Question about Sea and Sea Syrens OnBoard WiFi Motherboard
Packets in/ IP address?
Hello, I am new to this boat that has a syrens system onboard. However, the system is not working.
We are not getting any packets in/ IP address.
Can you help?
    Novelist:
  • 127 Answers
It sounds like it's bad. Those Syrens units either work great forever or they have problems forever. It's a router, it should be doing DHCP to automatically assign your settings. If it's not it's not working. You didn't tell how you were connecting to it, so plug in wired connection has to be assumed. With that there should be no problems with you using the wrong wireless key or something like that.
You might try power cycling that unit ... or use its reset button to try for factory defaults.
I do this type of work for marine, and have a wifi system available should you need to replace that one. http://www.wifiyacht.net
Posted on Nov 22, 2009
  • Alan Spicer
    Alan Spicer Nov 23, 2009
    You, ummm, told him to ask a staff member? then asked him to tell you what boat it is? It's the Titanic, that's important because....? Now we're getting some where, ...and the ip address?
    tell you everything? Nahhhhh. How about just the ip address and the gateway? :-)
    Problem Solver:
  • 16 Answers
Well first ask a staff member,Tell me what boat it is, and ip adress.
the way to find that out is on the connected computer with the trouble,press start and then run,type in cmd.exe and in the black box type in ipconfig.exe /all and then tell me everything in the section of wireless adapter
Posted on Nov 21, 2009
How to traceroute of packet using IP address?
Yes, it is possible to trace the route of the packet using IP address. You just go to the link I mentioned above, then follow the following instruction:
1. Click traceroute
2. Then go to ip2location
3. Click traceroute
Now you can see the route of the packet.
This website will also help you to find IP, Browser, Country information. This site also provides the current location of that IP address.
Dec 15, 2017 | Computers & Internet
Tip
Resolving 169.x.x.x IP address problems
This article outlines methods of resolving issues with a 169.x.x.x IP address. This address results from a built in feature of windows called automatic private IP address(APIPA). When your computer is unable to find a DHCP server the APIPA service will assign itself a 169.x.x.x IP address. According to Microsoft, the APIPA service checks for a DHCP server every five minutes.
Releasing the IP address
1. Click on Start and click Run.
2. Inside Run, type ipconfig /release to release the IP address.
3. Then after the IP address is released, type ipconfig /renew
Disabling the Ethernet Adapter
1. Click on Start and right click on My Computer. Then click on Manage.
2. Click on Device Manager and then Network Adapters
3. Under Network Adapters, right click on your Ethernet adapter and select Disable.
4. Wait approximately 5 seconds and right click on it and click Re-enable.
5. This restarts the DHCP client and tries to obtain an IP address from the Network.
Check the Ethernet cable
Sometimes a bad Ethernet cable can cause your system to receive a 169 IP address, try changing out the cable for a new one.
Disable antivirus and firewall applications
Disable/uninstall any external firewall, antivirus, or spyware programs (eg. Norton Internet Security, McAfee Security Center, Trend Micro 2007, Webroot).
Restarting the QoS packet scheduler Protocol
1. Click on Start and click Control Panel.
2. In Control Panel, double click on Network Connections and then Local Area Connection.
3. Click on Properties and uncheck QoS Packet Scheduler.
4. Click Ok and repeat the process.
Restarting the DHCP service
1. Click Start and select Run.
2. Type services.msc in Run and click Ok.
3. Find DHCP service and right click on it. Click on Stop.
4. Reboot the computer.
5. When the computer boots up, click Start and select Run
6. Inside Run, type the following: netsh int ip reset log.txt
7. Click Ok.
System Restore
1. Open Start and click on Programs and then Accessories.
2. Then click on System Tools.
3. Click on System Restore and select a restore point when you were not experiencing this problem.
4. Restore your system.
on Jun 14, 2010 | Computers & Internet
How to Prevent System Breakdown or Service Interruption of the MA5600 Caused by Network Attacks Through the Proper Configuration
The common improper configurations that affect the system security are as follows:
The ring network detection function and the anti-MAC address-spoofing function or anti-IP address-spoofing function are disabled. When the anti-MAC address-spoofing function or the anti-IP address-spoofing function is disabled, the ******* user sends the PPPoE and DHCP control packets by forging the MAC address or IP address of a legal user. In this case, the security of the system is affected.
Huawei MA5600
Run the ring check command to enable the ring network detection function on the user side
Run the security anti-macspoofing enable command to enable the anti-MAC address-spoofing function.
Run the security anti-ipspoofing enable command to enable the anti-IP address-spoofing function
The devices are managed by IP addresses of the public network and the access rights are not limited strictly when the ACL rule is configured. In this case, the network is attacked.
To ensure the security of devices, manage the devices by using the IP addresses of the private network. When configuring the ACL rule, you must comply with the principle of the minimum authorization to configure the accessible address segment. The accessible address segment can contain only the mandatory IP addresses of the management network segment. Other IP addresses cannot access the device management interface.
Run the acl command to create a basic ACL and enter the ACL mode. The number of a basic ACL can only be in the range of 2000-2999.
In the basic ACL mode, run the rule command to create a basic ACL rule. The parameters are as follows:
rule-id: Indicates the ACL rule ID. To create an ACL rule with a specified ID, use this parameter.
permit: Indicates the keyword for allowing the data packets that meet the related conditions to pass.
deny: Indicates the keyword for discarding the data packets that meet the related conditions.
time-range: Indicates the keyword of the time range during which the ACL rule is effective.
The packets that access the device management interface are not controlled so that the device is attacked by the packets. In this case, the system is caused to be busy and the services are affected.
Run the firewall packet-filter command to apply the packet filtering rules of the firewall to the interface to filter the packets that access the interface. In this case, the packet attack is prevented.
Huawei MA5616
Huawei MA5616 Gold Line
Huawei MA5616 Silver Line
Apr 12, 2017 | The Computers & Internet
Why Addresses in the IP Address Pool on a Switch Are Exhausted When the Switch Functions as a DHCP Server and It Has a Few Clients?
If the IP address pool has much more resources than needs of clients, the following two reasons may cause address exhaustion:
1. An attacker keeps changing the CHADDR field and sending DHCP Discover packets to exhaust addresses. If so, contact Huawei engineers to deploy DHCP snooping to protect the IP address pool.
2. The DHCP server ping function is enabled on the DHCP server. This function tries to ping the allocated addresses before responding to DHCP Offer packets. If a client responds to any ping packet, the DHCP server considers that there are address conflicts and addresses are exhausted. To solve this problem, two methods are available:
1. Capture packets on the ports connected to the DHCP server. If a client responds to ping packets, prohibit the client.
2. Disable the DHCP server ping function using the undo dhcp server ping packet command.
3. Such as S5700, S6700
Aug 01, 2016 | Computers & Internet
Netgear fs516 default ip address
switches do not normally have ip addresses as they are layer 2 network devices. They work on the MAC address of each network card attached to it to direct the network packets of data to the correct Network card.
Cisco Switches have an IP address but it is a virtual ip address used to remotely log into a Cisco Switch via IP but has nothing to do with the switching function however this is not a cisco switch.
Routers have IP addresses and use them to switch IP addressed packets to other Networks that have Routers connected to Switches.
Jun 30, 2014 | NetGear FS516 Networking Switch
Need ip address for syrens, not sure if i remember right: 192.168.1.1???
Hi Stephan,
the ip address of your router by default should be "192.168.1.1". to check if the ip adress of your router here's the solution :
  1. go to control panel > network and sharing/networking >change adapter settings
  2. then you'll see your local area connection
  3. right click on it>properties
  4. double click on (internet protocol tcp/ip) "tcp/ipv4 in windows vista/7
  5. the select "obtain ip address automatically" & "obtain dns server464142c.jpg automatically" click ok and click ok for the other window
  7. the dns server ip show should be your router ip adress
  8. open your web explorer and type in your router ip an press "enter" you'll get your router configuration where you'll be able to change the default ip.
I hope that it will help & don't forget to rate
Kind regards
Feb 14, 2010 | Sea and Sea Syrens OnBoard WiFi...
Plz send me the current status of contolling ip spoofing through inter domain packet filters
The current status is "operational" -- packet filtering is being used so that "outgoing" IP-addresses originating from a network are required to be IP-addresses that are valid within that network.
Nov 05, 2009 | Microsoft Windows XP Professional
No packets receive on network
Hello Melnavz,
Go into the Properties of "Connections" and high light the TCP/IP (Internet protocol) and press the "properties" button. Then choose the "obtain an IP address automatically".
This should fix your issue and good luck.
Jul 09, 2008 | Computers & Internet
Cannot find print server at all
How this works: Restoring the PocketPrintServer to Factory Defaults In most cases, the best way to restore the PocketPrintServer to factory defaults is through "telnet". However, if you are unable to connect to the device because of a configuration error, use the following method which does not require a network connection. To restore the PocketPrintServer to factory defaults, complete the following steps: 1. Disconnect the PocketPrintServer from the network and power cycle it. When it powers up, the LED will rapidly blink orange for five seconds. 2. Power down the device during the rapid orange blink period. Power up the device and power it down during that orange blink period two more times. 3. Reconnect the network cable and power up the PocketPrintServer. It will have restored itself to factory defaults and will rapidly blink green as it searches for a RARP or BOOTP server to find an IP address. Gleaning If an IP address has not been permanently assigned when the PocketPrintServer is powered on or reset, it will look for a "ping" packet on the network. If the PocketPrintServer receives a "ping" packet within two minutes, it will accept the IP address in the "ping" packet as its own address. To use Gleaning, you must have super-user privileges on a UNIX system. Gleaning also works under Windows 95 and Windows NT. 1. Add an entry in the ARP table that assigns an IP address to the Ethernet address of the PocketPrintServer. To do this, use the "arp" command. arp -s temp Example: arp -s 192.168.42.24 00:02:16:00:00:01 temp 2. Start a continuous "ping" to the PocketPrintServer. ping Example: ping 192.168.42.24 On some systems, this may require an additional parameter. Some implementations of "ping" only send out one "ping" packet which could get lost in transit. Check your system documentation for more information. 3. Connect power to the PocketPrintServer. The PocketPrintServer will "glean" its IP address from the "ping" packet. This IP address will remain in effect until the PocketPrintServer is power cycled or reset. Therefore, a permanent IP address should be assigned by running the ExtendView TCP/IP utility or via "telnet".
Jan 30, 2007 | Extended Systems Pocket Print Server
Sea and Sea Syrens OnBoard WiFi Motherboard Logo
132 people viewed this question
Top Sea and Sea Computers & Internet Experts
David Payne
David Payne
Are you a Sea and Sea Computer and Internet Expert? Answer questions, earn points and help others
