Question about Hotpoint RGB745 Gas Kitchen Range
I have a Hotpoint oven that is more than 5 years old, and it burns natural gas. when i use the oven, it will burn, but it doesn't seem to burn all the gas while it is on. The gas company has checked the oven with the sniffer several times and the same thing applies they cannot find any leaks. Should i replace the unit or try to have it fixed. And do you have any ideas on what it could be.
  • 10,865 Answers
Hello. Thanks for choosing Fixya! First of all you clearly did the right thing by having the gas company come by. Most likely the safety valve on your stove is defective and needs to be replaced. The safety valve is supposed to prevent accidental gas flow.
Here is the other issue. In home repairs have become so pricey once any thing is out of warranty that it is always a judgment call as to what to do. The new gas stoves are much more efficient than the models of 5 years ago, they are much better when it comes to baking with uniform results, etc. etc. etc. There fore, you could call a few appliance repair shops and get estimates, which would allow you to make a more educated decision about whether to repair or replace. Best regards, J.
Posted on Nov 13, 2009
How can I manually light the oven if the igniter does not work?
Is it a natural gas oven? I remember old times, when igniter didn't work, my 91 years old great-grandmother opened the gas and used a match. This procedure is considered rather dangerous but it never exploded to her...
Jul 26, 2015 | Hotpoint RGB524 Gas Kitchen Range
Gas odor and turns my pans black
Sometimes theres too much air in the line. A better connection from tank to stove may help, or your running low on propane. Try cleaning the burners with an old toothbrush removing built up sut. Your flame should burn blue, not yellow. Hope it helps!
Sep 16, 2012 | Tappan Ovens
I need to change the stove to operate on propane instead of natural gas.
You will need to conact a gas safe engineer who will change your gas jets from natural gas to LPG, then carry out various test to makesure your flueless appliance burns the gas safely and efficiently
Jul 11, 2011 | Hotpoint Kitchen Ranges
The gas stove fire burns with black soot and is only 1 month old
Gas should not burn with soot, if it does it is dangerous as poisonus fumes will be produced as the air/fuel mix is wrong.
Call a qualified gas engineer to check out the installation and make it safe.
Nov 11, 2010 | Microwave Ovens
When oven was 1-year old, the lower oven started making a noise that sounded like a blow torch, usually after being on for a little while. It was (after many service calls) repaired by replacing the...
Hi Nancy
I have to ask you a couple of questions. Is the range set up for LP or Natural gas? Blow-tourch sounds are normally caused by to much air going into the burner. If you can look at the burner safely the flames should burn just out of the burner. If the flames are way off the burner the air adjustment is way off or you range is set for the wrong gas. Are your top burners OK?
Sep 13, 2010 | Maytag Kitchen Ranges
Hot water heater is natural gas type gas is staying on all the time burning even when water is hot it continues to burn. Not hot water tank is over 10 years old should I try to repair or just replace???
The thermostat is what is out of calibration...this is built into the gas valve. Unfortunately the part cost almost what a new tank does. My opinion is to replace.....today gas valve....another 8 years the tank...
May 09, 2010 | Heating & Cooling
Flames in oven are WAY too high! Having trouble lowering them.
Hi! melisrus
If you are using LP, even if you change the regulator settings from Natural Gas to LP Gas, the orifices all need to be changed. The Orifices should have come with the new unit, if not contact Hotpoint.
www.hotpoint.com
Make sure you order the instruruction manual and this is an Oven with Range Top, you will need orifices for all the burners on the range top.
InMrFixIt
Nov 18, 2008 | Kitchen Ranges
Oven & broiler not working
you ignitor is going out you will need to replace it the ignitor needs to draw a min of 3.2 amps in order to open the gas valve coil if short of this it will not open at thimes it may just have enough to open
Jun 28, 2008 | Hotpoint RGB528 Gas Kitchen Range
8 year old kitchenaid gas range nom fire in the oven
I went to the kitchenaid web site for parts and found a trouble shooting section. I read about how a electronic glow coil works and discovered that mine was just old and did not reach the right voltage to open the gas flow valve.
Feb 20, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
162 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
