Question about Dell Dimension 8300 PC Desktop
Power light blinks amber and fans not running
  • Dell Master
  • 4,806 Answers
A blinking amber light demotes that there is a problem with an installed device like the CD/DVD Rom, sound card etc.
You will need to start troubleshooting and start to remove each removable part until you find out what device is causing the problem. But before you start taking devices out of the computer try this >>>>
Remove the power cord from the back of the tower and remove the side panel to expose the motherboard.
You now need to look for the motherboard battery and remove the battery for 30 minutes.
After the 30 minutes is up put back the battery and the power cord and try to boot the machine up. The battery looks like this >>>
If its blinks then you will have to start removing or just disconnecting the CD/DVD drive, hard drives and any other device that can be taken or disconnected from the motherboard.
Good luck.
Posted on Nov 13, 2009
In focusi 2114 will not stop blinking amber
pls check the uaer manual
http://www.projector-manual.com/manuals/infocus/InFocus_IN2114.pdf
page 6
http://manualmachine.com/infocus/in2114/771122-user-manual/page:6/
Power, blinking amber
The power button has been pressed to turn the projector off and the fans are running to cool the projector.
Nov 10, 2016 | Computers & Internet
Dell Desktop Fan Runs all the time and Amber Light
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard.
Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
May 08, 2014 | Dell OptiPlex 3010 DT
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
Dell 4700 blinking amber light. nothing else happens no fans no beeps.
HERE is the troubleshooting section for your PC from dell. It will give you at least a strating point as to what the problem may be. If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.
Apr 27, 2011 | Dell OptiPlex SX280 PC Desktop
Blinking amber power button dell 4700 c / light blinks & after a while it boots. when its running its fine works with no problem. Is it power supply. bad fan, coms - battery , or hard drive . or all...
first remove your memory and clean it with a clean cloth the remove the processor fan and clean the surface ot the fan an the processor then apply a thin layer of heatsink compound and fix tightly to the socket
Apr 27, 2011 | Dell Dimension 4700 PC Desktop
Powers On if I plug it in, and power supply fan runs...
Think of blinking amber as the initial state of the LED. As long as the system is receiving power from a power source and can pass that power through the system board to the LED on the Control Panel it should, at least, blink amber. As a result, a blinking amber Power Button LED is a reliable indicator that the system is receiving power from a power source. This, in turn, tells us that the source and power cord are likely to be functional. The Blinking Amber LED also tells us that the power supply to system board connection is good as well as the connections between the system board, I/O Panel and Control Panel. Depending on the components installed and the condition of those components, the LED may progress past blinking amber and move to solid amber. If the LED does not progress past blinking amber it indicates that the system is not able to properly distribute power to the system components. This is discussed in the next section of the interaction.
It does not indicate that the power supply is bad. It simply indicates that, for whatever reason, one of the power supply 'rails' is not operating within its specified range or, simply, that there is a short somewhere in the system.
The LED state could be the result of a misconfigured or incorrectly installed system component. A bad drive, for example, may be shorting out one of the rails. Incorrectly installed memory can cause a blinking amber front panel power button LED.
Feb 05, 2009 | Dell PowerEdge 1800 Server
Amber light on power button
Check to see if there are any loose connections to the memory cards on the memory board. Make sure the data cable to the drives are connected properly. Is the fan in the power supply on?
Jul 27, 2008 | Dell Dimension 8300 PC Desktop
Blinking power light
check your power supply. A flashing amber power button usually means its gone bad
Jul 15, 2008 | Computers & Internet
Power Problem
It could be the power supply isn't getting enough current to run things. I'd start there.
Jun 21, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 8300 PC Desktop Logo
172 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
