Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
My whirlpool ultimate care series washer does not drain and won't spin. what seems to be the problem?
  • Whirlpool Master
  • 19,396 Answers
Hi.
It is a drain problem. The machine timer won't advance to spin until it detects that drain is complete. For this reason the machine is also not spinning.
Check lid switch first, this is testted with a multimeter.
Ensure that the drain hose at the back is not clogged or kinked.
Access the drain pump and undo the hose attached to the pump, see if there is any blockage in there.
The pump can be fully tested by a technician energizing it directly.
If the drain system is fine check the pressure switch that detects when the drain is complete, this should not be the case.
If all the rest is OK, replace the control board.
You can find parts and diagrams for most models here.
Regards.
Posted on Nov 13, 2009
Testimonial: "THANKS THIS WAS VERY HELPFUL"
  • 48 Answers
Lid switch most likely.
Whirlpool ultimate care heavy duty leaks underneath, not agitate or spin. only humms and fills up
Again!! Any washer that does not drain has a bad Drain Pump. Very Common. I see this in 40-50% of the problems. Replace the drain pump and your washer will be very happy
Jan 19, 2014 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer won't spin or drain
if it can't drain then it won't spin,something could be jammed in the pump,the clutch isn't falling on the trans. what does it do when it goes into spin cycle'do you hear any noises.when it does go into spin cycle listen if nothihng hapeens open the lid and close it listen to see if the clutch falls
Mar 06, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
How do I repair my Whirlpool Ultimate Care 2 LSQ9549L Top Loader Washer?
check the motor coupling,if the coupling is broken you'll hear the motor run but the agitiator won't move and no spin,the coupling connects the motor to the transmission.watch this video
http://www.youtube.com/watch?v=9K1KHEogf3c
May 30, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer ultimate care II will not spin motor is working
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 26, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Phillips Whirlpool Ultimate Care II won't spin very quickly
If this is a top loader it is possible that you have a bad clutch. sometime when your transmission leaks oil it will get into the clutch and this will cause a slower spin and possibly no spin. Tip the washer back just enough so you can see under the washer. Is there a orange/yellow sticky substance under there? If so this is trany fluid.
Jan 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care II will not spin
You said,washer is full of water and will not spin. You hear the lid switch clicking. When you start it on spin cycle and hear a hum, the tub moves a couple of inches and then stops...shortly after it shuts off.
Some reasons this may happen
Washer won’t drain or spin
n
1. Is the drain hose clogged, or the end of the drain hose
more than 72 inches (183 cm) above the floor?
2. Is the lid open? ............Also the lid switch can be faulty!!
The lid must be closed during operation.
3. Is there excessive sudsing?
Always measure detergent. Follow manufacturer’s directions.
4 If you have very soft water, you might need to use less
detergent.
Sounds to me like the lid switch can be faulty!!Then it acts like the lid is open.
Huuum
Oct 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
check for problem with the pump it is coupled to the motor, if it is spinning then it should also be pumping out the water
Apr 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
319 people viewed this question
Dan Webster
Dan Webster
Sal De
