Question about Maytag MEW5530D Electric Single Oven
Set oven kicks on then after a few seconds kicks itself off
    Sergeant:
  • 172 Answers
I would say the baking heating element is bad and when replacing that I would also replace the Oven sensor "thermostat"...Before replacing anything make sure your timers are all off and not set to a start and stop time and try oven again to make sure its not just the timer was set .........
Posted on Nov 20, 2009
GE Monogram 30" built-in oven turns itself off after a few seconds.
Likely you need a thermal cutoff replaced near where your heating elements are. It senses the fault and shuts down. You can but an after market thermal cutoff from most any electronic parts supply, and maybe even from an appliance parts supply.
Nov 12, 2013 | GE JTP20 Electric Single Oven
Oven Switching Off
I have a few questions. Does the oven reach the set temperature? How do you get it to go back on? and if you do not set the time do you have the same problem?
Dec 06, 2007 | Electrolux EOB6632 Electric Single Oven
What will make a oven come on with the oven knob turned to the off position?
Maybe your knob is turning but the rod the knob is connected to is not turning. Best to remove knob and turn the rod to off position with Pliers to be sure it is actually being turned to the off position.
Jan 15, 2018 | Frigidaire 30" Self-Cleaning Freestanding...
My Kenmore 911-4298814 oven won't hold broil or bake temp setting. The oven powers on with no error. When I press the "Bake" and dial up a temperature to (say) 350 degrees, the LCD displays...
just had similar problem with frigidaire, temp display would go blank, not even show clock, i took off back of stove, the circuit board would wiggle. when i pushed in on the circuit board it worked correctly.
Oct 30, 2011 | Ovens
My oven wont work afte a power cut its flashing oo:00 auto and I dont have a manual
you have 2 buttons one pops out for adjustment the other is only a push button push the left hand one repeatedly till a red clock symbol shows at top of clock then turn right hand knob to set time wait a few seconds and clock will set itself.
Nov 16, 2009 | Neff B1421 Electric Single Oven
When turning the oven on it will not start up
Assuming the clock/timer has not been accidentally set, and this is what is turning it off, does everything go off on the oven including the lights and the display on the oven control?
If it does, then it could be the oven overheat thermostat kicking in.
Also is the cooling fan running normally in the background because if it isn't, this will cause the oven to overheat.
Nov 13, 2009 | Stoves 720EF Electric Double Oven
Double oven, top oven run by keypad turns off
I have a double oven. The top unit works fine. The bottle unit will turn on to cook or clean. Then after a few seconds it turns itself off.
Oct 12, 2009 | GE Profile JKP56 Electric Double Oven
Simpson oven 736 evolution turns itself on briefly then turns off
sounds like you have a control board problem
Jun 12, 2009 | Ovens
Jenn-Air w156 Single Wall Oven Problem
Most likely its the EOC (electronic oven control), it needs to be replaced. If you self cleaned the oven a lot the very high heat generated fatigues computers in modern ovens.
Sep 28, 2007 | Jenn-Air JJW7530DDS Electric Single Oven
Maytag MEW5530D Electric Single Oven Logo
88 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
