Question about Nokia N79 Cellular Phone
How can I delete a character in a text message, they does not seem to be a return key?
  • Nokia Master
  • 6,993 Answers
There should be "Clear" as soon as you start typing on the screen of any nokia phone. Though before you start typing, you will see "Back" on the screen but immediately you type a letter, the "Clear" will appear which replaces the "Back".
Just Check thoroughly, you will definitely seen how to delete a character.
I wish you the best.
Posted on Nov 13, 2009
  • Jillian Oct 16, 2012
    I have the same problem and I can't see a clear or back button anywhere like most Nokia phones!
How do I use alphabet keys on remote
Generally, entering text is carried out the same way as with most cell phones.
  • 0, 1, 2, 3, 4, 5, 6, 7, 8, 9: Enter a character to the position pointed by the cursor.
    • First press: enter the first character from a set of characters related to this button. Each subsequent press: you may change the entered character to the next one from this set.
    • 0: enter the space.
    • 1: enter a special character (punctuation marks, etc).
      • Up, Down, Left, Right after pressing 1 (special character entering mode): select the required character.
  • ENTER: confirm selection; finish text entering.
  • SUBTITLE: enter the period (for numeric mode); functions like button 1 (character mode).
  • CLEAR (<-): delete a character to the left of cursor.
  • SELECT (cap'num): switch input mode:
    • abc: character mode, small latin letters.
    • ABC: character mode, capital latin letters.
    • 123: numeric mode, digits.
  • RETURN: cancel the text changes and finish text entering.
  • Left/Right: move the cursor one character left/right.
  • Up/Down: move the cursor to the start/end of a text line.
    • If the cursor is already in start/end position: select another user interface element which is under/over the current text entry area (only for dialogs with several elements of user interface; text changes are confirmed automatically).
  • POP UP MENU: show context menu with a list of available commands. They allow you to cut, copy and paste text using the clipboard, much like it is done on a PC.
  • http://electronicshelponline.blogspot.com/
Jun 26, 2016 | Televison & Video
Backspace key only deletes one character at a time ? unless i hold shift key for ten seconds?
that is normal
if you wish to delete more than one character, shift button and click on mouse and wipe over the text then delete
Jun 15, 2012 | Acer Aspire One A150-1006 Notebook
I have a new Motorola Cliq2 How do I delete text messages form this phone?
To delete a message or a message thread
  1. From the programs menu, tap Text Messaging
  2. On the Text Messaging screen, tap the message thread that you want to delete.
  3. Do one of the following:
    • To delete the entire thread, press the Menu key and then tap Delete conversation. When prompted to confirm, tap OK.
    • To delete a message in a thread, press and hold the message that you want to delete, and then tap Delete message on the options menu. When prompted to confirm, tap OK.
Note: To delete all messages on the text messaging screen, press the menu key while on the text messaging screen, tap Delete all conversations, tap Yes to confirm.
https://motorola-global-portal.custhelp.com/app/answers/detail/a_id/61024/~/cliq-2---delete-and-forward-sms/mms-text-messages
Mar 02, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
Asus P320 does not detected on computer. It was since last month I think.. And I have another problem, which may cause the above problem The other problem is that my Asus P320 seems to ''freeze'' its...
backup all your data and then hard reset.
To reset your phone
1. Tap Start > Settings > System tab > Default Settings.
2. Key in "1234" to confirm that you want to restore default settings and press OK.
3. Tap OK.
The phone will restart automatically after it is reset.
Mar 25, 2010 | Computers & Internet
Unable to acess phone or type messages correctly
Have you tried re-setting? Remove you battery and hold down end call button for 20 seconds. Release it and then put battery back in and wait for the phone to reprogram itself. This may take a while, so be patient.
Feb 07, 2010 | RIM BlackBerry Curve 8310 Smartphone
Can I retrieve my deleted texts from my palm centro and how?
Hello michael_s35,
This is a rather awkward procedure but it will allow you to keep a copy of your text messages on the Centro. Ready? Here it is:
A). In Text Messages
•Open the text you want copied
•Select all of the characters in the message by slowly dragging the stylus from the upper left hand character to the bottom of the text message.
•While the text is highlighted, press the menu button (at the bottom right-hand corner)
•Select Edit in the Menu.
•Select Copy in the Menu. (text is now copied to the clipboard)
B). In Memos
•Press the home key
•Go to the Main category (Main showing in the top drop-down list)
•Tap on Memos
•Tap the New button at the bottom of screen
•Press the menu button (at the bottom right-hand corner)
•Select Paste in the Menu. (text is now saved in the memo file)
•Repeat the above procedure (A & B) for each text message you want to save.
*Each text can be appended in the same memo or saved in a different memo*
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Jan 21, 2010 | Palm AT&T C/PHONE PALM CENTRO S64801
Accidentally sending multiple copies of text
I was having this very same problem with my brand new Propel. It seems that the longer the message is, the phone will split it into multiple messages, because it starts at 1 and as I continue typing it increments the number of messages to be sent. If I delete some characters, then the number of messages goes down. I seems like it allows about 160 characters per message.
What I'm still confused about it why it is driving your friends crazy. Are they getting the full message multiple times? I would think they would get multiple messages with a portion of your message in each. Are they getting the messages out of order?
Jul 09, 2009 | Samsung Propel A767 Cell Phone
Buffer full message
"The Buffer Full message is displayed if more than 60 characters, this
would include symbols, accents, and returns, have been entered to be
print. To clear this message press the BS key to delete some existing
text and rephrase the text to maximum of 60 characters.
However if the Buffer Full message is displayed before 60 characters
have been entered to be print, then your P-touch may need to be reset.
To reset the machine:
1. Power off the machine.
2. Hold down the ""CODE"" and the C""LEAR"" keys.
3. With both keys depressed, press the ""ON/OFF"" key once.
4. Release the ""CODE"" and the ""CLEAR"" keys.
If your machine is within Warranty, please contact our Customer Support
Center at 1-877-478-6824 so that we may make arrangements according the
product warranty.
If your machine is out of warranty, you may take your machine to a
localBrother Authorized Service Center. To locate a local Brother
AuthorizedService Center visit our website (http://www.brother-usa.com).
You can also locate a local Brother Authorized Service Center by calling our automated phone system at 1-800-284-4357. This
system can provide you with either a verbal listing or a printed listing
via facsimile.
Feb 11, 2008 | Brother PT-1750 Thermal Label Printer
Nokia N79 Cellular Phone Logo
129 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
