Question about Frigidaire FWS833A Top Load Washer
Washer will not fill with water goes right to wash with no water
  • 48 Answers
Sounds like the water level pressure switch could be bad. Or the tube feeding it could be plugged.
Posted on Nov 13, 2009
Washer does not fill; goes right to wash mode
The pressure transducer is defective it as built into the water temp switch and must be replaced.
Jul 18, 2014 | Whirlpool Ultimate Care II LSQ9549L Top...
Wash cycle
What is the model number of the unit?
Dec 02, 2012 | Washing Machines
FISHER PAYKEL WASHER GWL11 WONT FILL TANK
Check your diverter valve is in right and working.
Energized valve, water goes over bowl.
Non Energized valve water goes down the drain.
Feb 12, 2012 | Fisher and Paykel GWL11 Top Load Washer
Kenmore washer does not fill first ,goes right into washing.Replaced timer ,same problem.
Hello Sue,
The reason your washer starts agitating instead of filling first is shortted water level sensor switch that should be replaced.
The part number for that switch is W10177795
GENE
Nov 11, 2011 | Kenmore Washing Machines
Won't fill with water and goes right to wash cycle
Chech the pressure lelvel switch and hose that is connect to the pressure switch and tub
Mar 25, 2010 | Frigidaire FEX831CS Top Load Stacked...
My whirl pool washing machine tries to fill up but never fills up
This means it is stuck between the spin and rinse cycle and the time piece in the housing unit might need replaced if the knob itself isnt stripped also make sure it is on small or large load..
Dec 09, 2009 | Whirlpool LSR5132PQ Top Load Washer
Washing maching not filling with water
The problem is most likely the water fill sensor switch. If it is telling the machine that it is full, it will go right to agitate.
Apr 25, 2009 | Roper RAB2121KW Top Load Washer
Will not fill with water goes right down the drain,works sometimes
Your drain line is too low or there is a air gap blockage.
Remove the drain line from the drain and hold it up high while filling with water and see if it fills and stops.
If so, correct the drain line problem.The drain hose should be 36 inches from the floor.
Apr 12, 2009 | Kenmore 22422 Top Load Washer
Washer fills up than starts draining while in wash cycle
Hello , here is the fix-your drain hose is placed to low in the drain line in the wall, it can not be placed in water or it will siphon the water out of your washer into the drain pipe and it wont stop until it hits air. try pulling your drain hose up and out of the drain and get a zip tie or cable and tie it to one of the water valves by the drain pipe placing the end of the drain hose about 5-6 inches inside the drain pipe. Let me know if you have any other questions and good luck it will work.
Phil
Jan 28, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
Frigidaire FWS833A Top Load Washer Logo
50 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
