
This is because your camera only has a limited amount of internal memory limiting you to the amount of pictures you can save on the camera.
Purchasing a memory (SD card) is certainly an advantage and they can be used in card readers, MP3 players and computers etc.
Regards.
Sep 14, 2009 | IT Works Cameras
Memory card will not push in and stay engaged in memory card slot
This happens most of the time with digital camera and mobile phones, if you try to insert the memory card in a wrong direction. Before inserting your memory card, look into the slot hole and see the position of contact terminals and insert your card in such way that the card comes with contact with the terminals inside the slot. If your card already got struck into the slot, try removing it by pulling out using a small nose plier. Also try with another memory card of similar type to detect any problem due to your memory card. I hope this will help you out.
Aug 04, 2009 | Canon PowerShot A720 IS Digital Camera
Momory card slot?
I imagine that is just the plastic plug for the bus port. Are you looking for a laptop memory slot or SD camera memory slot. These machines do not have an SD camera memory slot. You will have to get a USB adapter for it. They sell them at Walmart for approx $15. The laptop memory slots are located under a panel on the bottom of the machine. If there is only one slot there, then the other slot is under the keyboard.
Jun 29, 2008 | Toshiba Satellite M45-S165 Notebook
Canon PowerShot A540 Digital Camera Logo
51 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
