Question about Lenovo 3000 N100 CoreDT2080 VB PC Notebook
My problem with my Lenovo is somewhat the same but different. It started shutting off for no apparent reason. We also took out the battery with no longer worked. Bought a new on from the factory and inserted it and the compter worked off the battery if unpluged for about a month. Then for no reason it shut down again and I had a time getting it rebooted. Checked and the battery is 99%charged. Seems the computer does not recognize the battery is even in the computer. I am stuck to the power. My computer was about 3years old before we started having problems. I use XP. countygirl7@frontiernet.net
  • 6,993 Answers
If your computer works directly to electricity without the battery, then the battery is faulty. Battery showing you 99% does not mean it is working, because bad battries gets full on time. The cell of the battery might have been dead because only GOD knows how long it had stayed in the factory.
But if you are convinced that the battery is good, then check the adaptor, and if the adapter is good.
Just try to check everything to ascertain the fault. And let me know what happens next.
I wish you the best.
Posted on Nov 13, 2009
Starts then dies.97 couger
Try disconnecting negative battery cable for a few minutes then reconnect. This will reset computer. Worked on my wife's car. It would start and shut off 2 seconds later for no apparent reason. Do you have a check engine light on? Could also be caused by a bad maf/map sensor or tps sensor
Nov 21, 2014 | Cars & Trucks
Flash drive unrecognized
Remove the USB, shut down, unplug, remove battery, plug in, Reboot the machine, insert the USB, you didn't supply the Lenovo Model or the OS? Without knowing your OS or laptop model, the size of the USB drive may make a difference. Do ALL your Windows and Lenovo updates.
Feb 13, 2013 | Lenovo Computers & Internet
Lenovo T61 keeps shutting down for no reason. Repair shop took out fan and checked it, works fine. They also blew out dust from vents. Problem still there. I installed a CPU temp utility pgm and shows temp...
Automatic shutdown is always cause of overheating, busted heatsink/ fan/motherboard. if the fan and heatsink wasnt replaced yet though they check it fine i would still recommend replacing it. if the problem persists a mainboard replacement would be the last part needs to be replaced.
Dec 31, 2010 | Lenovo ThinkPad T61 Notebook
Unit keeps shutting down Lenovo 7757 Laptop.
Could be related to a heat issue if it just powers off for no apparent reason.
Try cleaning your fans our with some canned compressed air available at your local retailers such as Walmart, Fred Meyers, or Walgreen's.
However, if Windows displays that it is going to shut down due to low battery, you may try gauging if your battery life has significantly decreased. Less than 60 minutes is usually a good sign to replace the battery.
If Windows is just shutting down without any messages you can attempt to clean any malware off your computer by using Malware Bytes from www.malwarebytes.com. Also looking using Microsoft Security Essentials as a normal virus scanner (free).
Nov 26, 2009 | Computers & Internet
Abrupt shutdown of Lenovo 3000 Y410
motherboard thermal section problem
joe
Nov 03, 2009 | Lenovo 3000 Y410 Notebook
Car won't start, dead battery.
You will need tools (a good multimeter) to figure it out if no apparent reason can be found. We call this a parasitic drain. Could be a relay stuck on to anything, even a bad computer.
Nov 02, 2009 | 1996 Pontiac Sunfire
T23 Dropped and will not turn on
I hate to say this, but it sounds like Lenovo Service is where you need to start at this point.
Jan 04, 2009 | IBM ThinkPad T23 2647 Notebook
How can i change my spark plug wire set
I recently did this on my 2004 Sedona. After much web browsing, decided to remove the intake manifold and access the plugs from the top. The intake manifold was apparently designed for realatively easy removal. Having seen exactly how much room is available, I believe that this is the simplest solution. Disassembly took about 5 hours and reassembly took less than an hour. It was somewhat intimidating, but not overwhelming. The primary reason for the lengthy time, was two bolts that I could not get enough leverage to move. I am somewhat small and do not have the arm strength of most mechanics and limited space did not allow a bigger wrench(I may need to get a new wrench before attempting this again:). I understand that the wires are easily damaged durring removal, so I replaced the plugs and wires. Also, if you decide to remove the intake manifold, be sure to replace the upper gasket. The upper gasket is different than the lower. I hope this helps.
Jul 30, 2008 | 2004 Kia Sedona
SOS!
Jun 29, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Shuts down for no reason
With the battery removed any interruption of the AC power will cause the laptop to cut off. The power adaptor may be faulty or intermittent or more likely the socket on the laptop motherboard may have a dry jointed connection. These problems would not be apparent with a charged battery fitted.
Otherwise [especially with P4 type processors] overheating could cause cutting out - clean any fans and make sure vents for air intake are not blocked [by bedding etc].
Mar 15, 2008 | Acer Aspire 3000 Notebook
Lenovo 3000 N100 CoreDT2080 VB PC Notebook Logo
89 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
