Question about Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB Bottom Freezer Refrigerator
My automatic ice maker has stopped making ice, although the 'arm' is in the upright position. Can you help? Thanks very much. Carole Carley
  • 48 Answers
For the ice maker to be on your arm should be down not up.
Posted on Nov 13, 2009
How do I turn off ice maker
Good Afternoon Rsimmon5,
I see that you are trying to turn off the ice maker to your Frigidaire refrigerator, model# FRS6R5EMB. You will be moving the signal arm to turn your refrigerator off.
To begin ice production, lower the wire signal arm to the DOWN or ON position. The ice maker turns off automatically when the ice container becomes full. To stop the ice maker, raise the wire signal arm until it clicks and locks in the UP or OFF position.
If you have any trouble with your ice maker continuing to make ice after this, I recommend contacting either the manufacturer or an authorized technician in your area. Hope this helps.
-Best Regards-
WP
Apr 05, 2014 | Frigidaire FRS6R5EMB Side by Side...
Ice maker quit working
Good Afternoon Kevin,
I understand that your Frigidaire refrigerator, model# FRS26R4A, is not making ice. There are a couple of things you can check. First, check the wire signal arm to make sure it is in the "down" or ON position. The ice maker turns off automatically when the ice container becomes full. To stop the ice maker, lift the wire signal arm until it clicks, and locks in the "up" or OFF position. Second, check to see if the water dispenser is dispensing. You might need to change your water filter. It's recommended you change it every 6-8 months. The other thing if your appliance is not dispensing water is there might be a kink in the hose or maybe the water supply has been cut off. Hope this has been helpful.
-Best Regards-
WP
Mar 27, 2014 | Frigidaire FRS26R4A Side by Side...
Frigidaire FRS6LR5E ice maker won't stop making ice
Ice maker wire signal arm is being held down by some item in the freezer. Move item and release wire signal arm. Any ice cubes that are frozen together over the wire signal arm. the ice rises in the ice bucket and pushes the wire signal arm up and this is what stops ice production as ice is used then arm comes down and starts ice production all over again. if there is nothing holding arm down then you will need to replace ice maker.
Oct 07, 2013 | GE Monogram ZDI15C Automatic Icemaker
Ice maker won't stop making ice. We put the metal flip facing up and it just keeps making ice. It should stop...right?
If the arm is up and locked in position, it should stop the ice maker. check that the bail arm is indeed pushed into the ice maker head, you will likely have to remove the ice maker with the 1-3 screws holding it in place, to see it. Check also that the other end of the bail arm is attached near the fill cup, if its not attached, that could be the reason. If the arm does not appear to lock in the upright position, or if it does and still does not stop ice production, you will need to replace the ice maker
Oct 26, 2010 | Kenmore 57029 Side by Side Refrigerator
Ice maker stopped making ice. I emptied ice holding tray and since then, if will not make ice. I adjusted arm in hole correctly. Arm is down and is in correct position to make ice. Still no ice. Please...
Fill the ice maker with water. If it freezes and dumps the the water control valve on rear of the refrigerator and near floor is defective and will need replace. If the water just freezes then the ice maker thermostat is the problem, Let me know,Thanks Sea Breeze
Aug 17, 2009 | Refrigerators
Ice maker arm in freezer
On most automatic ice makers the arm is in the up position to make ice, but check with the manufacture to make sure
Jul 20, 2009 | Amana ABB1927DE Bottom Freezer...
Ice maker
hi. thanks for the question. is the arm on the ice maker in the up position. it could be stuck in the ice cubes. the arm has to he up to stop the process thanks the appliance doc.
Oct 02, 2008 | LG LRFC25750 Refrigerator French Door
I have an Amana fridge with an internal ice maker. It suddenly stopped making ice. The lever that moves up and down popped out and I put it back in but now there's no ice. Can you help?
hi thanks for the question is the arm in the down position and is the arm put back in its proper position check that thanks please leave a positive feed back the appliance doc
Sep 24, 2008 | Refrigerators
Ice maker does not make ice. Shut off arm staysin up position. The manual specifies that this arm can not be forced by hand. How can I lower that arm?
hi thanks for the question all the ice makers i have seen you can move the arm by hand so i would move it thanks cause it wont make ice with arm in up position thanks the appliance doc
Sep 07, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice Maker not making ice
replace the icemaker is the best solution , or possibly jst the control module
Jan 14, 2008 | Jenn-Air JCD2389G Side by Side...
Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB Bottom Freezer Refrigerator Logo
187 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
