Question about Kenmore 62602 Electric Dryer
Dryer not heating on any setting.
I have a Kenmore Dryer-Model/Stock # 110.669121691; Serial # MH3094217. It stopped drying last night. Dryer runs just no heat on any setting.
  • rablack66
    rablack66 May 11, 2010
    This could be a few different things are you capable of testing continuity on components
  • Kenmore Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer if you are then:
Sounds like your problem may be with the heating coil.
Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
Hope this helps
Posted on Nov 13, 2009
On my kenmore dryer 970-c82062-00 I can get all 3 timers to start but the heated automatic dry portion does not time out.
that model number doesn't come up,you sure that isn't the serial number?also does the dryer have heat,when you run it on time dry the timer just counts down like a clock,when on auto or more or less the heat comes on until the dryer heats to temp. the heat shuts off and the timer will advance,when the heat comes back on the timer stops moving,it will do this until the clothes are dry,if you do have heat you could have a bad sensor or a bad cycling thermostat but you'll have to check it with a meter.send the model number and i can help you better.
Feb 16, 2014 | Dryers
Old Kenmore Dryer can't turn-off and won't heat
Look like you need a timer control
model number should start with a 110. number timer for your dryer is about $70
Dec 05, 2013 | Kenmore Dryers
I own a Kenmore clothes dryer, serial #ME2475807, model/stock #96573220. Recently the heat stopped working. It still spins the clothes around, but does not heat up to dry them properly. I think it needs a...
Unplug the dryer and take the back off
The backsides is where the element is located.
The back side components look like this:
Their are 2 limits mounted on the heater chamber:
More here
Sep 12, 2011 | Kenmore Dryers
My Kenmore model 70 dryer works with the timer but the auto-dry feature will never turn off the dryer. I'm assuming that this is a moisture sensor problem. Info from the tag inside the dryer: type:...
are your clothes drying?when the dryer heats up the heat shuts off then the timer will move,when the heat starts the timer stops,no heat no timer movement.when did you last clean out the dryer?you need to clean out the vent line if it's a long run i use a leaf blower to clean it out,you need to clean out the duct that the lint filter slides into and vac out the inside of dryer where the motor is,you should do this once a year so you don't have a fire and your clothes will dry on time and you won't have any problems like this,try running it with the vent line off to see if this helps.you also could have a bad thermostat but you should clean it first anyway
Apr 17, 2010 | Kenmore Dryers
It wont stop running... dries perfectly but wont stop. Thanks! ;o)
either a timer or the heating element or a blocked vent also there is a resister on some kenmore/whirlpool dryers and if it is out it wont advance in the auto cycles. It should advance in the timed cycle with or without heat
May 11, 2009 | Dryers
Dryer is not heating and will not stop running
if you were running it on timed cycle and it was still running with no heat then you have a bad timer and if you were running it on auto cycle and it was still running and its electric dryer then you have a bad element ,,, if its gas you may have a bad ignitor / larry
Dec 04, 2008 | Dryers
Kenmore 62602 Electric Dryer Logo
80 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
